POV-Ray : Newsgroups : povray.off-topic : Lytro Cameras Server Time
26 Feb 2026 06:41:00 EST (-0500)
  Lytro Cameras (Message 1 to 10 of 14)
Subject: Lytro Cameras
Date: 22 Jun 2011 21:45:00
Message: <web.4e029a1b6ec54cc8f3c9d8950@news.povray.org>
Forget focal blur.  I'd like POV to output files in this thing's format.
http://www.digitaltrends.com/photography/lytro-the-camera-that-could-change-photography-forever/
By capturing more information from the scene, pictures taken with a Lytro camera
allow you to adjust the focus after the picture has been taken.  The bottom of
the page linked above has some picttures you can try it out yourself with.
While I'm certain the above pictures were cherry picked to show this capability
in its best light, I'm very excited about seeing how it works once consumer
models ship.
....Chambers
Subject: Re: Lytro Cameras
Date: 22 Jun 2011 23:03:37
Message: <4e02ad09$1@news.povray.org>
> models ship.
Note that if this camera uses techniques anything like what's been
around in the graphics research community for a while now, you'll pay a
hefty price in terms of lower resolution for the ability to change focus
after the fact.  Given that current cameras are beginning to capture
images in much higher resolution than most people view them maybe this
is an okay tradeoff.  The hype in the linked article is a bit over the
top though IMHO.
Also, it shouldn't be too hard at all to get povray to output into a
format you can do this with, although writing the viewer would probably
be a tad trickier (but still probably not too hard, although it's been a
while since I've looked at this sort of stuff).
Date: 22 Jun 2011 23:10:01
Message: <web.4e02ae7413a16337f3c9d8950@news.povray.org>
It all depends... if the demo on the story was indeed a live version of the
viewer, then I would imagine a standalone version would be available when the
camera ships.
Of course, something tells me they faked it for the story.  I didn't bother
examining it too closely.
---Chambers
Date: 23 Jun 2011 02:45:21
Message: <4e02e101@news.povray.org>
  Just output the depth and surface normal information for each pixel
(besides the regular pixel color information, in HDRI resolution for
extra oomph, of course) and you can do a lot of postprocessing with it.
  (In fact, if this information would be output for each recursion level
instead of just the first one, the possibilities would increas, as it
would allow more accurate post-processed focal blurring of reflections,
refractions, etc.)
Date: 23 Jun 2011 04:27:30
Message: <4e02f8f2@news.povray.org>
I heard about that technology years ago. (It may even have been on
Tomorrow's World.) Not particularly interesting to me, because I usually
just want *everything* to be in focus - which it usually is.
I'll get excited when they release a holographic camera. (Which, I would
like to point out, is *totally* plausible.)
Date: 23 Jun 2011 12:25:09
Message: <4e0368e5$1@news.povray.org>
Am 23.06.2011 05:09, schrieb Chambers:
> camera ships.
There is indeed no fluent transition from foreground to background;
looks like a set of precomputed images to me, with clickable regions
bringing up the best fit of the set.
Date: 23 Jun 2011 12:27:54
Message: <4e03698a$1@news.povray.org>
Am 23.06.2011 03:42, schrieb Chambers:
Note that the render time would probably be the same as running a focal
blur render multiple times with different focal points (presuming you
save photons and radiosity data for re-use).
Date: 23 Jun 2011 12:41:51
Message: <4e036ccf$1@news.povray.org>
> refractions, etc.)
This would of course work as a quick hack in some cases, but I'd imagine
it'd have difficulty near death discontinuities, particularly for scenes
like looking through nearby grass at a distant background where depth
discontinuities are everywhere.  I'm sure it's solvable in a
good-enough-for-most-scenes sense though.
In any case, I suspect that the camera itself works through an entirely
different technique called light field photography (or plenoptic
photography).  Instead of me describing it you can read about it here:
http://en.wikipedia.org/wiki/Plenoptic_camera  This sort of thing should
be downright trivial to do in povray, although render times would be high.
As a side note, I have occasionally though it would be really useful to
get a really rich image representation such as you describe form povray.
  Particularly since it seems like you should be able to do thing like
change some of the material parameters of objects and some things about
lighting and see results in real time if you had a good image
description like that.
Date: 23 Jun 2011 13:07:00
Message: <4e0372b4$1@news.povray.org>
Am 23.06.2011 18:41, schrieb Kevin Wampler:
According to the thesis by the company's CEO, that's exactly what they do.
Date: 24 Jun 2011 10:35:29
Message: <4e04a0b1@news.povray.org>
Invisible escreveu:
>> Lytro camera
yes, holography is exactly what I thought of (the "light from all
directions" concept).
Of course, holography and this focal-changing one demands a proper
viewer too, possibly even more expensive, limited and cumbersome than
the simple 2-frames stereographic ones they're trying and failing so
hard to sell today.
a game sig: http://tinyurl.com/d3rxz9
