POV-Ray : Newsgroups : povray.off-topic : Audacity and vocal track question Server Time
11 Sep 2025 17:24:14 EDT (-0400)
  Audacity and vocal track question (Message 1 to 5 of 5)
Subject: Audacity and vocal track question
Date: 17 Nov 2010 18:25:01
Message: <web.4ce4633eb44f366334d207310@news.povray.org>
Hi, I've got an important problem and the Audacity website doesn't have working
links to a forum.
I have an audio track of someone talking where some of the vocals go just off
scale.  I want to make this a high-quality soundtrack to an animation using
TMPGEnc.  Any tips?
One thing I tried was to "Amplify" in Audacity where I just reduced the max
volume to about 90% of full scale.  This gave, in Audacity, a strange click at
these portions where it went offscale.   Then I tried Adding Noise (fullscale
white noise reduced -20 dB twice) to the soundtrack, then doing a "Noise
Removal" on the combined track.   Right now I'm rendering this with TMPGenc to
see if I have the same problem.
Any tips appreciated, I'm trying to help my son do a school project. thanks.
Subject: Re: Audacity and vocal track question
Date: 17 Nov 2010 19:30:00
Message: <web.4ce4732e9391cfbb34d207310@news.povray.org>
Um, I tried resizing in audacity the **images** from 3364 pixels to 640 pixels,
and the **sound** quality improved. Aha, it was probably due to some kind of
constant quality or MB/second setting I hadn't found.  thanks anyway.
Date: 18 Nov 2010 09:50:02
Message: <4ce53d19@news.povray.org>
gregjohn <pte### [at] yahoocom> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 17 lines --]
> links to a forum.
> TMPGEnc.  Any tips?
  As you might imagine, the clicks and cracks are caused by the original
wave being clamped at the maximum amplitude, causing a flat plateau at
the top of the wave, with sharp transitions.
  While the information which went off-scale is forever lost (if you don't
have the original recording), the clicks could be removed by reducing the
overall volume of the sample (as you did) and then smoothing out these
plateaus (making them smooth curves rather than sharp plateaus). However,
I don't know if Audacity (or any other program) has a filter for this.
Date: 18 Nov 2010 10:27:25
Message: <4ce545dd@news.povray.org>
Cool Edit Pro does, it is called Restoration filter.
Best Regards,
Date: 19 Nov 2010 07:45:00
Message: <web.4ce6710b9391cfbb34d207310@news.povray.org>
"gregjohn" <pte### [at] yahoocom> wrote:
> ... resizing in audacity the **images**
.... changing the pixel size output of the resulting anim in TMPGEnc...,  FWIW.
Thanks for the advice.
