> 1. Wow... Actual CAD software exists and there are people who use it.
Yes, the package I use sells about 30k copies a year. So some people must
be using it.
> 2. A mouse? Really? Not a tablet or some other futuristic input device?
I use a mouse for drawing 2D sketches (as do most other people I know), it's
most intuitive given that it's what you use for every other operation like
this in other software. For panning/zooming (and rotating when in 3D) I use
a 3D mouse with my left hand though.
Orchid XP v7 nous apporta ses lumieres en ce 2008/01/07 16:33:
> scott wrote:
>> Just for interest, all modern 3D CAD programs work in similar way to
>> SketchUp to start with. You draw you stuff using the mouse, and the
>> software automatically tries to guess what you meant to do (ie lines
>> at right angles to each other, lines parallel, same length etc).
>> After you've drawn your initial sketch you can then go and delete/add
>> constraints until your sketch is exactly as you want. Of course
>> constraints can be formulae based on other dimensions, other drawings
>> etc so it's very flexible to build up a whole model based on just a
>> few parameters. The huge benefit is that when you want to change one
>> of the key parameters, the entire model is updated in virtually
>> real-time (depending on the complexity of the model...)
Tons of peoples use those. AutoCAD is a huge one. Started 2D only, then added
faked 3D, then 3D primitives and modeling. Professional use only at over $6000
per workstation/user, unless you have a pirated version...
A tablet futuristic? It's over 20 years old!
No matter how good she looks, some other guy is sick and tired of putting up
with her shit.
Men's Room, Linda's Bar and Grill, Chapel Hill , NC
> added faked 3D, then 3D primitives and modeling. Professional use only
> at over $6000 per workstation/user, unless you have a pirated version...
I guess it's a fairly specialist application area... (Specifically, if
you're not designing anything, you probably won't need it!)
Well, *computers* were regarded as "futuristic" for a very long time
after they were invented - mainly because almost nobody owned one. ;-)
I was half-expecting a dataglove...
http://blog.orphi.me.uk/
Invisible nous apporta ses lumieres en ce 2008/01/08 12:00:
>> then added faked 3D, then 3D primitives and modeling. Professional use
>> only at over $6000 per workstation/user, unless you have a pirated
>> version...
Engeenering, civil engeiniring, architecture, interior planing... Also
acoustics, stage planing and some more.
I have a brother who use it dayly for his work and use a "piked-up" version as a
hoby. The maker realy don't mind that, as long as you don't use that copy for
anything professional.
They made a "light" version that you can have for less than 5% of the price of
the regular version, made for those who can't "borrow" a copy from work. It's a
few versions behind.
You know you've been raytracing too long when you've converted POV-Ray into an
operating system; now you've got all the system resources to do your renderings.
Vimal N. Lad / Gautam N. Lad
> version as a hoby. The maker realy don't mind that, as long as you don't
> use that copy for anything professional.
Do you mean he is "picking up" the license at home from the license server
at work? That is totally legal and the whole point of having a central
license server - I do it all the time for both professional and hobby work.
And even if you don't have an internet/VPN connection to the license server,
you can "check out" a license and use it for up to 30 days standalone
(obviously nobody else can use the license during this period).
scott nous apporta ses lumieres en ce 2008/01/09 03:40:
>> don't use that copy for anything professional.
> server at work? That is totally legal and the whole point of having a
> central license server - I do it all the time for both professional and
> hobby work. And even if you don't have an internet/VPN connection to the
> license server, you can "check out" a license and use it for up to 30
> days standalone (obviously nobody else can use the license during this
> period).
Borrow the installations floppies(before)/CD(now) and install it localy at home
or on his portable.
There is NO registration procedure at all, No serial number to enter, and you
can leave all identification, but the name, blank. The name can be any 1 or more
leters.
Autodesk don't mind. They know very well that they will never sell the regular
version to individuals. They also know that an individual who have a "gray" copy
may induce some administrators to buy many licences. Increasing the user base is
the key word.
Expert, n.: Someone who comes from out of town and shows slides.
All sounds pretty high-end to me. :-)
(Let's face it, most people's job is to file paperwork...)
"Orchid XP v7" <voi### [at] dev null> wrote in message
news:47865e78$1@news.povray.org...
Eh? How do you come to that conclusion?
~Steve~
'Cause not everyone has a proper job :)
Now-a-days I file electronic paper instead of moving oil barrels from one end of
the rig to another.
Regards
Two is greater than four for sufficiently large two. ;-)
Or something...
