POV-Ray : Newsgroups : povray.off-topic : ANN: New, open-source, free software rendering system for physically correc= Server Time
7 Apr 2026 04:21:00 EDT (-0400)
  ANN: New, open-source, free software rendering system for physically correc= (Message 71 to 80 of 82)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: ANN: New, open-source, free software rendering system for physically co=
Date: 29 Oct 2007 08:58:31
Message: <4725e707@news.povray.org>
Vincent Le Chevalier <gal### [at] libertyallsurfspamfr> wrote:
> >   Unless I have understood something completely incorrectly, I think that
> > "unbiased rendering" simply means that light is not assumed to be coming
> > from a specific direction, but the entire space is sampled for possible
> > incoming light.
> But that means that the images should be different, no? And I mean, more
> than just noisy...
  It means that the scene has global illumination. It doesn't make surfaces
more opaque.
> >   (Besides, I think the only difference pure unbiased rendering would do
> > is to make the image have global illumination, ie. what povray calls
> > "radiosity", especially if big area lights are used instead of point
> > lights.)
> Well that's a big difference
  Not that much of a difference. It doesn't make surfaces more opaque,
for instance.
>, and I don't know if it's really possible
> or even desirable to make a single path if you're not looking for an
> unbiased result.
  I don't believe unbiasing makes surfaces more opaque, so I don't see
how that is any relelvant.
> I was thinking more of your reflection 1 transmit 1 example. Energy
> conservation is still one of the basic properties of BRDFs. There is no
> way you can represent that with a BRDF. Of course all BRDFs are only
> approximations, but that does not mean that they do not have
> constraints. I guess my use of "physically accurate" is the problem here...
  A BRDF can take light coming from several directions and calculate how
it affects the outgoing light towards a certain direction. I don't believe
BRDFs have the requirement that these different light amounts must be
*averaged* instead of being added together.
> A black object can have a bright highlight, of course. Or rather, a
> bright reflection. In that case, you would lower diffuse_amount, to be
> able to set a higher reflection_amount.
  How is the program supposed to guess that you really wanted a lower
diffuse amount?
  Besides, the black object was just an example. Take a red object, with
a relatively high diffuse, and a white light source. The surface can have
white highlights even though the surface is red.
  If you average the diffuse and the specular reflection, the latter
would get a red tint.
Date: 29 Oct 2007 09:45:54
Message: <4725f222$1@news.povray.org>
It could very well be the case. The unbiased renderer cannot allow any
non-conservative material. If it did, it would be unable to reach a
stable solution, because it attempts to simulate the physical system. If
you had just one non-conservative material in real-life, the scene would
just end up saturated with light...
So the biased renderer can handle surfaces that are perfectly
transparent yet perfectly reflective, because it samples a limited class
of rays that make it work. The unbiased renderer must sacrifice either
transparency or reflectivity in order for its solution not to explode.
If you do not make an average, as more rays are traced the brightness of
the image rises, which is not realistic. So regardless of lighting
theory, you must do an average. It is exactly what happens in anti
aliasing, I don't see the problem. That average, I think, stems from
Monte-Carlo integration.
> diffuse amount?
It does not guess, you tell it so. Because as I said, colors should be
normalized. If you want black you have to lower the diffuse amount.
If you add them up, there will be a red tint as well. It's just that you
clamp the components of the color after the fact, ending up with
something white. If no clamping happens, the red tint should still be there.
Vincent
Subject: Re: ANN: New, open-source, free software rendering system for physicallyco=
Date: 29 Oct 2007 10:15:57
Message: <4725f92d@news.povray.org>
Are we talking about a biased raytracer like POV-Ray, or a different
algorithm? POV-Ray definitely doesn't require normalized colors (3.7
beta and Mega-POV both support HDRI output).
Date: 29 Oct 2007 10:21:59
Message: <4725fa97$1@news.povray.org>
No I was just trying to point out a problem with mixing
reflection_amount & co with colors in the tentative pseudocode. POV-Ray
certainly has no need to normalize colors.
Thinking about it the easiest way would be to define all the amounts as
colors with all components between 0 and 1, and run the algorithm for
each color, rather than trying to treat all colors simultaneously...
Vincent
Date: 29 Oct 2007 14:33:31
Message: <4726358b$1@news.povray.org>
Sure, there will be a red tint no matter if you add them or average them but
in both cases the red tint is so small that it's insignificant.
Remember that the specular reflection of a light source is *many* times
brighter than the diffuse reflection of that same light source in that spot
where the highlight appears. So the contribution of the red diffuse
reflection is insignificant compared to the specular reflection - exactly
like if you had added them together.
Remember to think in terms of high dynamic range and not brightness values
clamped to a [0-1] range...
Rune
Date: 29 Oct 2007 15:09:28
Message: <47263df8$1@news.povray.org>
Vincent Le Chevalier wrote:
> OK, let's say more physically correct then ;-) I don't know, something
> that conserves energy, for a start :-)
Fair enough. Hey, does it get a prism right, defracting different colors
by different amounts? That seems pretty fundamental and possible even
without doing QED calculations.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 29 Oct 2007 15:27:17
Message: <47264225$1@news.povray.org>
I think you can manage that in much the same way POV does at the moment,
yes... It's just more costly in terms of rays, of course.
Vincent
Date: 29 Oct 2007 16:38:08
Message: <472652c0$1@news.povray.org>
Oh! I didn't even know POV handled it at all. :-)
Date: 29 Oct 2007 17:04:04
Message: <472658d4@news.povray.org>
>> moment, yes... It's just more costly in terms of rays, of course.
Actually you made me doubt whether it was in Megapov or POV-Ray, but
there it is, in mainstream POV:
http://www.povray.org/documentation/view/3.6.1/415/
Vincent
Date: 29 Oct 2007 18:20:59
Message: <47266adb$1@news.povray.org>
Kewl. Faked, but kewl. ;-)  When changing the IOR in an unbiased render
automatically makes a spectrum, let me know. ;-)
