POV-Ray : Newsgroups : povray.off-topic : Fun challenge Server Time
21 Jun 2025 18:52:22 EDT (-0400)
  Fun challenge (Message 1 to 10 of 23)
Subject: Fun challenge
Date: 25 Aug 2014 15:24:59
Message: <op.xk5xjwbaufxv4h@xena.home>
A) Make a solar system with  binary stars
B) Make the binary stars orbit around each other so that the trajectory
looks like intersecting circles of the same size, yet the stars should
never collide.
C) Have a planet for each star without colliding.
D) give each planet a moon.
E) change the size of one moon  to be the same size as it's planet so that
they become binary planets
F) ad a planet that orbits both stars.
-Nekar Xenos-
Subject: Re: Fun challenge
Date: 25 Aug 2014 15:26:19
Message: <op.xk5xl4xvufxv4h@xena.home>
On Mon, 25 Aug 2014 21:24:58 +0200, Nekar Xenos <nek### [at] gmailcom>
> never collide.
> that they become binary planets
http://labs.minutelabs.io/Chaotic-Planets/
left out the most important part :S
-Nekar Xenos-
Date: 25 Aug 2014 22:46:58
Message: <53fbf522$1@news.povray.org>
Am 25.08.2014 21:26, schrieb Nekar Xenos:
No problem.
>> trajectory looks like intersecting circles of the same size, yet the
>> stars should never collide.
That sounds rather easy - provided that the intersecting "circles" are
allowed to be slightly elliptic.
That might become problematic. AFAIK there is no general solution to the
three-body-problem except for m1 >> m2 >> m3, and here we have a
four-body-problem...
... a six-body-problem...
... and...
... so on.
I can only imagine it to be somewhat stable if you take care to make not
only the masses sufficiently different in order of magnitude, but also
the radii. Like, have the stars orbit each other at an average distance
of X, and have the planet orbit them at an average distance of, say,
100*X. (And yes, make that an exact multiple.)
Date: 25 Aug 2014 23:28:59
Message: <53fbfefb$1@news.povray.org>
I wonder how the results would look like if the number of planets
couldn't only decrease due to collisions, but could also increase due to
planets breaking apart in near-collisions, or by collisions of planets
with similar mass resulting in a big planet and a number of smaller
fragments.
Date: 26 Aug 2014 00:39:50
Message: <53fc0f96$1@news.povray.org>
Am 25.08.2014 21:24, schrieb Nekar Xenos:
> never collide.
Here's a good example of why that's more difficult than it may appear at
first:
http://goo.gl/8oj291
At first it seems that the system settles into a very neat routine:
While a pair of two heavy central bodies tumbles closely around each
other, a lighter third body circles it at a considerable distance, with
some precession but otherwise unremarkable. After a while the third
body's trajectory will become uneasy for a brief time, then settle again
into a more excentric but seemingly more stable orbit, ceasing its
precession.
But the peace is a treacherous one: Very suddenly, momentum will begin
to transfer from the inner planets to the outer one, drastically
increasing its orbital period and excentricity; within a matter of just
a dozen orbits it will start going off screen, until it spends maybe a
minute or so off screen at a time. Another dozen revolutions later the
orbital period and excentricity will start to decrease again, but will
never shrink again to fit inside the screen, and only a handful of
revolutions later the planet picks up speed again, this time to go for good.
Date: 26 Aug 2014 01:20:53
Message: <53fc1935$1@news.povray.org>
easy.
> never collide.
so both stars have nearly the same mass, not a problem. (not a ratio
bigger than 5 ?)
Hummm, due to Roche limit, a planet would only survive far away from
both (if it goes between the two and out of it, it's broken in very
small pieces due to the change of the gravity field... or it's not a
planet). So the planet is rather orbiting around the center of mass of
the two stars as one object.
Having two of them is not a problem (Jupiter/Saturn), but they are not
around a star.
A possibility would be to have the planets at the lagrange points.
L1 is hell and there is no place for two there, L2 & L3 are moving too
fast to respect Kepler equation. L4 & L5 (mirrored L4) are on nearly the
same orbit as the second object, so speed is ok to say "I'm orbiting
around..." .
But there is a problem for orbiting around the second star, as L4/L5 are
around the most massive one only... you can of course cheat and assert
the stars have the same masse, but L4/L5 are stable only for mass ratio
above 24.96...
Easy... excepted that each planet still does not exist according to C
unless you are far far away or at L4/L5.
So they are even further away from the stars, and they are like pluto
and charon.
Or they are even smaller to fit their orbits safely in L4/L5
stability of L4/L5 is still a problem.
I could finally go the easy way for a solar system with enough mass
increase (everywhere) to lighten Jupiter as a star. (but that make the
sun a supermassive star. as Jupiter need a boost to reach 0.07 sun's
mass to burn deuterium, so about a x13 factor)
Stars: sun (x13 mass, candidate to becoming a neutron star one day) &
jupiter as brown dwarf.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 26 Aug 2014 11:40:00
Message: <web.53fca8d3af6ef2fed858cefd0@news.povray.org>
> first:
> precession.
I saw the Wikipedia, it says that over a large timescales, the Solar System will
be chaotic.
Date: 26 Aug 2014 14:08:13
Message: <op.xk7onwqpufxv4h@xena.home>
this one is very interesting. This planet has a very exiting life :)
http://goo.gl/Gz5saE
-Nekar Xenos-
Date: 26 Aug 2014 14:26:05
Message: <53fcd13d$1@news.povray.org>
Am 26.08.2014 20:08, schrieb Nekar Xenos:
is that "exiting" or "exciting"? :-P
Date: 26 Aug 2014 15:23:45
Message: <op.xk7r5svqufxv4h@xena.home>
this is the closest I've gotten so far. But the binary planets still crash
after a few rounds
http://goo.gl/V6YRX2
-Nekar Xenos-
