POV-Ray : Newsgroups : povray.off-topic : Physically based rendering Server Time
4 Feb 2026 18:15:20 EST (-0500)
  Physically based rendering (Message 54 to 63 of 63)
Subject: Re: Physically based rendering
Date: 2 Jul 2015 12:16:38
Message: <559563e6$1@news.povray.org>
Am 02.07.2015 um 10:25 schrieb scott:
>> - Always use "fresnel on" for reflections (don't forget to specify
>> "ior"), or "metallic on" where applicable, and always use 0.0 for the
>> minimum reflection (or leave it out, specifying the maximum reflection
>> only).
> If you are using fresnel, is it valid (from a PBR point of view) to even
> scale the results using a maximum reflection other than 1?
Absolutely - if, for instance, your surface is littered with
non-specular material at a microscopic level. Fine rust on iron steel,
for instance, or a thin coating of dust.
In those cases it might be better, however, to use an average of two
materials.
Date: 2 Jul 2015 23:09:11
Message: <op.x06gc9hjufxv4h@xena>
>>> only).
> materials.
What about plastic? It reflects, but it's not highly reflective. I don't
think I would go higher than 0.5 maximum reflection on plastic.
-Nekar Xenos-
Date: 3 Jul 2015 04:34:39
Message: <5596491f$1@news.povray.org>
But are you sure simply scaling down the Fresnel reflection term in
those cases gives a physically correct result for those materials?
>> materials.
Yes that's my concern, that if you are using the reflection scaling to
"fake" a different effect (roughness, absorbtion or scattering etc) then
it *might* not be physically correct to just scale it.
In other words, if you created a geometrically microscopic rough surface
(or added physical dust, sub-surface scattering or whatever) and
rendered it with max reflection 1, would it be possible to get the same
result by rendering a perfectly smooth, clean surface with max
reflection set to some lower value?
Agreed completely, but does using the Fresnel equations to calculate
reflection (which gives an absolute value) and scaling the result to
simulate some other effect (surface roughness, sub-surface scattering
etc) give a physically correct result? Or is it just a "fudge factor" to
give something that looks correct?
Date: 3 Jul 2015 07:00:22
Message: <55966b46$1@news.povray.org>
>>>> even
>>> materials.
I don't know, but in all these cases different from the /simple/
reflective surfaces, we need some good working examples demonstrating
the properties. I confess that this is too difficult for me - and
probably most people - to do and expect them from our own gurus :-) I
have also difficulties visualising an averaged texture or a layered
texture staying within the properties boundaries.
Date: 3 Jul 2015 09:13:46
Message: <55968a8a$1@news.povray.org>
What really would be ideal would be some macros to use for various
groups of materials (glasses, metals, plastics, paints etc) with
parameters designed such that no matter what values you give you are
guaranteed a physically correct material.
I'm not a regular user of POV anymore so it's all too easy for me to get
one number "wrong" and then I don't get a physically correct material.
If there were some macros-for-dummies then this whole problem would be
avoided and would surely lead to much higher quality work from all
non-experts.
Date: 3 Jul 2015 09:36:08
Message: <55968fc8@news.povray.org>
Am 03.07.2015 um 05:08 schrieb Nekar Xenos:
>> materials.
For plastics - and actually any material that's neither metallic nor
coated - I think heavily blurred reflections and a well-chosen ior are
the key, not reducing the reflection maximum.
With a high ior, the maximum reflection only occurs when viewing the
material almost edge-on. And with blurred reflections, even there the
maximum isn't truly achieved, as the effective reflection brightness is
tuned down by averaging in reflections at a less shallow effective angle.
BTW, the ior of most plastics is in the range from 1.5 to 1.6.
Date: 3 Jul 2015 10:01:08
Message: <559695a4$1@news.povray.org>
Am 03.07.2015 um 10:34 schrieb scott:
>>>> even
If it's soot, then yes (provided you also tune down the diffuse term);
any other stuff mixed in, and things get more complicated, hence my
recommendation:
>>> materials.
For surface roughness, "roughness" is the POV-Ray parameter to tweak;
this also tunes down the brightness of individual pixels in highlights
(provided you use the "albedo" keyword) and reflections (provided you
also use the "roughness" keyword in the reflection block), by spreading
the highlights over a larger area (so much that you might not even
notice the specular reflection anymore), but just tuning down the
maximum brightness obviously doesn't get you the same effect, as it
leaves reflections crisp and sharp.
Sub-surface scattering has nothing to do with specular reflections - to
the contrary: It is the result of all the light that is /not/ reflected
in a specular manner (which is to say, at the object's surface). As a
matter of fact, sub-surface scattering (in a very simple case) is what
the traditional "diffuse" mechanism models.
Date: 4 Jul 2015 00:24:13
Message: <op.x08eiaqmufxv4h@xena>
>>>> even
>>> materials.
So a shiny plastic has a high ior I assume. Then it makes sense.
-Nekar Xenos-
Date: 6 Jul 2015 03:11:28
Message: <559a2a20$1@news.povray.org>
What makes a plastic shiny or not is usually the geometric finish on the
surface, not anything to do with the material itself. It all depends on
the surface finish of the mould tool that was used to make the part. It
can be anything from high polished (to give a high gloss finish) to a
very fine texture (to give varying degrees of matt finish) to a large
patterned texture for something like a leather effect on car trim.
Date: 11 Jul 2015 06:00:01
Message: <web.55a0e86c18c52d49a46a090d0@news.povray.org>
> Now, that is a comprehensive tutorial about do's and dont's. Thanks
> indeed Christoph.
I second that! So much wonderful/useful information--and in only one post!!
