POV-Ray : Newsgroups : povray.off-topic : Physically based rendering Server Time
22 Jun 2025 07:55:59 EDT (-0400)
  Physically based rendering (Message 44 to 53 of 63)
Subject: Re: Physically based rendering
Date: 26 Jun 2015 02:58:13
Message: <558cf805$1@news.povray.org>
On 26/06/2015 07:34, And wrote:
> "And" <49341109@ntnu.edu.tw> wrote:
>> Thank you. I knew this. It must do. This is due to POV-Ray's light source
>> defines the color of a diffuse surface which is illuminate by the light source
>> at a distance of fade_distance.
> I'm very smart.!!
LOL
You are too. :-)
Regards
Date: 26 Jun 2015 03:47:23
Message: <558d038b$1@news.povray.org>
>>> source
>>> light source
>> I'm very smart.!!
> LOL
> You are too. :-)
Why do I feel depressed now? :-)
Date: 26 Jun 2015 03:54:00
Message: <558d0518$1@news.povray.org>
On 25-6-2015 20:00, And wrote:
> Just like the opinion clipka have answered you the other day, an emission sphere
> in the sky is too small to render. I always use the parallel light to
> simulate the sun light and it is very convenient. If you would like to place a
> white look-like object, the sun's color should like this: rgb<1,1,1>*10000.
> Is a very large quantity.
Depending on the scene, the multiplicator used can be less than that. In
my experiments shown in p.b.i I used a multiplicator of 2 which works
quite well. Much higher values overexpose the scene.
Date: 26 Jun 2015 08:55:17
Message: <558d4bb5$1@news.povray.org>
Am 26.06.2015 um 09:53 schrieb Thomas de Groot:
>> emission sphere
>> place a
>> rgb<1,1,1>*10000.
Maybe there's a misundertanding here:
The multiplicator is needed on the looks_like object; the light_source
brightness should stay the same if you don't use fade_power.
Date: 26 Jun 2015 10:52:17
Message: <558d6721$1@news.povray.org>
>>> emission sphere
>>> place a
>>> rgb<1,1,1>*10000.
True enough. THere was a misunderstanding though from my side (of
course) as I had also added an emission to the looks_like object which
it doesn't need in fact with And's suggestion.
Date: 26 Jun 2015 11:27:10
Message: <558d6f4e$1@news.povray.org>
Am 26.06.2015 um 16:52 schrieb Thomas de Groot:
>>>> emission sphere
>>>> place a
>>>> rgb<1,1,1>*10000.
Um... a looks_like object should _always_ have a emission! Otherwise it
won't look like what a light source would look like.
However, And has correctly hinted someplace else at conflict between
different ways of simulating the same thing when using a "looks_like"
object. A light source should only show up in one of the two ways of
each of the following pairs:
- Classic diffuse illumination vs. radiosity: A "looks_like" object
should always have "no_radiosity on" set, which unfortunately isn't the
default. (Theoretically, an alternative would be to make the light
source invisible for the sake of the "diffuse" component, but in
practice that doesn't make any sense due to the vast differences in
computational effort; if you want to go that far, just leave out the
light source entirely and go with the "looks_like" object alone.)
- Specular highlights vs. reflections: A "looks_like" object should have
"no_reflection on" set. An alternative would be to make the light source
invisible for the sake of specular highlights, but POV-Ray doesn't
support this at the moment (which puts me to shame, as I must admit).
Date: 27 Jun 2015 01:10:00
Message: <web.558e2f2618c52d498107bb350@news.povray.org>
> >>> emission sphere
> >>> place a
> >>> rgb<1,1,1>*10000.
> Thomas
I saw the third one 'rsocp_uber_metallic.png' is just what my skill. I like it.
The color of sky is realism, too.
Date: 27 Jun 2015 01:20:03
Message: <web.558e317d18c52d498107bb350@news.povray.org>
Thanks for the interpretation.
Date: 27 Jun 2015 01:25:00
Message: <web.558e335418c52d498107bb350@news.povray.org>
> >> I'm very smart.!!
> > LOL
> > You are too. :-)
> Thomas
giggle.
Date: 2 Jul 2015 04:25:09
Message: <5594f565$1@news.povray.org>
> - Always use "fresnel on" for reflections (don't forget to specify
> "ior"), or "metallic on" where applicable, and always use 0.0 for the
> minimum reflection (or leave it out, specifying the maximum reflection
> only).
If you are using fresnel, is it valid (from a PBR point of view) to even
scale the results using a maximum reflection other than 1?
