POV-Ray : Newsgroups : povray.off-topic : Physically based rendering Server Time
22 Jun 2025 19:20:06 EDT (-0400)
  Physically based rendering (Message 24 to 33 of 63)
Subject: Re: Physically based rendering
Date: 24 Jun 2015 03:22:52
Message: <558a5acc$1@news.povray.org>
On 23-6-2015 19:22, clipka wrote:
> Am 23.06.2015 um 09:28 schrieb Thomas de Groot:
>> No more sad examples of reflective spheres on chequered planes :-)
> It's impressive what a difference it can make to really press for PBR,
> even for something so seemingly trivial as RSoCP; I think especially
> using a fully fresnel-aware model (using "fresnel on" in the entire
> finish block) and blurred reflections (with specular highlights properly
> tuned to match) really adds a level of credibility that you might not
> even have expected to be there.
Oh yes! While I jokingly mentioned the RSoCP I fully realised the
implications your rules would have on them.
Date: 24 Jun 2015 03:27:01
Message: <558a5bc5$1@news.povray.org>
On 23-6-2015 19:35, clipka wrote:
> Oh, and another one:
> - Always, I mean /really/ always and without exception, use
> "assumed_gamma 1.0".
> I guess this one is so trivial for me that I entirely forgot to mention it.
Oh, we are so used to your typical head bashing that we just grumble
"here we go again" ;-)
But that aside, it can never be mentioned too often.
Date: 24 Jun 2015 04:02:25
Message: <558a6411$1@news.povray.org>
Pictures!
Not real if there is no proof. :-)
Regards
Date: 24 Jun 2015 07:06:20
Message: <558a8f2c@news.povray.org>
> Pictures!
We are not allowed RSoCP pictures in this n.g., sir ;-)
Date: 24 Jun 2015 07:47:29
Message: <558a98d1@news.povray.org>
>> Pictures!
I know the rules. But I thought for you they could be bent.
Since uncle Ken moved on. We are sliding into decadence. :-)
Regards
Date: 24 Jun 2015 09:30:01
Message: <web.558ab00418c52d4916086ed00@news.povray.org>
> Am 21.06.2015 um 09:44 schrieb Nekar Xenos:
> > Can some explain to me what exactly PBR is. In Pov-Ray terms would be
> > nice :)
> PBR avoids old-school shading models and rendering algorithms that were
> designed to achieve a particular effect, and instead uses mechanisms
> that were designed to model the underlying physical processes.
> POV-Ray has been heavily geared towards PBR in recent times, and UberPOV
> should by now be a viable PBR tool, provided you stick to the following
> rules:
Precious information that definitely needs to land in POV-Ray documentation. But
I do like the shortcuts, because they are my only hope for an acceptable render
time, though I have not reached it yet.
Off topic request: please don't suppress POV rainbows! If you can't leave them
alone, please just improve them, as you did with iridescence.
Date: 24 Jun 2015 10:08:19
Message: <558ab9d3$1@news.povray.org>
>>> Pictures!
We are living in troubled times. No respect for the simplest rules of
render behaviour. I shall see yet in my old age the heresy of chequered
spheres on reflecting planes I am afraid.
That said, and in keeping with off off-topic, I have trouble with an
emission sphere replacing a Sun light_source in a scene. Whatever the
emission value, the scene remains fairly dark and no shadows seem to be
cast. Using UberPOV. What about this, Christoph?
Date: 24 Jun 2015 12:57:00
Message: <558ae15c$1@news.povray.org>
Apparently there is a name for this: It's called Parkinson's law.
Date: 24 Jun 2015 14:01:07
Message: <558af063@news.povray.org>
Am 24.06.2015 um 16:08 schrieb Thomas de Groot:
Using an emissive sphere instead of a light_source for the sun - while
being proper PBR - is not a good idea performance-wise: The sun is quite
small in the sky, and most rays will miss it. I suspect that's the
underlying cause for your problem.
If that is the case, and you want to stick with the emissive sphere, then:
- In the radiosity block, use a second parameter to the "count" keyword,
and make it huge; this will be the total number of directions the
radiosity algorithm will choose from, yet for each individual sample it
will only shoot as many of those as specified by the smaller parameter.
- In the radiosity block, increase the primary parameter to the "count"
keyword.
- On the command line, use a higher oversampling confidene ("-ac")
setting; this will force UberPOV to shoot more rays for any given pixel
before it thinks it has seen it all.
The emission setting for the sun should probably be somewhere in the 1e5
range.
Date: 24 Jun 2015 14:10:32
Message: <558af298@news.povray.org>
Am 24.06.2015 um 15:26 schrieb Mr:
That sounds like you're actually using them?
Don't worry - I'll leave them alone, as they do what they were designed
to do (which isn't much), and aren't in the way of anything better.
Iridescence was an entirely different beast: It was utterly broken.
