POV-Ray : Newsgroups : povray.off-topic : Interdimensional slices Server Time
22 Jun 2025 11:08:07 EDT (-0400)
  Interdimensional slices (Message 1 to 10 of 45)
Subject: Interdimensional slices
Date: 22 Jul 2013 16:48:18
Message: <op.w0m5epqbufxv4h@xena>
If you take a horzontal 2d slice of a human being near the center of the
torso, you will get 3 objects: 2 almost circular objects for the arms and
one ovalish shape for the torso. So if a 2d world could coincide with a 3d
world, a 2d being on that plane would see 3 objects and could not imagine
that it could be one object.
If we step it all up one dimension, you could have a 3-dimensional slice
of 4-dimensional object that would seem to be more than one 3d object to
us 3-dimensional beings.
Is this theoretically correct? Or am I missing something?
-Nekar Xenos-
Subject: Re: Interdimensional slices
Date: 22 Jul 2013 19:10:58
Message: <51edbc02$1@news.povray.org>
Am 22.07.2013 22:48, schrieb Nekar Xenos:
> and one ovalish shape for the torso. So if a 2d world could coincide
> with a 3d world, a 2d being on that plane would see 3 objects and could
> not imagine that it could be one object.
You've gotten it absolutely right.
Think of, for instance, three blobs that over time merge into one. That
/is/ a single object in 4D spacetime, but at any one moment we can only
see a 3D slice of it, with some of the slices looking as if it were
three separate objects.
Date: 23 Jul 2013 03:38:17
Message: <51ee32e9$1@news.povray.org>
Sounds correct to me - if you haven't already read Flatland then I
recommend it:
http://en.wikipedia.org/wiki/Flatland
Date: 23 Jul 2013 03:56:57
Message: <51ee3749$1@news.povray.org>
Nope, you're correct.
There are two main ways to transform a 4D object into something that our
3D senses can comprehend. One is to take a 3D slice out of the object
(which can obviously be done at different angles, and through different
points). The other is a "projection", rather like the way POV-Ray
transforms 3D scenes into 2D images. Like POV-Ray, you can do this two
ways - a perspective projection, and an orthographic projection.
Fun fact: If you slice off one corner of a cube, the new facet is
triangular. Similarly, if you slice off the corner of a hypercube, you
get a tetrahedron...
Date: 23 Jul 2013 09:29:01
Message: <51ee851d@news.povray.org>
It depends on whether you are seeing a slice or a projection.
Date: 23 Jul 2013 15:06:03
Message: <op.w0ovcbctufxv4h@xena>
> recommend it:
Very interesting. I will have to read it =)
-Nekar Xenos-
Date: 23 Jul 2013 15:06:57
Message: <op.w0ovduowufxv4h@xena>
>> and
>> 3d
>> imagine
Yes. In this case it is a slice.
-Nekar Xenos-
Date: 23 Jul 2013 16:06:39
Message: <op.w0ox49ezufxv4h@xena>
On Mon, 22 Jul 2013 22:48:15 +0200, Nekar Xenos <nek### [at] gmailcom>
wrote:
If we take a vertical 2D slice of a tin can we get a rectangle.
If we take a horizontal 2D slice of the same tin, we get a rectangle.
So if we have a special shape that I will call a 4D Cylinder when taking
3d slices we can get a sphere or a block depending on which direction it
is being sliced.
So a 4d entity would tell you that that specific sphere and block are the
same thing and any normal human being would think this 4d guy is just
plain crazy ;)
-Nekar Xenos-
Date: 23 Jul 2013 17:14:21
Message: <51eef22d@news.povray.org>
Am 23.07.2013 22:06, schrieb Nekar Xenos:
> is being sliced.
Somehow my intuition tells me that depending on how you construct your
4D cylinder you would either get (a) a sphere or a cylinder (by
extruding a 3D-sphere along the 4th dimension), or (b) a cylinder or a
box (by extruding a cylinder along the 4th dimension), but not what you
describe.
After all a sphere is curved in 2 dimensions, so in order to hide all
curvature you'd need 2 extra dimensions, i.e. a 5D space.
Date: 24 Jul 2013 03:33:31
Message: <51ef834b$1@news.povray.org>
> is being sliced.
You can do it purely from a mathematical point of view if you feel like
it - you can do isosurfaces right? :-)
3D:
A cylinder is x^2+y^2<1 and 0<z<1
If you fix z to 0.5 (your 2D plane) you get a circle.
If you fix x to 0 you get y^2<1 and 0<z<1 (ie a rectangle)
4D:
Try something like x^2+y^2+z^2<1 and 0<w<1
If you fix w=0.5 (your hyper-plane) you get a sphere
If you fix z=0 you get x^2+y^2<1 and 0<w<1 (ie a cylinder)
Or how about x^2+y^2<1 and 0<z<1 and 0<w<1
z=0.5 gives a cylidner
y=0 gives a 3D block
So as clipka says, I don't think there is any 4D shape you can define
that you can "hyper-slice" to get either a block or a sphere. But that
isn't exactly a proof - feel free to experiment, look forward to your
images in p.b.i :-)
