POV-Ray : Newsgroups : povray.off-topic : Interdimensional slices Server Time
5 Feb 2026 06:06:40 EST (-0500)
  Interdimensional slices (Message 21 to 30 of 45)
Subject: Re: Interdimensional slices
Date: 26 Jul 2013 03:36:37
Message: <51f22705$1@news.povray.org>
On 26/07/2013 05:16 AM, clipka wrote:
> String theory postulates that there are indeed - AFAIR - about half a
> dozen extra dimensions, and it is suggested that they may indeed all be
> curled up in this manner, with sizes roughly on the scale of sub-atomic
> particles.
More fully: Some formulations of string theory suggest that the universe
has as many as 11 spatial dimensions. The obvious question is then "so
why can't I see any of them?", and the only answer anybody has come up
with is "well, maybe they're really tiny..."
Date: 26 Jul 2013 06:35:45
Message: <51f25101@news.povray.org>
Nekar Xenos <nek### [at] gmailcom> wrote:
> I have heard it mentioned in scientific news that scientists have found
> the fourth dimension and measured it.
You are probably confusing it with something else.
Date: 26 Jul 2013 14:03:58
Message: <op.w0ucgtywufxv4h@xena>
On Fri, 26 Jul 2013 09:36:45 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
>> particles.
That one is easy. Simply because our eyes can only see in 2d. We can
perceive 3d images because of the stereoscopic effect of having 2 eyes.
I think it is possible that this universe itself may be 4d or even more
dimensions, but we can only perceive a 3d slice of it.
If a 4d being has only 2d and 3d "perceptors", how will it know that it is
4d?
-Nekar Xenos-
Date: 26 Jul 2013 14:05:44
Message: <op.w0ucjrtlufxv4h@xena>
On Fri, 26 Jul 2013 06:16:05 +0200, clipka <ano### [at] anonymousorg> wrote:
> Am 25.07.2013 19:24, schrieb Nekar Xenos:
>> Now for the part that I don't understand at all:
>> How can you measure a dimension? I don't understand that. If the 4th
>> dimension has a "thickness", what then is the thickness of the 3rd
>> dimension. It makes absolutely no sense to me at all.
> Those news actually make no sense for yet another reason: Scientists
> around the world should know better than to call a newly discovered
> dimension the "4th dimension", as the term is already firmly associated
> with time.
> But yes, there is some sense to measuring a dimension: Imagine the
> universe was made up of only one spacetime dimension, and one additional
> dimension curled up in a small loop; the universe would then have the
> shape of a cylinder surface stretching into infinity(*) along the
> spacetime dimension. But the other dimension would be finite, and could
> probably be measured.
> (*Alternatively, spacetime might also be finite, but on a much larger
> scale, in which case we'd get a torus surface.)
> particles.
It still doesn't make sense to me ...
-Nekar Xenos-
Date: 26 Jul 2013 14:14:57
Message: <op.w0ucy4fpufxv4h@xena>
It may be more dimensions and not just the 4th dimension.
-Nekar Xenos-
Date: 26 Jul 2013 15:46:52
Message: <51f2d22c$1@news.povray.org>
>> universe has as many as 11 spatial dimensions. The obvious question is
>> then "so why can't I see any of them?", and the only answer anybody
>> has come up with is "well, maybe they're really tiny..."
That doesn't explain why visible objects around us only move in 3
dimensions. If there were more dimensions and we should somehow only
"see" 3 of them, we should see objects constantly zipping into and out
of the 3D slice we can perceive.
Date: 26 Jul 2013 15:57:48
Message: <51f2d4bc$1@news.povray.org>
Why would they move in the other dimensions, if they are only moved in
our three or four?
What force would move them?
Regards
Date: 26 Jul 2013 16:58:35
Message: <51f2e2fb@news.povray.org>
> our three or four?
Why would they *not* move in the other dimensions? Why would all forces
just happen to be perpendicular to those dimension?
Date: 26 Jul 2013 17:42:25
Message: <51f2ed41$1@news.povray.org>
I thought I had said, why would a force be applied to them?
If they are dimensions that not much happens in.
Regards
Date: 26 Jul 2013 18:43:51
Message: <51f2fba7@news.povray.org>
Perceiving three-dimensional space is not related to stereoscopic vision.
It helps, but it isn't what makes it three-dimensional perception.
Talking about slices is, as I see it, nonsensical. A camera doesn't see
a "slice" of the three-dimensional space. It sees a *projection*, which
is a completely different thing. If there were a fourth dimension that's
like the other three, we would likewise see a three-dimensional projection
of it, not a slice.
Anyway, according to general relativity, spacetime *is* four-dimensional,
and everything actually moves in the fourth dimension all the time.
Moreover, the reason why gravity (seemingly) accelerates objects is
because of this movement in 4-dimensional spacetime. (The spacetime is
curved, which is what causes the apparent acceleration. In reality it's
not acceleration but inertia.)
So, technically speaking, when you drop an object, you are seeing movement
in the fourth dimension (or, more precisely, the effects of the curvature
of spacetime, from which we see a 3-dimensional projection, which is what
causes us to perceive it as accelerating motion, even though in reality
it's just inertial motion. It's a similar idea as how a railroad seems
to converge at the horizon in a photograph.)
