POV-Ray : Newsgroups : povray.off-topic : Interdimensional slices Server Time
18 Dec 2025 19:35:41 EST (-0500)
  Interdimensional slices (Message 16 to 25 of 45)
Subject: Re: Interdimensional slices
Date: 25 Jul 2013 03:11:03
Message: <51f0cf87$1@news.povray.org>
> So shifting the dimensions up we get a cube on the first 3d section of
> this "4d table leg" with each cube being curved more than the previous
> and the last 3d section is a perfect sphere.
FWIW I think an equation for such an object might be:
x^(1/w) + y^(1/w) + z^(1/w) < 1 and 0 < w <= 0.5
Date: 25 Jul 2013 13:21:47
Message: <op.w0sfuhb6ufxv4h@xena>
Ingenius! =)
I will give that a try. I want to make an image that will depict how a 4
dimensional object can look totally different depending on where it is
sliced.
-Nekar Xenos-
Date: 25 Jul 2013 13:24:36
Message: <op.w0sfy7hkufxv4h@xena>
Now for the part that I don't understand at all:
I have heard it mentioned in scientific news that scientists have found
the fourth dimension and measured it.
How can you measure a dimension? I don't understand that. If the 4th
dimension has a "thickness", what then is the thickness of the 3rd
dimension. It makes absolutely no sense to me at all.
-Nekar Xenos-
Date: 26 Jul 2013 00:16:16
Message: <51f1f810@news.povray.org>
Am 25.07.2013 19:24, schrieb Nekar Xenos:
Those news actually make no sense for yet another reason: Scientists
around the world should know better than to call a newly discovered
dimension the "4th dimension", as the term is already firmly associated
with time.
But yes, there is some sense to measuring a dimension: Imagine the
universe was made up of only one spacetime dimension, and one additional
dimension curled up in a small loop; the universe would then have the
shape of a cylinder surface stretching into infinity(*) along the
spacetime dimension. But the other dimension would be finite, and could
probably be measured.
(*Alternatively, spacetime might also be finite, but on a much larger
scale, in which case we'd get a torus surface.)
String theory postulates that there are indeed - AFAIR - about half a
dozen extra dimensions, and it is suggested that they may indeed all be
curled up in this manner, with sizes roughly on the scale of sub-atomic
particles.
Date: 26 Jul 2013 02:50:21
Message: <51f21c2d$1@news.povray.org>
> Ingenius! =)
Thinking about it, there should probably be a modulus function around
x,y,z (to get the absolute value), otherwise x=-5,y=5,z=0,w=0.2 is part
of the solid (which it shouldn't be).
> sliced.
Slicing it along one of the coordinate axes will be easy, the hard (and
more interesting) bit will be taking angled slices :-)
Date: 26 Jul 2013 03:36:37
Message: <51f22705$1@news.povray.org>
> particles.
More fully: Some formulations of string theory suggest that the universe
has as many as 11 spatial dimensions. The obvious question is then "so
why can't I see any of them?", and the only answer anybody has come up
with is "well, maybe they're really tiny..."
Date: 26 Jul 2013 06:35:45
Message: <51f25101@news.povray.org>
You are probably confusing it with something else.
Date: 26 Jul 2013 14:03:58
Message: <op.w0ucgtywufxv4h@xena>
On Fri, 26 Jul 2013 09:36:45 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
>> particles.
That one is easy. Simply because our eyes can only see in 2d. We can
perceive 3d images because of the stereoscopic effect of having 2 eyes.
I think it is possible that this universe itself may be 4d or even more
dimensions, but we can only perceive a 3d slice of it.
If a 4d being has only 2d and 3d "perceptors", how will it know that it is
4d?
-Nekar Xenos-
Date: 26 Jul 2013 14:05:44
Message: <op.w0ucjrtlufxv4h@xena>
> with time.
> particles.
It still doesn't make sense to me ...
-Nekar Xenos-
Date: 26 Jul 2013 14:14:57
Message: <op.w0ucy4fpufxv4h@xena>
It may be more dimensions and not just the 4th dimension.
-Nekar Xenos-
