POV-Ray : Newsgroups : povray.off-topic : Real or Render? Server Time
11 Sep 2025 19:06:21 EDT (-0400)
  Real or Render? (Message 21 to 28 of 28)
Subject: Re: Real or Render?
Date: 24 May 2011 12:32:03
Message: <4ddbdd82@news.povray.org>
Jim Henderson <nos### [at] nospamcom> wrote:
> Now in terms of the OP, the size of the moon in the image is physically
> impossible compared to the size of the sun.  There is no place on the
> Earth that the moon will photograph as that large without some sort of
> photo trickery.  None - absolutely NONE.
  As I said in my post, it's perfectly possible to make a photo of the
Moon so that it looks enormous compared to the details on the ground.
Just use a really strong zoom.
  Of course to get the ground details and the Moon on the same photo with
such a strong zoom the Moon has to be very close to the horizon, and the
ground details very far away from the photographer. If the Moon is higher
on the sky then it becomes impossible (because you can zoom either to the
Moon or to the horizon, not both).
  And of course if the Sun were visible as well, that would look much
bigger as well (about the same size as the Moon), for the same reason.
Date: 24 May 2011 13:39:31
Message: <4ddbed53@news.povray.org>
There would be artifacts, stretching, or *something* that made it obvious
it was faked using optics.
>   with
> higher on the sky then it becomes impossible (because you can zoom
> either to the Moon or to the horizon, not both).
Exactly.
Date: 24 May 2011 14:39:39
Message: <4ddbfb6b@news.povray.org>
  Faked? Faked compared to what? What is a "normal" zoom level?
  Is the image shown by a microscope "faked"? How about an image taken by
Hubble? Is that "faked" as well? What's the difference?
Date: 24 May 2011 14:52:04
Message: <4ddbfe54$1@news.povray.org>
>> >   the
>> obvious it was faked using optics.
Composited or put together using some sort of optical trickery.
>   by
No, because those images aren't trying to be "realistic".  (Arguably,
some of the pictures from Hubble are 'fake' in that they show non-visible
wavelengths using visible wavelengths, but they don't try to pass them
off as being anything other than a composite with visual representations
of things that you wouldn't actually 'see' with your eyes).
Jim
Date: 28 May 2011 08:12:50
Message: <4de0e6c2@news.povray.org>
> >> >   the
  How is zooming towards the horizon "composited or put together"?
Date: 28 May 2011 10:35:01
Message: <4de10815$1@news.povray.org>
>> >> >   the
>> >> > ground. Just use a really strong zoom.
If it were done optically, there'd be some kind of artifact.  You
wouldn't get that from just a standard zoom setting on a camera - not
with that extent of exaggeration in the moon without having the sun also
exaggerated.
Jim
Date: 28 May 2011 11:23:20
Message: <4de11366@news.povray.org>
> >> >> >   the
> exaggerated.
  Perhaps you should read again what I wrote? Nowhere did I say that you
could get the image referenced in the original post with zooming. (On the
contrary, I explicitly said that if you get an enlarged moon by zooming,
the sun would also be equally enlarged.)
Date: 29 May 2011 14:45:17
Message: <4de2943d$1@news.povray.org>
I understood what you wrote; you didn't understand what I wrote,
apparently, and I've been trying to explain it.  Apparently not well
enough.  Oh well.
Jim
