I acquired this interesting device as part of a lot of tools (in every sense of
the words) and have yet to determine how it is used.
It is labeled "mechanical solution of spherical triangles"
And search as I might, I have found nothing on the interwebs that shows a
similar device or explains how it might be used.
The attachments are simply clamped onto the edge, like a caliper.
I have no idea if there were any more parts intended to go along with it.
Does anyone have any ideas?
Download 'device.gif' (1928 KB)
Preview of image 'device.gif'
Am 11.06.26 um 12:51 schrieb Bald Eagle:
I googled the words on the note attached and came up with the hint to a
nautrigon:
https://www.abebooks.com/first-edition/Description-Nautrigon-Directions-Use-Instrument-Solving/588224941/bd#&gid=1&pid=1
Best regards
Michael
> nautrigon:
d=1
Ooooh - you had more luck than I did, and that is a VERY good lead.
Obviously there's a LOT more to this device than what I got. Now I just need a
good picture of it, and a fairly through description of how to use it.
I did find "On an Instrument for Solving Spherical Triangles". but it would be
more comprehensible with a diagram to accompany it.
THANKS! :)
- BW
Am 11.06.26 um 23:40 schrieb Bald Eagle:
>> nautrigon:
> d=1
> THANKS! :)
> - BW
After taking another closer look at the image from the link above this
morning, I no longer believe that your device is part of a Nautrigon,
because the Nautrigon shown in the image does not appear to have any
circular segments covering more than 180 degrees. That was an
interesting lead, but unfortunately, it was probably the wrong track.
However, I haven’t found any other sources on the Nautrigon, and the
original publication is a bit too expensive for me just to satisfy my
curiosity.
Best regards
Michael
> > nautrigon:
pi
> d=1
> THANKS! :)
> - BW
You might have a look at the link below
https://www.usni.org/magazines/proceedings/1878/december/brief-account-progress-art-navigation
and search for 'OTHER DEVICES'. No manual how to use that thing but a hint for
what is was designed.
Droj
