POV-Ray : Newsgroups : povray.off-topic : Nope, I STILL don't understand git branches Server Time
12 May 2026 19:31:15 EDT (-0400)
  Nope, I STILL don't understand git branches (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Nope, I STILL don't understand git branches
Date: 23 Jan 2026 09:46:12
Message: <697389b4$1@news.povray.org>
On Fri, 23 Jan 2026 00:25:24 -0400, Cousin Ricky wrote:
> On 2026-01-22 22:38 (-4), Shay wrote:
>> Cousin Ricky <ric### [at] yahoocom> wrote:
>>> I created a branch, made some changes there, then switched back to the
>>> main branch, and the changes were also in that branch as well.  Why
>>> did the changes apply to both branches?  What am I missing?
>>> Most baffling is that I got branches to work just 3 weeks ago.  I
>>> don't know what I did differently.
>> 90% chance you created a branch with `git branch` but then never
>> checked it out.
>> Create a branch with `git checkout -b new-branch` to do both at the
>> same time.
> Nope, that wasn't it.  It still changes both branches at the same time.
I might be mistaken (it's WAY to early in the morning for me to be
thinking about this), but if the file isn't added to the repo and just
lives within the directory, then I don't think any changes get tracked,
and this is the behavior you would probably see.
Make sure you use `git add <filename>` for anything you want change
tracking enabled.
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 23 Jan 2026 19:20:00
Message: <web.69740f24461f9d4efe29df036830a892@news.povray.org>
> >> checked it out.
> >> same time.
> tracking enabled.
Also I don't know how bad you feel about using GUI, but I love Git-Cola for
spotting that kind of issue.
Date: 24 Jan 2026 12:30:00
Message: <web.6975009e461f9d4e95258fa76f35e431@news.povray.org>
> tracking enabled.
Yes, this was my first thought - you need to commit your changes to the current
branch or nothing gets tracked. Use 'git add <...>' to stage the changes, 'git
commit' to commit them.
Bill
Date: 24 Jan 2026 16:10:21
Message: <6975353d$1@news.povray.org>
> current branch or nothing gets tracked. Use 'git add <...>' to stage the
> changes, 'git commit' to commit them.
IIRC, 'git status' will show if that's the case, as it shows untracked
files.
Date: 24 Jan 2026 17:40:00
Message: <web.69754a1a461f9d4e95258fa76f35e431@news.povray.org>
> files.
Yep, 'git status' with no other args will list staged files, changed tracked
files and untracked files in separate sections.
This scenario sounds like there would just be items in the 'changes' section,
since these are changes to tracked files. A newly added file would appear in
untracked files.
Bill
Date: 24 Jan 2026 20:13:06
Message: <69756e22$1@news.povray.org>
> tracking enabled.
No, the files are definitely part of the repo.
Date: 24 Jan 2026 20:21:02
Message: <69756ffe$1@news.povray.org>
>> tracking enabled.
Git-Cola has been wonderful, and it works seemlessly with the CLI.  But
the files in question *are* being tracked.
Date: 24 Jan 2026 20:29:19
Message: <697571ef$1@news.povray.org>
Are you saying that changes will show up in *all* branches until they're
committed to *one* of the branches?
Date: 24 Jan 2026 20:53:12
Message: <69757788$1@news.povray.org>
>> the changes, 'git commit' to commit them.
Technically, they don't show up in any branch because the file isn't
tracked.  If a file isn't tracked, it exists outside git's "system", and
the file will appear the same in all branches (but it's not in any of
them.  If you wipe the directory and then do a git pull, the file won't be
there at all).
Date: 24 Jan 2026 20:56:23
Message: <69757847$1@news.povray.org>
>> tracking enabled.
Do you see them in `git status`?
If you see something like this:
$ git status
On branch electron
Your branch is up to date with 'origin/electron'.
Untracked files:
  (use "git add <file>..." to include in what will be committed)
	package-lock.json
nothing added to commit but untracked files present (use "git add" to
track)
Then the file isn't part of the repo (in this case, package-lock.json
isn't part of the repo I was checking). That would be consistent with what
you're seeing.
Jim
