POV-Ray : Newsgroups : povray.off-topic : Raysnail 0.1.2 Server Time
6 Sep 2024 21:19:02 EDT (-0400)
  Raysnail 0.1.2 (Message 1 to 3 of 3)
Subject: Raysnail 0.1.2
Date: 25 Jul 2024 11:36:15
Message: <66a270ef$1@news.povray.org>
I've been working some more on the raysnail, lots of basic
infrastructure to do, little to show. I could extend the compatibility
with PovRay scene files a little bit, CSG intersections and differences
are supported now, even if only with two objects each.
The translate operation should work, rotate only for the y axis (the
other two axes soon to be supported too).
The parser now supports finish blocks, but only reads the reflection
item from it, the basic variant with just a float.
The attached render was created with this SDL file:
https://github.com/Varkalandar/raysnail/blob/72908892fba87898477324814a5515207d8b8755/sdl/csg.sdl
Download 'csg_sample_scene.jpg' (87 KB)
Preview of image 'csg_sample_scene.jpg'
Subject: Re: Raysnail 0.1.2
Date: 29 Jul 2024 14:58:26
Message: <66a7e652@news.povray.org>
... it now supports PovRay SDL syntax to translate, rotate and scale
objects, and the 10 parameter quadric object type. I still have to work
on regular cone and cylinder SDL support.
Download 'sdl_quadrics.jpg' (123 KB)
Preview of image 'sdl_quadrics.jpg'
Date: 7 Aug 2024 16:10:03
Message: <66b3d49b@news.povray.org>
And again, some more work done. The raysnail got better at
transformations and CSG operations, and it now also supports PovRay SDL
#declare and #while directives. One cannot #declare everything yet, that
PovRay allows, but scalar values, vectors and object definitions are
supported now.
Attached, there an example of a while loop. It was created by this SDL file:
https://github.com/Varkalandar/raysnail/blob/a2e24b1845f6686684b5e08b5e0106648b7aa7b0/sdl/declares.sdl
While I'm quite happy with the results, I think there is still about 90%
missing to really render existing PovRay scenes with the raysnail.
Download 'declares_and_loop.jpg' (138 KB)
Preview of image 'declares_and_loop.jpg'
