POV-Ray : Newsgroups : povray.off-topic : Re: Tales from a Renderfarm Server Time
6 Sep 2024 21:23:18 EDT (-0400)
  Re: Tales from a Renderfarm (Message 1 to 8 of 8)
Subject: Re: Tales from a Renderfarm
Date: 20 Sep 2018 23:35:33
Message: <5ba46705$1@news.povray.org>
On 09/08/2018 09:07 AM, dick balaska wrote:
> Now if the vpn dies, the queued frames keep chugging, and if a machine
> reboots he just restarts and goes. yay.
Ah, computers...
The bsacs service (renderfarm server) fails to launch povrayws on reboot.
If I stop/start it by hand, it works.
If I upgrade, the system stops, upgrades, and starts the service correctly.
But on reboot, no.  wtf.
dik
Rendered 1024 of 921600 pixels (0%)
Date: 21 Sep 2018 02:08:53
Message: <5ba48af5$1@news.povray.org>
> Ah, computers...
violent shutdown for reboot have a trend to leave some files behind them
which make the system believe the process is already running.
Typical wtf:
1. the start process write the psid in a file
2. on clean shutdown, file with psid is deleted
3. system upgrades cleanly stop all processes before restart (see 2)
4. on power-reboot, file with psid exist, so the system is happy and do
nothing.
The basic solution is that the psid in the file should also be checked
to see:
1. Is such psid currently in use (does the process exist)
2. Is such process matching the command that is associated with the file
(collisions on psid can occurs, there is only 65535 id, and they get reused)
Especially after a power-reboot, in which more processes are forked at
start to check the disks, so another service can now use the psid logged
in the file in the previous session.
When you forget point 2, you get problem, randomly.
Date: 21 Sep 2018 03:32:06
Message: <5ba49e76$1@news.povray.org>
> Ah, computers...
How big is the farm?
Mike
Date: 21 Sep 2018 11:43:25
Message: <5ba5119d$1@news.povray.org>
5 nodes. http://www.buckosoft.com/bsac/meta/ click the "Servers" tab.
> Mike
dik
Date: 21 Sep 2018 21:48:22
Message: <5ba59f66$1@news.povray.org>
>> Mike
OMG what happened to Elvis and Emma?! Are they okay?
Mike
Date: 22 Sep 2018 02:16:03
Message: <5ba5de23$1@news.povray.org>
Elvis died of heat exhaustion. joe is his replacement (my buddy's linux
server).  Emma has been retired.  She was my firewall/tunnel/dns/dhcp
server and has been replaced with a Raspberry Pi. (5 watts vs. 250 watts).
dik
Date: 22 Sep 2018 04:11:09
Message: <5ba5f91d$1@news.povray.org>
On the toilet?  ;)
Regards
Date: 30 Sep 2018 06:33:24
Message: <5bb0a674$1@news.povray.org>
> Typical wtf:
> nothing.
> to see:
> reused)
This was the problem, but sideways.
For about 6 years, Debian mounts /var/run as a tmpfs so it is always
empty on boot.  This was done specifically to solve the problem you mention.
On install, I created /var/run/bsac (chown bsac:bsac) because I can't
write to root owned /var/run. The solution was to check for
/var/run/bsac at service startup and create as needed.
dik
