POV-Ray : Newsgroups : povray.off-topic : WebGL Server Time
1 Sep 2024 09:19:35 EDT (-0400)
  WebGL (Message 1 to 10 of 28)
Subject: WebGL
Date: 5 Jun 2016 10:05:26
Message: <575431a6$1@news.povray.org>
Hey guys. Remember this?
http://madebyevan.com/webgl-path-tracing/
Yeah, well now there's this:
http://jonathan-olson.com/tesserace/tests/3d.html
Firstly, it looks a bit less like a computer simulation and more like
the Real World. Only a bit, but hey.
My favourite feature is that you can adjust the lens aperture and focus
distance. I was just wondering whether you could accurately simulate
depth of field using path tracing! Now we just need to be able to change
the focal length of the lens too... (There are also options for
adjusting the exposure.)
For a camera nerd, this is quite fun! (Well, it beats Nikon's "lens
simulator", which just shows a static JPEG with variable magnification!)
Sometimes I really wish I knew how to do this stuff for myself...
What *would* be interesting is to see how this handles a scene of
non-trivial complexity. I'm going to say "like a glacier"...
Subject: Re: WebGL
Date: 5 Jun 2016 10:11:27
Message: <5754330f$1@news.povray.org>
...well, there is this:
http://reindernijhoff.net/2015/04/realtime-webgl-path-tracer/
Granted, it's grainy as *hell*, but at a tiny resolution it's watchable.
Maybe give it ten years, and the GPU will have enough horsepower for
people to actually put this stuff in game engines.
Maybe.
Subject: Re: WebGL
Date: 6 Jun 2016 08:36:10
Message: <57556e3a@news.povray.org>
Follow a tutorial on WebGL - or if you want to skip all the html/js
boilerplate stuff you'll need to know, go straight to something like
shadertoy. There are plenty of examples, and shadertoy now supports
reading back pixels from previous frames, so you can do
multi-frame-averaging for path-tracing amongst other effects.
Building a lens simulator (with real-time path-traced results) sounds
feasible and very interesting.
Subject: Re: WebGL
Date: 8 Jun 2016 13:06:27
Message: <57585093$1@news.povray.org>
Well, I went to the ShaderToy website... and discovered that apparently
Opera has WebGL support that's flaky as *hell*! The number of times I
have to close and reopen the browser to turn WebGL back on...
Some of the shaders on offer are absurd. I saw one that was a real-time
simulation of waves crashing on a giant sea... fractal wave
distribution, subsurface scattering, specular highlights... and wondered
why the hell they don't put this in games yet!
But mostly, attempting to browse the shaders just broke Opera.
After about an hour of squinting at the sparse ShaderToy documentation
and making some educated guesses, I did eventually manage to build a
trivial ray-tracer that runs in real-time. I have no idea how to do
random number generation yet, but we'll see...
Subject: Re: WebGL
Date: 9 Jun 2016 03:11:22
Message: <5759169a$1@news.povray.org>
Come on, make it public and post the link then for all to see :-)
I had a bit more of a think about how you might do a lens simulation.
You start by firing the ray from a random point within the pixel on the
sensor, and fire it at a random point on the surface of the first lens
element. Then follow that ray through the lenses (assume no reflection
for speed here), if it gets too far from the lens axis then return
black, otherwise once it gets out of the end of the lenses and into the
scene do the raytrace as normal.
With the above you should be able to move about individual lens elements
in almost real time (it might take a second or two to smooth out the noise).
Yes that is tricky, but I'm sure you've already looked at other shaders
there to see how they do it. Something involving the sine of the
coordinates multiplied by some huge value IIRC.
Subject: Re: WebGL
Date: 9 Jun 2016 13:53:43
Message: <5759ad27$1@news.povray.org>
I'm sure you've all seen a white sphere with some coloured lights. :-P
> noise).
That sounds quite complex. (In particular, it seems to require me to
actually design a real lens assembly, and implement real refraction.)
I was thinking more along the lines of a camera entity that fires rays
in a pattern that matches a theoretical ideal lens. But I need to figure
out the equations for that first...
Yeah, not just a random number per pixel, but *multiple* random numbers!
Multiple, statistically-independent numbers... This is not trivial.
Subject: Re: WebGL
Date: 9 Jun 2016 14:00:16
Message: <5759aeb0$1@news.povray.org>
Yesterday I had another go at this, and hit a show-stopping snag: No
flow control.
It seems that implementing reflection is essentially impossible. You
can't do recursive functions. You can't do arrays. [Well, you can... but
the array indices must be known at compile-time, thus negating all
possible advantages of arrays.] You can't do while-loops with
complicated break or continue conditions. You can't do function
pointers... In short, it seems that all code jumps and data accesses
must be statically known at compile-time.
Obviously, the rendering equation is inherently recursive. You fire a
ray, which spawns further rays with are recursively traced like the
first one. But without the ability to dynamically trace different
primitives differently, or apply different surface characteristics
dynamically, or basically do *anything* dynamically... You end up
basically needing to write some kind of engine to *generate* the WebGL
code, hard-coded to the particular geometry of your scene.
I see now why no computer game will ever use this technology. It's fast
because it's *completely inflexible*.
I am now baffled as to how all the *other* people managed to do so much
cool stuff in a language that abhors conditional branching... Clearly
I'm going to have to cheat and look at the source code. But I fear I
won't be able to comprehend any of it.
In summary, it appears that implementing reflection is mathematically
impossible. I may perhaps still be able to realise my dream of rendering
depth of field effects realistically. (Although without a nice detailed
scene to look at, it might be rather disappointing...)
Subject: Re: WebGL
Date: 9 Jun 2016 14:46:06
Message: <5759b96e$1@news.povray.org>
OK, here ya go:
struct Ray
     vec3 S, D;
vec3 RayPoint(in Ray ray, in float t)
     return ray.S + ray.D*t;
Ray Camera(in vec2 uv)
     Ray ray;
     ray.S = vec3(0, 0, -5);
     ray.D = vec3(uv.x, uv.y, 1);
     return ray;
struct Sphere
     vec3 C;
     float R;
     float R2;
Sphere MakeSphere(vec3 center, float radius)
     return Sphere(center, radius, radius*radius);
float IsectSphere(in Ray ray, in Sphere sphere)
     // (P - C)^2 = r^2
     // (P - C)^2 - r^2 = 0
     // ((Dt + S) - C)^2 - r^2 = 0
     // (Dt + S - C)^2 - r^2 = 0
     // (Dt + V)^2 - r^2 = 0
     // D^2 t^2 + 2DVt + V^2 - r^2 = 0
     vec3 V = ray.S - sphere.C;
     float a = dot(ray.D, ray.D);
     float b = 2.0*dot(V, ray.D);
     float c = dot(V, V) - sphere.R2;
     float det = b*b - 4.0*a*c;
     if (det >= 0.0)
         return (0.0 - b - sqrt(det))/(2.0*a);
     else
         return -1.0;
float Illuminate(vec3 light, vec3 surface, vec3 normal)
     vec3 d = light - surface;
     return dot(normalize(d), normalize(normal));
vec2 MapScreen(vec2 xy)
     return (xy - iResolution.xy/2.0) / iResolution.y;
vec2 MapScreenExact(vec2 xy)
     return (xy - iResolution.xy/2.0) / iResolution.xy;
void mainImage( out vec4 fragColor, in vec2 fragCoord )
     Sphere s1 = MakeSphere(vec3(MapScreenExact(iMouse.xy)*4.0, 0), 1.0);
     vec3 l1 = vec3(-5, +5, -3); // Red
     vec3 l2 = vec3(+5, +5, -3); // Green
     vec3 l3 = vec3( 0, -5, -3); // Blue
     Ray cr = Camera(MapScreen(fragCoord.xy));
     float t = IsectSphere(cr, s1);
     if (t > 0.0)
         vec3 surface = RayPoint(cr, t);
         vec3 normal = surface - s1.C;
         float b1 = Illuminate(l1, surface, normal);
         float b2 = Illuminate(l2, surface, normal);
         float b3 = Illuminate(l3, surface, normal);
         fragColor = vec4(b1, b2, b3, 1);
     else
         fragColor = vec4(0, 0, 0, 0);
Copy & paste into the ShaderToy website and hit Go. You can click on the
image to move the sphere around. (It doesn't follow your cursor exactly
because of the perspective transformation.)
Subject: Re: WebGL
Date: 10 Jun 2016 02:59:11
Message: <575a653f$1@news.povray.org>
Obviously it's not, because there are plenty of shadertoy examples
showing it:
https://www.shadertoy.com/view/4ssGWX
Surfaces that reflect *OR* refract are trivial:
for(i=0;i<MAX_TRACE_DEPTH;i++)
   intersect = Trace( ray );
   if( REFLECT(intersect) ) ray = ReflectRay(ray , intersect);
   if( REFRACT(intersect) ) ray = RefractRay(ray , intersect);
To do surfaces that do both you need to choose randomly at each
intersection which ray to follow (weighted appropriately depending on
the material) and then average over a larger number of samples. You can
either do many samples per frame (but obviously this gets slow for
complex scenes), or what is commonly done is to average over many frames
(and reset the average if the camera is moved). Or both.
Subject: Re: WebGL
Date: 10 Jun 2016 03:23:54
Message: <575a6b0a@news.povray.org>
> showing it:
Interesting. On my browser, that just crashes.
The difficulty is figuring out what surface was hit just from the
intersection coordinates. And perhaps a perfect reflection isn't so
hard, but I wanted to have the colour change slightly on each
reflection... but I can't figure out how to stack up the colour changes
until you get to the end of the reflection chain, and then unstack them
again.
Still trying to work out how you "average over several frames".
ShaderToy is great fun, but so *utterly* undocumented... it's quite hard
to figure out how to do anything.
