POV-Ray : Newsgroups : povray.off-topic : Make it Server Time
13 May 2026 01:48:36 EDT (-0400)
  Make it (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Make it
Date: 27 May 2016 09:23:51
Message: <57484a67@news.povray.org>
>>> I can't believe I've just spent an entire day writing Makefiles... At
>>> this rate, it would almost be simpler to just write a loop to compile
>>> every source file in every directory and then link them all! But, alas,
>>> it turns out that you have to actually link them in the right order, or
>>> it doesn't work.
>> Isn't there some tool to do that automatically?
> Absolutely. It is called "make", and needs a Makefile to work ;)
Oh, what you can use make to make a makefile? Sounds like some IOCCC
entry...
Date: 27 May 2016 11:10:25
Message: <57486361$1@news.povray.org>
Am 2016-05-27 08:39, also sprach clipka:
> Am 27.05.2016 um 12:31 schrieb scott:
>>> it doesn't work.
It's weird that in 2016 a 1980s program is still in charge of assembling
large swaths of code. Ant /tried/ to take over, but that's even worse.
dik
Date: 27 May 2016 11:37:03
Message: <5748699f$1@news.povray.org>
>>> it doesn't work.
Actually you can ask gcc/g++ to output the dependencies on sources files. Then you can
have them read back by "make".
Date: 27 May 2016 13:51:27
Message: <5748891f$1@news.povray.org>
On 26/05/2016 08:28 PM, Le_Forgeron wrote:
> Le 26/05/2016 20:11, Orchid Win7 v1 a écrit :
>> I also enjoy how if you try to link an executable, it whines about unresolved
symbols, but if you link an SO file, it's NOT considered an error to have missed half
of the necessary object files... (!)
> Shared lib (.so) are allowed to be completed later by other libs, or even the
loading binary.
Presumably this requires the executable to load everything in exactly
the right order though?
> It's at runtime that you will get your problems.
Indeed. This is what I feared... So at some point, when the program is
running, it will suddenly segfault for no apparent reason, and it will
be mathematically impossible to ever determine why. Great.
Date: 27 May 2016 13:52:58
Message: <5748897a$1@news.povray.org>
On 26/05/2016 08:31 PM, Le_Forgeron wrote:
> Another trick against the "right order" of linking: put everything but the main in a
single archive library ( .a ).
> Then compile the main source into a binary with the library on the command line.
Heh, don't even get me started on archive files!
I had the "brilliant idea" of turning each folder into an archive, and
then linking those together. Trouble is... it only works 95% of the
time. About 5% of the time, the resulting object behaves differently
(i.e., wrong). GTest in particular seems to not like it. I have no idea why.
I stripped all traces of .a files out of the Makefile, and half my
problems went away...
Date: 27 May 2016 13:53:24
Message: <57488994$1@news.povray.org>
>>> it doesn't work.
LMAO! :-D
Date: 27 May 2016 13:54:48
Message: <574889e8$1@news.povray.org>
> entry...
Weirdly, Make actually has implicit rules for how to make the Makefile
itself... If you run it in debug mode, you can see it "considering"
whether your Makefile is up-to-date or not.
I have no idea what these rules *are*, mind you... Perhaps it's looking
for a Makefile.am to run AutoMake on or something?
Date: 27 May 2016 13:56:26
Message: <57488a4a$1@news.povray.org>
Make is a nice *concept*... sadly, the *implementation* leaves something
to be desired.
(I want to find the person who decided to use tabs as part of the
language syntax and BEAT HIM TO DEATH! >_< My text editor is rightly
configured to strip all tabs and turn them to spaces, but then noooo...
As soon as you want to edit a Makefile, you have to turn that off.)
Date: 27 May 2016 13:59:34
Message: <57488b06$1@news.povray.org>
can have them read back by "make".
Yes, this is the main thing I did.
Originally, the Makefile had one entry for every source file in the
entire project, some (but not all) listing the header files they depend
on. (Hey, at least the exact compilation command was a variable!)
I replaced that with a rule that says how to build any object file from
a source file. That crunched the file size down to a fraction of its
former self. I also made G++ spit out dependency information that then
gets included back into the Makefile. Our CI server probably won't care,
but it'll help the next poor sod who tries to build it by hand.
Finally, I wrote some crazy Make macro [yes, Make has macros] that
generates a list of all the object files in a folder. Before they exist.
So that I can depend on them.
...and then I did it all over again, since apparently SO files have to
be built with -fPIC, whatever that does...
Date: 27 May 2016 14:09:35
Message: <57488d5f$1@news.povray.org>
hi,
'make -p' dumps default rules & vars.   'info make' is your friend.
jr.
