POV-Ray : Newsgroups : povray.off-topic : Semantics? Server Time
10 Oct 2024 11:18:13 EDT (-0400)
  Semantics? (Message 1 to 10 of 32)
Subject: Semantics?
Date: 1 Sep 2015 03:06:18
Message: <55e54e6a$1@news.povray.org>
Coming up often and just noted that again in Ger's answer in the thread
above.
What is the meaning of percentages higher than 100? I don't get it.
If my bottle of wine is considered 100% full, what would be 200%? Two
bottles of wine? :-)
Subject: Re: Semantics?
Date: 1 Sep 2015 05:32:34
Message: <55e570b2@news.povray.org>
> above.
The answer is pretty simple.
If 1 (one) core is working on povray that would be 100% load. If 2 cores are
working on povray that would be 2 x 100%. So, in my case that would be 8
cores, each working at (or close to) 100%, so 800%.
The percentage load is taken from the "1 core" or "1 proc" view.
Ger
Date: 1 Sep 2015 07:38:34
Message: <55e58e3a$1@news.povray.org>
>> above.
OK. I missed the 8 cores obviously. it makes sense, but
Still, I feel uncomfortable with the notion itself and would rather
think that povray is rendering at 100%, divided over 8 cores... each
working at 100%... for me, that does not add up to 800%, only to faster
rendering, which is why I guess this is a semantic question.
Date: 1 Sep 2015 09:24:34
Message: <55e5a712$1@news.povray.org>
Yes, typically % is defined as % of some (obvious) maximum. Defining CPU
load as a % of only 1 core being fully loaded seems a bit
counter-intuitive. But so long as everyone is aware of this, and they
know exactly how many cores are in the CPU then it shouldn't be a huge
problem. If we didn't know there were 8 cores, 800% could mean anything.
Also, in general, when you combine percentages from various bits you
need to sum the numerators and denominators separately, otherwise you
get a wrong result.
eg
Bag 1 has 6 apples out of space for 10 : 6/10 = 60% full
Bag 2 has 3 apples out of space for 4  : 3/4  = 75% full
Combined there are 9 apples out of space for 14, so 64% full. NOT 135% full!
Date: 2 Sep 2015 03:15:19
Message: <55e6a207$1@news.povray.org>
> get a wrong result.
> eg
> full!
Thanks indeed. That sums it up nicely :-)
The case of Ger's which triggered my thread is pretty obvious and
acceptable in the context. However, the misuse nowadays in all kinds of
situations seems to be growing and can be pretty annoying sometimes.
Date: 2 Sep 2015 06:35:58
Message: <55e6d10e$1@news.povray.org>
Yes, whenever an athlete/sportsperson says they "gave it 110%" they
should be immediately investigated for doping :-)
Date: 2 Sep 2015 07:20:23
Message: <55e6db77$1@news.povray.org>
That's a fair assumption indeed ;-)
Date: 2 Sep 2015 10:22:12
Message: <55e70614$1@news.povray.org>
Am 02.09.2015 um 09:15 schrieb Thomas de Groot:
I think there are plenty of cases where values >100% are perfectly ok,
such as:
"This year, our budget has increased by 250% [compared to last year]."
"Let's see for how long we can push the engine to 120% [nominal] thrust."
"This amplifier has a gain of 420%."
"This telescope rod can extend to 550% [of its retracted length]."
Date: 3 Sep 2015 02:42:04
Message: <55e7ebbc@news.povray.org>
Reminds me of my last company, where the profit was always hovering
around zero (and sometimes negative). The column "profit compared to
last year" was always an amusing one, it could be 1000000% or negative,
or the year after a negative amount they didn't know what to do so left
it blank that year :-)
Date: 3 Sep 2015 03:30:06
Message: <55e7f6fe$1@news.povray.org>
> such as:
Yes, I suppose so but more often than not the bracketed portion is
omitted which results in confusion, at least for me.
