POV-Ray : Newsgroups : povray.off-topic : Heightfield modification Server Time
1 Sep 2024 13:22:41 EDT (-0400)
  Heightfield modification (Message 1 to 10 of 21)
Subject: Heightfield modification
Date: 15 Aug 2015 00:49:12
Message: <55cec4c8$1@news.povray.org>
Let's say that I have a array of points generated from a height field.
But I want areas of low slope to be made completely flat and rounded to
the nearest 24 vertical units.
I know that the result will no longer be a classic heightfield since
there will be vertical areas that will need to be joined by new
triangles. But how would I accomplish this?
The simplest thing to do would be to measure the slope of each triangle
relative to the ground plane and then alter the vertices. But the
triangles are in a regular grid:
http://i421.photobucket.com/albums/pp292/SharkD2161/LDraw/terrain_nosteps_standin_01_zps6hreaqla.png
It will look funny since all they are all oriented in the same direction.
Thanks for the help!
Mike
Subject: Re: Heightfield modification
Date: 15 Aug 2015 01:18:00
Message: <55cecb88$1@news.povray.org>
Am 15.08.2015 um 06:49 schrieb Mike Horvath:
Sounds like what you want is the equivalent of a 2D array of boxes, with
each box's height determined by an input image. Do I understand that
correctly?
POV-Ray currently doesn't provide any native support for such an object
(except of course an actual array of boxes, a mesh generated by a custom
macro, or some such). It shouldn't be too difficult to implement such a
primitive though.
Date: 15 Aug 2015 01:33:45
Message: <55cecf39$1@news.povray.org>
> correctly?
> primitive though.
I only need the special behavior when the slope is already low. For
areas with a large slope I want to retain the original smooth mesh.
I will have to do the calculations myself because I need to be able to
import the mesh into LDraw.
Date: 15 Aug 2015 05:05:33
Message: <55cf00dd$1@news.povray.org>
Hash: SHA256
>>> field. But I want areas of low slope to be made completely flat
>>> and rounded to the nearest 24 vertical units.
>>> since there will be vertical areas that will need to be joined
>>> by new triangles. But how would I accomplish this?
>> boxes, with each box's height determined by an input image. Do I
>> understand that correctly?
>> object (except of course an actual array of boxes, a mesh
>> generated by a custom macro, or some such). It shouldn't be too
>> difficult to implement such a primitive though.
> For areas with a large slope I want to retain the original smooth
> mesh.
Assuming the height-field is created from an image, what you seems to
want is a local filter to detect slope and make them flat... aka
uniform in colour.
With the exception of nearest 24 vertical unit rounding, that looks
like a color/palette reduction in any decent picture manipulation
program. That kind of thing.
> to import the mesh into LDraw.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlXPAN0ACgkQhKAm8mTpkW2fcAQAifIjBBLeXx45pPguEg2d2YXI
hdev1wOnwEbrEMW0GGJ/oTPJ6bAKY78+LeKh/Bn7m5JXVCf8FRPA/MHWSNjwXnJ4
WAYRGgHkOM4SMZtUKB1KjB3i310FOFJ8qRQusl8R3oG2o4X8CxnyyboN461Wz+Q6
SaOq9MvsmB9lH6SZi50=
=4Hr0
-----END PGP SIGNATURE-----
Date: 15 Aug 2015 06:43:18
Message: <55cf17c6$1@news.povray.org>
> uniform in colour.
I was wondering if the slop pattern could be used to create a modified
image to use as a height field.
Regards
Date: 16 Aug 2015 12:21:10
Message: <55d0b876$1@news.povray.org>
How do I calculate the slope of a 3D triangle with respect to the ground
plane? And I need a non-POVray solution. Thanks.
Mike
Date: 16 Aug 2015 13:06:18
Message: <op.x3g0grcrufxv4h@xena>
On Sat, 15 Aug 2015 06:49:23 +0200, Mike Horvath <mik### [at] gmailcom>
> Mike
Maybe open the map in Photoshop. The largest areas should be the flattest
areas, so they should be easy to select with the Magic Wand Tool. Once
selected, Image adjustment/Gradient Map should do the trick if you edit
the gradient to be only 24 shades of grey.
-Nekar Xenos-
Date: 16 Aug 2015 14:34:26
Message: <55d0d7b2$1@news.povray.org>
Hash: SHA256
> ground plane? And I need a non-POVray solution. Thanks.
> Mike
basic 3x3 matrix of delta, in height field.
You get 8 products ( assume a 3x3 grid, numbered clockwise around the
center cell, of vectors from center cell to border cell: 1-c-2, 2-c-3,
...up to 8-c-1 ).
The projection on the plane of each products is 45°, so the sum of the
8 values gives you a criteria to detect a relative null curvature.
(there is the true flat situation, and the monkey saddle, but for the
central point, all of them are of flat at center).
Now, if you have a true triangle, it's another matter, just compute
the normal and normalize it, then project on the vertical axis and
check the length of the projection.
Version: GnuPG v2
iJwEAQEIAAYFAlXQ17IACgkQhKAm8mTpkW117wP9Fa2lWNrXLdfg2bU5zT6Fq5HX
aUwL5j/M7N5v9nKGPJAQwwLncb3R0Uzr0kZQS4s18g+JYsdnaovj2eZd+8QfChNd
gpXunDXsvdva1WZTGPjCmkXjVakdKre79MwjShQoKvhjSOHCKR13dnpTILExTwsm
EQHjBpCJ80RFk9rFrQI=
=qiQo
Date: 17 Aug 2015 12:24:25
Message: <55d20ab9$1@news.povray.org>
Some code would be helpful. JScript or VB or Lua please.
Mike
Date: 17 Aug 2015 12:34:39
Message: <55d20d1f$1@news.povray.org>
> flattest areas, so they should be easy to select with the Magic Wand
> Tool. Once selected, Image adjustment/Gradient Map should do the trick
> if you edit the gradient to be only 24 shades of grey.
1. An image is not going to work because the result may have coordinates
sharing the same XZ positions, but differing in Y. You can't do this
with images.
2. I want a solution in code, not one where I have to do things by hand.
