POV-Ray : Newsgroups : povray.off-topic : Fractal screen Server Time
4 Feb 2026 18:16:13 EST (-0500)
  Fractal screen (Message 11 to 20 of 20)
Subject: Re: Fractal screen
Date: 8 Aug 2015 19:40:02
Message: <web.55c69275771bab4d2aaea5cb0@news.povray.org>
> > Maybe I'll get something going and upload it to glslsandbox.
> OK, here's something if anyone's interested: http://glslsandbox.com/e#27058.0
> You'll have to place the mouse in the lower left corner to properly initialize
> the layers (goofy mistake). Seeds are automatically placed under the mouse
> cursor.
> The effect tends to be large-scale compared with other diffusion-limited
> aggregation setups, but it can be tweaked by changing the settings.
neat. But is there a way to add constructive interference?  It could make a
great simulator for frost, if you could do that.
A.D.B.
Date: 8 Aug 2015 20:35:01
Message: <web.55c6a002771bab4db426f96a0@news.povray.org>
> > cursor.
I was thinking about another version that adds a water tank/ripples effect to
the solution... is that what you mean? It would be interesting to see how the
solid layer builds faster in areas of the solution where it's concentrated due
to CI. Hm...
Date: 9 Aug 2015 00:45:00
Message: <web.55c6d99f771bab4d2aaea5cb0@news.povray.org>
> > > cursor.
> to CI. Hm...
mostly, I was thinking that the end result would look less like a voronoi
diagram.
to have it really look like frost, it would have to grow in spikes that get
wider as they get longer.  I have no idea how you'd do that...
A.D.B.
Date: 9 Aug 2015 01:30:13
Message: <op.x225kglqufxv4h@xena>
On Sun, 09 Aug 2015 00:49:03 +0200, Samuel Benge <stb### [at] hotmailcom>
> initialize
> mouse
> cursor.
Beautiful.
It would be nice to have as a Pov-Ray texture.
-Nekar Xenos-
Date: 9 Aug 2015 14:40:00
Message: <web.55c79e12771bab4db426f96a0@news.povray.org>
> > to CI. Hm...
> diagram.
It could be done, of course. Not yet sure how I'd go about it though...
Either reduce the amount of solution consumed, increase the growth rate, or do
both.
And for water crystals, it helps if the system uses a neighborhood that tests
cells six directions from center:
..oo
ooo
oo.
The result has a six-fold symmetry but ends up skewed, so to look good the final
image would need to be transformed.
Date: 9 Aug 2015 14:50:00
Message: <web.55c79fd4771bab4db426f96a0@news.povray.org>
> > initialize
> > mouse
> > cursor.
> Beautiful.
Thanks.
You could always take a screenshot, crop out the window frame, and remove the
blue channel.
Alternatively, it can all be done procedurally in POV, if you're prepared to
render many, many frames, or endure an hours-long parse time :P
Date: 10 Aug 2015 03:02:36
Message: <55c84c8c$1@news.povray.org>
> OK, so some people around here work with LCDs...
> We've got a laptop at work with a cracked screen. Around where the crack
> is, the pixels are all black. Which isn't surprising. Slightly more
> interesting is the red vertical lines that seem to extend vertically
> outwards from the cracks. Why red? Why every other pixel? Why vertical?
> I have no idea.
It's more than likely due to the column drivers malfunctioning. One
possible column driver scheme is to use only one DAC for each *pixel*
column (not sub-pixel) and then multiplex the output between RGB
subpixels. It saves by a factor of 3 the number of DACs needed and the
number of wires to/on the panel. What is likely happening is that when
each row is getting refreshed, the driver is reset as data is clocked
in, red is likely first and it gets screwed (because all the column
tracks are broken at the crack so the wrong capacitance and resistance
or possibly even shorted) and it never manages to switch the output to
the green and blue columns.
Another possibility, if the drivers are on the glass substrate itself,
or a bare IC bonded to the glass, is that they got damaged when the
crack was made.
> What's weirder still is that close to the cracks, the dead pixels
> exhibit a curiously fractal pattern. It looks like some kind of weird
> pixellated plant growth or something. Does anybody have any idea why?
The "growth" bit is because gradually moisture is getting in to the LC
material through the crack. They are normally completed sealed in, I'm
not a chemist but I know moisture+LC is bad and gives those patterns
even without a crack. Also does the pattern move when you press around
the crack? It's likely the cell-gap (distance between the inner two
faces of glass) has changed due to the crack, that normally needs to be
very accurately controlled to create a uniform image.
Date: 11 Aug 2015 13:19:59
Message: <55ca2ebf$1@news.povray.org>
That's just trippy. Not quite as intricate as some of the
reaction-diffusion systems I've seen, but mental none the less...
Date: 11 Aug 2015 14:25:00
Message: <web.55ca3d6f771bab4db426f96a0@news.povray.org>
Freudian slip? It /is/ probably more of a reaction-diffusion system than it is a
traditional DLA ;)
More detail can be added by making the following line changes:
line 28: float solSub = 10.0;
line 92: R = 1.1 * Sol;
It looks much darker, though. Also, the resolution can be changed via a pull
down menu in the upper left (the default for all shaders is 2x).
Date: 11 Aug 2015 17:25:44
Message: <55ca6858$1@news.povray.org>
> traditional DLA ;)
It hadn't really registered that it's DLA. It looks like the type of
organic growth you sometimes see with RD systems.
The difference, of course, is that I understand how DLA works. ;-)
