POV-Ray : Newsgroups : povray.off-topic : 1+2+3+4+... = ? Server Time
13 May 2026 04:21:52 EDT (-0400)
  1+2+3+4+... = ? (Message 11 to 20 of 36)
Subject: Re: 1+2+3+4+... = ?
Date: 30 Jul 2015 06:29:55
Message: <55b9fca3@news.povray.org>
scott <sco### [at] scottcom> wrote:
> >> -6s    = 1-1+1-1+1-1+1-...
> > Which is equal to:
> >   -6s = (1-1)+(1-1)+(1-1)+...
> >       = 0+0+0+0+... = 0
> I'm no mathematician, but to do that you must make the assumption that
> there are an even number of terms in the infinite sum (ie every +1 has a
> -1 to pair with it). You could have assumed an odd number of terms and
> got a sum of 1 instead.
> Writing the sum equals 1 minus the sum seems to avoid the need to make
> such an assumption.
An infinite sum can't have an "odd" or an "even" number of terms.
But you bring a good point. If you pair the elements differently, you get:
 -6s = 1+(-1+1)+(-1+1)+(-1+1)+...
     = 1+0+0+0+0+... = 1
Therefore s = -1/6.
In fact, you can get basically any integer value you want for -6s when
you group the elements appropriately.
This goes to show that when you are dealing with infinities, you can
"prove" anything you want.
I think the original "proof" is bogus.
The "proof" using Riemann's zeta function is also bogus in a sense.
Riemann's zeta function is the infinite sum of 1/n^s, but only for
values of s so that Real(s) > 1. (The sum would give 1+2+3+4+... when
s = -1, but the zeta function is not 1/n^s for values of s < 1. It's
something a lot more complicated.)
Date: 30 Jul 2015 07:46:34
Message: <55ba0e9a$1@news.povray.org>
>> such an assumption.
Yes that was my point, "grouping" in any way is invalid because you must
make assumptions about the total number of terms, which you can't for an
infinite list.
Date: 30 Jul 2015 14:59:20
Message: <55ba7408@news.povray.org>
> >> such an assumption.
> infinite list.
I don't think that's how it works. (If it were, then that original "proof"
would be invalid from the get-go, because it's grouping elements and
summing those groups.)
Date: 31 Jul 2015 02:41:47
Message: <55bb18ab$1@news.povray.org>
>> infinite list.
There's no grouping like you did in the original proof. Which part of
the original proof assumes the length of the summation is anything other
than infinite?
Welcome back BTW :-)
Date: 31 Jul 2015 18:22:55
Message: <55bbf53f@news.povray.org>
Am 27.07.2015 um 19:54 schrieb Orchid Win7 v1:
> This latter type of shenanigans is mostly used in cryptography and
> number theory, but does also pop up in places like error-correcting
> codes. (If you've ever tried to scan a bar code or play a CD, you care
> about error-correcting codes.)
Nobody cares about error-correcting codes when playing an audio CD.
Unlike DVD or even data CDs (aka CD-ROMs), Sony's audio CD format
doesn't waste any data capacity on bit error recovery.
Date: 31 Jul 2015 18:30:04
Message: <55bbf6ec$1@news.povray.org>
Am 27.07.2015 um 11:19 schrieb scott:
> https://en.wikipedia.org/wiki/1_%2B_2_%2B_3_%2B_4_%2B_%E2%8B%AF
You may also like the proof that all triangles are equilateral:
https://youtu.be/Yajonhixy4g
Date: 1 Aug 2015 05:24:10
Message: <55bc903a$1@news.povray.org>
In fact, the audio CD format uses cross-interleaved Reed-Solomon codes
for error recovery.
Date: 1 Aug 2015 11:36:56
Message: <55bce798@news.povray.org>
Am 01.08.2015 um 11:24 schrieb Orchid Win7 v1:
> for error recovery.
Damn, I hate to stand corrected.
But there was /something/ with regards to error recovery that CD-ROMs
have but CD-DAs don't.
Date: 1 Aug 2015 11:50:09
Message: <55bceab1$1@news.povray.org>
>> for error recovery.
Write this Date in our calenders.
On the first of August two thousand and fourteen. Clipka admitted he was
wrong. :-P
Regards
Date: 1 Aug 2015 12:34:56
Message: <55bcf530$1@news.povray.org>
>> for error recovery.
Yes, I have that vague recollection as well. I should think ISO-9660
probably has block-level checksums or similar, to allow corruption to be
detected. For audio CDs, the player is supposed to just fill in any
unreadable chunks with silence.
