POV-Ray : Newsgroups : povray.off-topic : Friday afternoon project: a real time ray tracer in your browser Server Time
18 Jul 2026 08:28:29 EDT (-0400)
  Friday afternoon project: a real time ray tracer in your browser (Message 21 to 30 of 33)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Friday afternoon project: a real time ray tracer in your browser
Date: 27 Jul 2015 13:35:24
Message: <55b66bdc$1@news.povray.org>
On 27/07/2015 11:47 AM, scott wrote:
> As highlighted on that page, the main problem is that every single pixel
> runs exactly the same code with the same inputs (apart from pixel
> coordinate). So you need some way of making every pixel generate a bunch
> of random numbers that are in no way related to any other pixels in the
> image (otherwise you get strange patterns like you saw with your 1
> sample image).
I wonder how long before GPU gets a hardware-based randomness source?
(It can't be that hard to sample a little thermal noise in hardware,
especially if you don't need cryptographic strength. The problem is
usually that hardware randomness sources are a tad slow...)
Date: 28 Jul 2015 02:45:01
Message: <web.55b724a0dee5de4aea9e60760@news.povray.org>
This works out of the box on OS X Yosemite under Google Chrome and it does so
very well indeed. This is a very clever piece of work. Thanks for sharing it
with us.
Date: 28 Jul 2015 02:55:16
Message: <55b72754$1@news.povray.org>
> with us.
Thanks! I can only claim credit though for modifying an existing path
tracing algorithm to run on a GPU and modifying JS/WebGL boiler-plate
code from various sources. I'm quite happy that it all runs from a
single html document though, hopefully it's a good platform for anyone
to tinker about with.
Date: 29 Jul 2015 04:19:24
Message: <55b88c8c@news.povray.org>
So do you remember a few years(?) back when 3D Mandelbulbs were all the
rage? IIRC there were some threads on these very groups about rendering
them in POV, however it was painfully slow.
Well now you can do it in realtime on a (fast) GPU near you :-)
I need to tidy up the code a bit to make it easier to "fly around" and
control the detail settings, but here's a quick teaser:
https://www.youtube.com/watch?v=r_Ek3Kfv8KA
Note there's nothing pre-calculated here, the GPU is doing all the work
on the fly.
Date: 31 Jul 2015 20:55:52
Message: <55bc1918$1@news.povray.org>
Am 27.07.2015 um 19:35 schrieb Orchid Win7 v1:
Well, GPUs should at least be able to provide plenty thermal for the
noise ;)
Date: 4 Aug 2015 04:55:14
Message: <55c07df2$1@news.povray.org>
> noise ;)
Yes :-)  It's not hard to sample the thermal noise, the problem is how
to sample it billions of times per second with enough resolution to be
useful.
Date: 4 Aug 2015 13:00:38
Message: <55c0efb6@news.povray.org>
>> noise ;)
> Yes :-) It's not hard to sample the thermal noise, the problem is how to
> sample it billions of times per second with enough resolution to be useful.
Well, no, you typically sample it a few times a second and use that to
seed a normal PRNG.
In other news, Intel added an op-code to generate truly-random numbers
using exactly this technique. The Linux kernel team added it to
/dev/random... and then took it out again, because they were apparently
concerned that the NSA would modify the die of your CPU to make the
random numbers non-random. (!!)
Jesus, that's next-level. Surely if you don't trust the hardware your OS
is running on, it's already game over. (?)
Date: 5 Aug 2015 04:24:23
Message: <55c1c837$1@news.povray.org>
>> useful.
> seed a normal PRNG.
But will that not cause the same problems seen already today with
unrandomness? If the pixel shader for every pixel gets exactly the same
random seed value, and just uses a PRNG to modify it, won't you see
patterns? I would have thought every pixel needs its own unique random
seed value every frame to really get rid of those sort of PRNG patterns.
If you want a *truly* unbiased ray tracer for example.
Apparently the on-chip thermal noise sampler outputs a stream of bits at
3 GHz. I don't know how big the hardware is for that circuit, but it's
not *that* far away from what you'd need to get a true random number for
every pixel processed on the GPU.
Yes, something like a true RNG in every home home PC seems like
something the NSA would be extremely interested in.
Date: 5 Aug 2015 16:28:40
Message: <55c271f8$1@news.povray.org>
>>> useful.
>> seed a normal PRNG.
> patterns?
My plan was more to have some hardware that seeds a PRNG with a
truly-random seed and then distributes a *different* random iterate from
the PRNG to each thread in the bunch. It's awkward to code in software,
but shouldn't be that hard in hardware...
OK.
It's slightly mental that the government of one country can insert spy
hardware into every computer that can ever exist... Especially given
that all silicon fabrication is done in countries hostile to America...
But hey, what do I know?
Date: 6 Aug 2015 03:20:12
Message: <55c30aac$1@news.povray.org>
Oh don't worry, I'm sure if the NSA were capable of inserting spy
hardware into CPU dies, the fab itself would be more than capable of
changing it back to something more to their (or their government's)
liking :-)
