POV-Ray : Newsgroups : povray.off-topic : Reach for the SKI Server Time
1 Sep 2024 13:21:09 EDT (-0400)
  Reach for the SKI (Message 1 to 10 of 16)
Subject: Reach for the SKI
Date: 20 Jul 2015 17:03:11
Message: <55ad620f$1@news.povray.org>
(OK, that was terrible.)
Over the weekend, I implemented an interpreter for the SKI combinator
calculus. In Bash script.
I am a sick, sick individual.
"The who to the what now?" you ask. Well, around about the time Alan
Turing was inventing Turing machines, a guy called Alonzo Church was
inventing something called the lambda calculus. If a Turing machine is
like an ultra-simplified computer, then the lambda calculus is like an
ultra-simplified programming language.
(Of course, all the experts know that "really" they're neither of these
things. They're actually abstract models of computation. But we'll
cheerfully ignore that for a moment.)
The lambda calculus is a programming language which is *so simple* that
it doesn't even have arithmetic built-in. In order to do trivial
calculations, you first have to manually *define* what arithmetic "is".
For every single program. Needless to say, programs in the lambda
calculus are... quite verbose.
The lambda calculus is conceptually simple, but rather fiddly to parse,
and even more awkward to execute. (In particular, there are some fun
edge-cases to do with scoping rules.) However, every possible lambda
expression can be encoded into an equivalent expression that contains
only three pre-defined values, traditionally denoted by the letters S, K
and I.
Let me say that again: The SKI combinator calculus is a programming
language consisting only of three letters (and millions of brackets),
and it's somehow Turing-complete.
The rules for executing SKI expressions are considerably simpler. And
the language has much easier to parse. So I set about writing an
interpreter for it. As a Unix shell script. It uses some features
specific to the Bourne Again Shell ("Bash"), so it's not portable to
other systems. But Bash is everybody's default shell anyway, so...
As you may know, any possible computable function can be computed by a
suitable Turing machine. However, Turing machines have no notion of
input/output operations, which is what we generally want real-world
programs to have. Likewise, neither the lambda calculus nor the SKI
calculus has a way to do I/O. So I added one.
It's based on the idea of how the original Haskell I/O system used to
work. (I.e., before we got monads.) Initially, I made the system so that
the SKI program accepts an arbitrary-length stream of code numbers as
input, and returns an arbitrary-length stream of code numbers as output.
I later changed it to be a stream of *bits*. My plan was that the
interpreter would read these codes and do different I/O operations based
on the "commands" it receives. I've since decided that since even the
most trivial SKI program is quite hard enough, this extra layer isn't
needed. (Yet?)
I've dubbed the resulting language "Pointless". So how do you execute a
Pointless program? The rules are quite simple:
* The only legal input characters are: S K I ( )
* The input source code is a sequence of "items". An "item" consists of
a single letter, or a pair of brackets enclosing ONE or more sub-items.
(It is an error for there to be ZERO items in the brackets.)
* To "execute" the program, you apply a series of transformations to the
source code, according to the rules below.
* First, append the items G, E, P to the right-hand end of the program.
* Now endlessly apply the transformation rules. Look at the LEFT-MOST
item in the program, and select the applicable rule:
RULE #1: "(" - Delete the opening bracket and the MATCHING closing bracket.
Rule #2: "I" - Delete the I.
Rule #3: "K" - Delete the K, keep the next item, delete the item after that.
Rule #4: "S" - Delete the S. Number the following items as 1, 2, 3.
Remove them, and replace with the sub-expression "1 3 (2 3)".
Rule #5: "G" - Read one bit of input. Delete the G and replace it with:
+ S(K(S(SI(K (KI) )))G   if the bit read was 0
+ S(K(S(SI(K (K ) )))G   if the bit read was 1
Rule #6: "E" - End of program. Stop executing.
Rule #7: "P" - Delete the P, keep the next item, insert O, Z after it.
Rule #8: "O" - Delete the O. Output a 1 bit.
Rule #9: "Z" - Delete the Z. Output a 0 bit.
The first 4 rules constitute the entire SKI calculus. The 5 subsequent
rules specify how to perform I/O.
For example, consider the expression
   SSKKII
By rule #4, 1=S, 2=K, 3=K, and we get
   SK(KK)II
Applying rule #4 again, 1=K, 2=KK, 3=I and we have
   KI((KK)I)I
Now rule #3 applies, which deletes the ((KK)I) item:
   I
As a slightly longer example,
   S(S(KS)K)IZO
                        S: 1=(S(KS)K), 2=I, 3=Z
   (S(KS)K)Z(IZ)O
   ^      ^             Brackets
   S(KS)KZ(IZ)O
                        S: 1=(KS), 2=K, 3=Z
   (KS)Z(KZ)(IZ)O
   ^  ^                 Brackets
   KSZ(KZ)(IZ)O
                        K: 1=S, 2=Z
   S(KZ)(IZ)O
                        S: 1=(KZ), 2=(IZ), 3=O
   (KZ)O((IZ)O)
   ^  ^                 Brackets
   KZO((IZ)O)
                        K: 1=Z, 2=O
   Z((IZ)O)
                        Output 0
   ((IZ)O)
   ^     ^              Brackets
   (IZ)O
   ^  ^                 Brackets
   IZO
                        I
   ZO
                        Output 0
   O
                        Output 1
So, in the end, this program outputs 001.
It turns out you can write a parser that parses items and an execution
engine that implements the 9 rules in less than 99 lines of shell
script, as I shall shortly demonstrate.
My initial thought was that certainly the first 4 rules ought to be
pretty simple to implement using sed (the Unix Stream EDitor). However,
sed only understands regular expressions, and such a construct cannot
handle *nested* brackets. For that, you need a context-sensitive grammar.
After many experiments, I hit upon a single idea: represent
single-letter items as themselves, and represent compound items by ID
numbers. So the shell script first runs the input through the "tr"
command (TRanslate), which strips all characters except the ones we're
interested in. (In particular, it strips all whitespace.) Then the
script creates one file on disk for each compound item.
For example, the expression
   S(SIK)(KI(SS))
might be translated into a bunch of disk files that look like this:
   0001.item: S 2 3
   0002.item: S I K
   0003.item: K I 4
   0004.item: S S
Now bash has a "read" command, which reads one line of input and splits
it into "words". By putting spaces around each item, this makes Bash
automatically split up the words, and put them into separate variables.
(It also means we can count higher than 9, of course...)
The parser is a fairly simple affair; once all spaces have been
stripped, look at each character. If it's an open bracket, allocate a
new item ID and start parsing items into that file. If it's a close
bracket, return to the caller [presumably a bracket handler, which will
then back out of the current bracket sequence].
Now ordinarily Bash tries to read lines. But according to Google [more
exactly, Stack Overflow], the magical incantation
   IFS='' read -r -n1 CHAR
will read exactly one character into ${CHAR}. (IFS='' disables all
delimiter characters, -r disables character escapes in the input string,
-n1 means "read 1 char".)
Once everything is item files containing space-delimited tokens, a call like
   read TOKEN1 TOKEN2 TOKENS <Filename
will redirect stdin to "Filename", and execute the "read" command, each
puts the first token in ${TOKEN1}, the second in ${TOKEN2}, and ALL
remaining tokens into ${TOKENS}.
At this point, it's just a matter of reading the item representing the
top-level program expression, figuring out what the first token is, and
overwriting the item file with the new, modified expression. (In some
cases, that means allocating new items, but for the most part it's just
rearranging existing ones.)
So, without further ado, here is the actual shell script:
#!/bin/bash
shopt -s extglob   # Allow regex in case patterns.
if [ ! -r "$1" ]; then echo "Can't open file '$1' for reading." ; exit
10 ; fi
if [ -d Heap ]; then rm -r Heap ; fi
mkdir Heap
echo 1 >Heap/Next
function NewItem()
   local ITEM=$( cat Heap/Next )
   echo ${ITEM}
   let ITEM++
   echo ${ITEM} >Heap/Next
function ItemPath() { printf "Heap/%04d.item" $1 ; }
function Ingest()
   printf '('
   tr -cd 'SKI()' <"$1"
   printf 'GEP)'
function ParseItem()
   if [ "${CHAR}" == "(" ]; then ParseItems ; return 0 ; fi
   if [ "${CHAR}" == ")" ]; then              return 1 ; fi
   printf "${CHAR} " ; return 0
function ParseItems()
   local ITEM=$( NewItem )
   local FILE=$( ItemPath ${ITEM} )
   printf "${ITEM} "
   while ParseItem >>${FILE} ; do : ; done
function Decode()
   local ITEMS ITEM
   read  ITEMS <$( ItemPath $1 )
   for ITEM in ${ITEMS}
   do
     if [[ "${ITEM}" =~ [0-9]+ ]]
       then printf '(' ; Decode ${ITEM} ; printf ')'
       else printf "${ITEM}"
     fi
   done
function Exec()
   local FILE=$( ItemPath $1 )
   while true
   do
     Decode $1 && printf '\n'
     read CMD ITEM1 ITEM2 ITEM3 ITEMS <${FILE}
     case "${CMD}" in
       +([0-9]))
         read OTHERS <$( ItemPath ${CMD} )
         printf "${OTHERS} ${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}" >${FILE}
       "I") printf "${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}" >${FILE} ;;
       "K") printf "${ITEM1}          ${ITEM3} ${ITEMS}" >${FILE} ;;
       "S")
         CHILD=$( NewItem )
         printf "${ITEM2} ${ITEM3}"                   >$( ItemPath
${CHILD} )
         printf "${ITEM1} ${ITEM3} ${CHILD} ${ITEMS}" >${FILE}
       "G")
         read BIT <&10
         case "${BIT}" in
           "")  printf "K          ${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}"
 >${FILE} ;;
           "0") printf "${CONS0} G ${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}"
 >${FILE} ;;
           "1") printf "${CONS1} G ${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}"
 >${FILE} ;;
         esac
       "E") echo "End of program." ; exit 0 ;;
       "P") printf "${ITEM1} O Z ${ITEM2} ${ITEM3} ${ITEMS}" >${FILE} ;;
       "Z") echo 0 >&11 ; printf "${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}" >
${FILE} ;;
       "O") echo 1 >&11 ; printf "${ITEM1} ${ITEM2} ${ITEM3} ${ITEMS}" >
${FILE} ;;
     esac
   done
CONS0=$( printf '(S(K(S(SI(K(KI))))))' | ParseItem )
CONS1=$( printf '(S(K(S(SI(KK)))))'    | ParseItem )
ROOT_ITEM=$( Ingest "$1" | ParseItem )
Exec ${ROOT_ITEM} 10<Input.rec 11>Output.rec
Assumptions / limitations:
* The input bits must be stored in a text file [or conceivably a named
pipe] called "Input.rec", which must contain one "0" or "1" per line.
Even if the program being interpreted has no input commands!
* The output bits are stored in a similar file Output.rec, which will be
created if it doesn't already exist.
* The shell script must be executed with the filename of the SKI program
as its only input. Otherwise you'll get an error message about being
unable to open the file.
* There is minimal error-checking. It isn't hard to add this, but it
makes the shell script longer than 99 lines. I wanted to show how
"simple" the job is, without a lot of error-handling clutter.
* In particular, mismatched brackets or incorrect SKI programs will
probably provoke utterly baffling failures.
To try it out, you need some SKI programs to run. Possibly the simplest
program is one that reads 0 bits of input and returns 0 bits of output:
   KK
Even simpler is a program who's output is identical to its input:
   I
Unimpressed, huh? OK, let's try something a bit more interesting. This
program takes no input, and always produces 101 as its output:
   K
     S(K(S(SI(K K ))))
       S(K(S(SI(K (KI) ))))
         S(K(S(SI(K K ))))
         K
I said the lambda calculus is verbose, right? Well, the SKI calculus is
even worse! (Wikipedia says something about  Θ(3^n) worse. Then again,
Wikipedia also says [citation needed], so...) By adding more possible
predefined letters, it's possible to reduce the bloat --- at the expense
of making the interpreter more complicated, of course.
To do anything much less trivial than this... well, the programs start
to get LARGE. I need to build myself a "compiler" to produce such
programs. (But not in Bash - GOD NO!)
Still, this whole idea came about as I was thinking about a Bash script
that contains a tarball that it then unzips, which mostly contains a
giant SKI program and the SKI interpreter. Good luck to anybody trying
to reverse-engineer that! ;-)
Subject: Re: Reach for the SKI
Date: 21 Jul 2015 12:58:03
Message: <55ae7a1b$1@news.povray.org>
Alternatively, if reading the input reached EOF, replace G with K.
I haven't looked into it properly yet, but it ought to be possible to
dispense with this rule.
Overall, I'm a little disappointed with how "complicated" this stuff
looks. It's meant to be like "wow, this is so simple, yet you can write
entire programs with it? No way!" But it comes across as maybe too
complicated for that.
> numbers.
It's really not hard to write a Bash script that linearly scans the
input, keeping a count of how many brackets it's seen, and handle items
that way. Trouble is, I anticipate "real" SKI programs being very large
indeed, and this method requires copying potentially huge blocks of text
around. OK, you can copy one character at a time, but Bash isn't noted
for being a high-performance I/O engine.
By contrast, by working with item IDs, each individual item is actually
tiny. We also get "full sharing" (i.e., if a sub-expression gets
duplicated [as the S command happens to do], then it still only gets
"executed" once).
Hypothetically, it could do with some kind of "garbage collector", which
removes item files that are no longer reachable. In practice, I doubt
you're going to run out of disk space. And it's not like we can reuse
item IDs (unless you start also renumbering items!)
Also, illegal characters in the input (e.g., J) will get silently
ignored, rather than reported as an error. Also note that SKI programs
are case-sensitive.
Date: 21 Jul 2015 14:51:20
Message: <55ae94a8$1@news.povray.org>
The lambda calculus has a single data-type: functions. Everything in the
language is basically an infinite-argument function. Because each
function takes a function as input and returns another function as
output. The notion of "curried functions" originates here; we can
represent a 2-argument function as actually being a 1-argument function
that returns a 1-argument function that returns the actual result [which
is again a function, but hey].
It goes without saying that trying to describe "functions that take
functions and construct functions that return functions for constructing
functions that make functions" gets confusing rather rapidly!
So how the hell do you "do" anything with the lambda calculus? Well,
think about it this way: To do anything with a digital computer, you
have to take whatever it is you want processed and *encode* it into
binary. You then run a program --- which is *also* binary --- which
produces a result [again binary]. You then *decode* the result binary to
get back something meaningful.
For example, to add two numbers, you encode each of them as a series of
bits. The computer than has a hardware-accelerated operation for
transforming the bits in such a way that when you decode the result, it
represents the sum of the original two numbers. Phrased like that, it
sounds really complicated. But in practise it isn't so much.
The lambda calculus is similar. Except that there's no
hardware-accelerated "add two numbers" operation built-in. You have to
define one yourself. But I'm getting ahead of myself.
The syntax of the lambda calculus goes like this. A lambda expression is
always one of three things:
* A variable reference.
* An anonymous function.
* A function call.
You reference a variable by simply writing its name. Likewise, you call
a function by writing the function to call followed by the argument to
call it with. An anonymous function consists of the Greek letter lambda
("λ"), followed by a variable name, followed by an arrow, followed by
the function body.
In symbols:
* <var name>
* λ <var name> → <expression>
* <expression> <expression>
You "execute" lambda expressions via a process of "beta reductions". For
example:
   (λ x → x x) foo
To "execute" this, take the body of the lambda function (the bit after
the arrow) and replace every "x" with "foo". The result is obviously
   foo foo
As another example,
   (λ x → x y) foo
This becomes
   foo y
The thing on the right doesn't have to be a variable, of course. It can
be another function. For example,
   (λ x → x x) (λ x → x x)
Now we have a confusion; the "x" on the left is a *different* variable
from the "x" on the right. Each is only in scope between the lambda and
the close-bracket. This kind of thing gets confusing quickly; this is
one of the reasons I went with the SKI calculus for my cryptic interpreter.
So let's try to implement some stuff in the lambda calculus. We'll start
with something really trivial: Bool functions. Now before we can do
that, we need to figure out a way to turn Bools into functions, and
functions back into Bools. In other words, we need an *encoding*.
According to the Church encoding [named after Alonzo Church], we have
   True  =   (λ t → (λ f → t))
   False =   (λ t → (λ f → f))
In other words, "True" is represented by any function that accepts 2
arguments and returns the 1st argument, unmodified. Similarly, "False"
is represented by any function that accepts 2 arguments and returns the
2nd argument unmodified.
With this way of thinking, then if "b" is a variable which contains [a
function that's meant to represent] a Bool, then we can do
   b abc xyz
If b = True, then the result of this expression is abc, otherwise it is
xyz. So it's a little like writing
   if (b == true) then return abc; else return xyz;
Suppose we have a "b", and we want the logical-NOT of that. How can we
compute it? Well, actually that's easy:
   b False True
Or rather, in proper lambda syntax,
   b (λ t → (λ f → f)) (λ t → (λ f → t))
If we want a NOT *function*, we can write
   NOT = λ b → b (λ t → (λ f → f)) (λ t → (λ f → t))
Now we have a 1-argument function that accepts a Bool and returns the
logical-NOT of it.
First: that was easy! Second: man, that's really verbose! This makes
*Java* look succinct. (!)
How about a logical-AND?
   AND = λ b → (λ b → a b (λ t → (λ f → f)))
If you're not expert in Boolean algebra, this might not be immediately
clear, but take a look at the truth table for the AND operation:
   a | b | a & b
   F | F |   F
   F | T |   F
   T | F |   F
   T | T |   T
If you study this table, you will notice that when a=T then a & b = b.
So in our lambda expression, if a is true, we return b. You will also
notice that if a=F then a & b = F, utterly regardless of b. So if a is
false, we return false [which is the (λ t → (λ f → f)) part at the end].
The OR function is fairly similar:
   OR = λ b → (λ b → a (λ t → (λ f → t)) b)
This time, if a=T we return T unconditionally, otherwise we return b.
Given the above, we can implement XOR as
   a XOR b = (a OR b) AND (NOT (a AND b))
which is wordy in words, but as a lambda expression it's
   XOR =
     (λ A → (λ B →
       (λ b → (λ b → a b (λ t → (λ f → f))))
         (A (λ t → (λ f → t)) B)
         (A B (λ t → (λ f → f)))
That is a LOOONG way to write A XOR B! Perhaps a better way is to attack
the truth table directly. If you study it, you'll notice that when A=F
then A XOR B = B, otherwise A XOR B = NOT B.
   XOR = (λ A → (λ B → A (B (λ t → (λ f → f)) (λ t → (λ f → t))) B))
That's a bit shorter.
It should be clear by this point that figuring out what some random
chunk of lambda expression does is quite fiddly. You can also see why
I'm looking into building automated tools for constructing this stuff.
If it takes multiple lines of code just to XOR two variables, imagine
trying to implement something actually complex!
In fact, the Church encoding offers a general way to encode any
algebraic data type. Suppose, for example, that an IO Mode has three
possible values: ReadOnly, ReadWrite, and Append. You can represent an
IO Mode as a 3-argument function that returns one of its arguments
unchanged. Which one tells you what of the three possible values it
represents.
   ReadOnly  = λ r → (λ w → (λ a → r))
   ReadWrite = λ r → (λ w → (λ a → w))
   Append    = λ r → (λ w → (λ a → a))
It goes without saying that you can't "tell" what a particular function
is supposed to represent just by looking at it --- much like you can't
tell what the bit-sequence 11010011 is meant to be. (Is that unsigned
binary? Ones complement? Twos complement? Excess-N? Sign and magnitude?
Fixed point? Floating-point? Scaled integer? ASCII code? Some other
random code...?)
For data records, you can use the following trick. Let's say we want to
store a data pair. "5" is not a valid lambda expression, but for
simplicity let's pretend it is. To represent the pair (5, 7), you could
write a function
   (λ f → f 5 7)
This function takes a function as input, and passes the two elements of
the pair to that function as arguments. Using this, you can easily write
a "get X" or "get Y" function:
   GetX = λ p → p (λ x → (λ y → x))
   GetY = λ p → p (λ x → (λ y → y))
That is, we take a pair ("p") as input, and call it, passing a function
that accepts two values ("x" and "y") as input and returns the desired
one. We could also easily do some calculation on the two coordinates
before returning them. It's also easy to see how we could extend this
scheme to deal with more than just 2 items.
Let us consider the Haskell programmer's favourite ADT:
   data List x = Null | Cons x (List x)
We can turn this into lambda expressions:
   null     = λ n → (λ c → n)
   cons h t = λ n → (λ c → c h t)
So a "list" is a 2-argument function. If it's an end-of-list marker, it
returns the first argument. Otherwise it takes the second argument and
calls it with the head and tail of the list as arguments. Now we can
easily write a function to (say) get the first element out of a list:
   head = λ l → l ??? (λ h → (λ t → h))
The "???" stands for the fact that if the list is empty, then there *is*
no "first element" to return, so we'd need to decide what to do here.
(Perhaps return some sort of default value instead, depending on what
this is a list *of*.)
One tricky issue is recursion. Since all functions are anonymous, it
*looks like* it's impossible for a function to call itself recursively.
However, it *is* in fact possible.
The basic idea is to write a non-recursive function, and pass a copy of
the function in as an argument. For example:
   (λ x → x x) (λ f → ...my function ...)
This does *almost* what we want. The function on the left makes two
copies of the function on the right, and passes one copy as the argument
to the other. The function on the right accepts a copy of itself as
input, and is therefore able to call itself.
But this isn't quite right. This only lets us do *one* recursive call.
We only made *two* copies of the function. To allow unlimited recursion,
we really need an unlimited number of copies somehow.
The function we search for is the so-called "Y combinator". It has the
property that
   Y f = f (Y f) = f (f (Y f)) = f (f (f (Y f))) = ...
In short, if f expects a copy of itself as input, then Y f generates
infinity copies of f, and we can have unlimited recursion.
Now, how to implement Y?
Wikipedia gives one implementation:
   Y = λ g → (λ x → g (x x)) (λ x → g (x x))
If we give it an argument:
   Y f = (λ g → (λ x → g (x x)) (λ x → g (x x))) f
       =       ((λ x → f (x x)) (λ x → f (x x)))
       =     f ((λ x → f (x x)) (λ x → f (x x)))
       =     f (Y f)
The first line is the definition of Y. On the second like, every g has
become f. Taking the lambda on the left and replacing each x with the
lambda on the right yields the third line. But if you look, the part in
brackets is identical to the line above, which represents Y f. Which is
what the final line says. So here we have unlimited recursion.
Now we can do something like
   MAP =
     Y
     (λ map →
       (λ f → (λ list →
         (λ null → (λ cons →
           list null (λ head → (λ tail → cons (f head) (map f tail)))
The Y combinator applies the inner function to itself, allowing it to
recurse over a list. If the list is null, return null. Otherwise, apply
f to the head of the list, and recursively apply map f to the tail.
Yeah, clear as mud, right? Trust me, it does work...
First, let me define what these letters actually are:
   I = λ x → x
   K = λ x → (λ y → x)
   S = λ f → (λ g → (λ x → (f x) (g x)))
The I function ("identity") takes an argument and just returns it
unchanged. The K function ("konstant") takes two arguments, and returns
the first one. In other words, Kx is a function that already returns x.
Finally, the S function... is the complicated one. But basically it
accepts two functions (f and g) and an input (x), and passes that input
to both functions, before calling the result of one with the result of
the other.
It should now be fairly obvious how the SKI interpreter rules come
about, given the lambda definitions for what these functions actually do.
Amazingly, every possible lambda expression can be transformed into a
lambda expression containing only S, K and I. [Provided there are no
"free variables" to start with.] Not only that, but there is a very
simple algorithm for doing precisely this. Let's write an expression in
square brackets to denote converting it to SKI. The rules are then:
What [λ x → e] becomes depends on e:
* If e is just x, then we have [λ x → x] = I.
* If e doesn't contain x at all, then e never changes no matter what x
is. So we can do [λ x → e] = K[e].
* If e is a function call, then e = l r
   * If r is just x, then we have [λ x → l x] which is equivalent to
[l]. (This is an "eta reduction".)
   * Otherwise, we can use S: [λ x → l r] = S[λ x → l][λ x → r]
* Finally, [λ x → (λ y → e)] = [λ x → [λ y → e]]. (That is, encode the
inner lambda first, and then encode the other lambda.)
Let's try our luck with some simple expressions. Perhaps the True
expression:
   λ t → (λ f → t)
OK, so how does this go down?
   [λ t → (λ f → t)]
Well, t definitely appears in the function body, so let's encode the
inner lambda first.
   [λ t → [λ f → t]]
Well, f doesn't appear in the body at all, so the K rule applies:
   [λ t → Kt]
Now the eta reduction rule applies:
   [K]
The SKI encoding of K is just K. So
   True = K
How about False?
   [λ t → (λ f → f)]
   K[λ f → f]
   KI
That was easy!
So how about NOT?
   [λ b → b (λ t → (λ f → f)) (λ t → (λ f → t))]
   S[λ b → b (λ t → (λ f → f))][λ b → (λ t → (λ f → t))]
   S[λ b → b (λ t → (λ f → f))](K[λ t → (λ f → t)])
   S[λ b → b (λ t → (λ f → f))](K[λ t → [λ f → t]])
   S[λ b → b (λ t → (λ f → f))](K[λ t → Kt])
   S[λ b → b (λ t → (λ f → f))](KK)
   S(S[λ b → b][λ b → (λ t → (λ f → f))])(KK)
   S(SI[λ b → (λ t → (λ f → f))])(KK)
   S(SI(K[λ t → (λ f → f)]))(KK)
   S(SI(K(K[λ f → f])))(KK)
   S(SI(K(KI)))(KK)
Well, it's a lot of steps, but the end result isn't too bad. The hardest
part is getting all the millions of brackets right! Fortunately, this
stuff is easy for a computer to do. Indeed, I've written a small Haskell
program where you type stuff into a HTML form, and the web server send
back a trace like the one above, pretty colour-coded as it does the
encoding. (It also allows you to execute arbitrary lambda expressions,
execute SKI expressions, and more besides.)
One of the most annoying things about carrying this process out by hand
is when you see an expression like λ b → ...b..., where the variable
*is* mentioned, but only in one place, and really deeply burried. So you
end up with a trail of K values. And then, because there's another
lambda around it, you've got to wrap all those Ks in Ss, and the
expression ends up really big and complicated.
You can somewhat fix that by adding a few new functions:
   L = λ f → (λ g → (λ x → (f x) (g  )))
   R = λ f → (λ g → (λ x → (f  ) (g x)))
These functions are both similar to S, but without the need to K the
left or right sub-expression. Which is a tiny saving in itself, but it
means that as you encode further lambdas wrapping the whole thing, the K
doesn't accumulate a stream of other combinators. The end result can be
quite a saving in text.
   L[λ b → b (λ t → (λ f → f))][λ t → (λ f → t)]
   L[λ b → b (λ t → (λ f → f))][λ t → [λ f → t]]
   L[λ b → b (λ t → (λ f → f))][λ t → Kt]
   L[λ b → b (λ t → (λ f → f))]K
   L(L[λ b → b][λ t → (λ f → f)])K
   L(LI[λ t → (λ f → f)])K
   L(LI(K[λ f → f]))K
   L(LI(KI))K
As you can see, this is a bit smaller than the previous expression.
Date: 22 Jul 2015 03:32:52
Message: <55af4724$1@news.povray.org>
An interesting read... What are the uses of SKI then, apart from just
making simple algorithms take up a million characters to encode?
Sounds like the start of an IOCCC entry to me, although it seems the
recent entries are just ridiculous (like PC emulators, ray tracers and
realtime CFD solvers in a few lines of gibberish C code with lots of
commas).
I once wrote an interpreter for a one instruction set computer (that's a
lot easier than what you did!) and even wrote the code to generate prime
numbers using it, but it got complicated and boring very quickly to do
anything useful. OK I found it on my old HD, see attached, it should(!)
compile and output all the prime numbers up to 1000. I wouldn't attempt
to try and figure out how it's doing it though :-)
I have a feeling though, writing a prime number generator in SKI might
be a tad longer...
Download 'test.c.txt' (1 KB)
Date: 22 Jul 2015 16:21:18
Message: <55affb3e$1@news.povray.org>
Erm... that's pretty much the only use.
Although, Wikipedia does mutter something about people making silicon
that runs SKI commands directly. (Not exactly sure how that would work,
but you can imagine a CPU with only 3 possible opcodes would be quite
simple to implement... Certainly a damned site easier than trying to
implement the full lambda calculus!)
That's pretty much what I was channelling, yeah.
I actually started thinking about a POV-Ray SDL program that's actually
a self-decompressing program that then executes SKI code to build a
scene description. But maybe that's just crazy...
Either way, I figured nobody would ever figure out WTF it actually does.
I would think the set of people who know how to unravel obfuscated shell
code and the set of people who know about theoretical models of
computation are totally disjoint.
> commas).
Ah, C. The entire language is specifically designed for crazy.
> anything useful.
Quitter. ;-)
My dream is to build non-trivial programs, encode them to SKI, and then
marvel at how huge they are. A bit like compiling Hello World in Eiffel
and then looking at the 25MB executable it produces.
Uh... I don't even... How can you index an integer as if it's an array?
If my understanding is not wildly broken, that's Undefined Behaviour...
> be a tad longer...
Division is fairly hard to implement in the lambda calculus. (Depending
on which way you encode integers.) The Fibonacci numbers should be
comparatively easy to compute, however.
[In fact, I managed to write a working implementation for that in my
lunch break. But it uses Church numerals, whereas the SKI interpreter I
wrote expects the output to be a linked list of Church Bools. It
shouldn't be too hard to convert, but I haven't done it yet...]
Date: 23 Jul 2015 03:05:01
Message: <web.55b0919e51ecd4c216086ed00@news.povray.org>
ROTFL !!! isn't that being slightly pervert ?! :)
I'm sure however that it could find unpredicted real applications one day!
Date: 23 Jul 2015 03:25:10
Message: <55b096d6$1@news.povray.org>
As I found with my OISC interpreter though, you just shift the
complexity away from the CPU/interpreter and into the program itself. In
a real system you'd probably end up with a "core" library to do things
like add, subtract etc, and then because every single program uses those
library calls, you might as well implement them in hardware...
Yes that's crazy, but so long as the output was half-decent I'm sure it
would generate a lot of interest after someone asked to see the source
code :-)
I wouldn't say *totally*.
I think that was one of the first things I learned from the IOCCC! a[b]
means read the value at memory address a+b*L, where L is the length of
each array element in bytes. If L=1 then a[b] == b[a]. Also if you then
use that value to index into another array: c[ a[b] ], by the same rule
that is equivalent to a[b][c] or any other combination you can come up with.
In my OISC code I used a prime sieve to avoid having to do any
multiplications or divides. The only tricky bit was having to use
self-modifying code to write the results to the correct place in the
output array.
I tried figuring out Fibonacci numbers in my head the other day (it was
a game-show question on TV) - I got lost pretty quickly, it's a lot
harder than you think without any pen and paper.
Date: 23 Jul 2015 03:37:00
Message: <55b0999c@news.povray.org>
Well, no, the SKI combinators are of theoretical interest, because they
show you something about how small a Turing-complete programming
language can be.
It's like, Turning machines have to *practical* use (unless you enjoy
writing excruciatingly complicated programs!), but they are
theoretically important.
Of course, the Iota calculus is even smaller, consisting of only *one*
predefined function. If we write it as X (rather than Iota), then its
definition is
   X = λ a → a S K
Therefore we have
   XX = XSK = (XS)K = SSKK = SK(KK)
If we eta-expand that, we find
   λ x → SK(KK)x = λ x → Kx(KKx) = λ x → x
which is the definition of I. Therefore
   XX = I
Similarly,
   X(XX) = XI = ISK = SK
   X(X(XX)) = X(SK) = SKSK = KK(SK) = K
   X(X(X(XX))) = XK = KSK = S
So, using only X, we can recover S, K and I, which we already know to be
Turing-complete. Therefore, any possible computable function can be
constructed just using X and brackets.
OTOH, if you look at the size of "S" verses "X(X(X(XX)))", you can see
that anything in the Iota calculus is going to be *really huge*!
This seems to be the general thing; the simpler your programming
language, the more complicated your programs get!
Date: 23 Jul 2015 04:05:59
Message: <55b0a067$1@news.povray.org>
>> day!
> language can be.
Wrong argument, I think. The outcome and next step is. Who would have
thought that quantum mechanic theory in the 1920's would lead to
transistors and your job. ;-)
Which is what Mr said.
Isn't that the point of high level languages? To get rid of all those
brackets.
Have you just proved: 1 = 1?
Regards
Date: 25 Jul 2015 04:09:05
Message: <55b34421$1@news.povray.org>
Indeed. The simpler the language, the more complex the programs.
> code :-)
Hehe, we'll see. ;-)
You may remember many years ago I built a self-decompressing SDL program
based on Huffman codes. Oh, the compressor was written in Smalltalk, but
the decompressor was SDL. It decompresses itself and then runs the
result. Curiously, when I posted it somebody instantly recognised the
decompression algorithm, despite the set of people who know 3D and the
set of people who know data compression being completely disjoint...
In other news: I often wonder just how hard it "really" is to
reverse-engineer compiled Haskell code. Supposedly it's intractably
hard, since GHC aggressively optimises your Haskell code, and the result
is statically linked against a non-trivial run-time system, and it does
things like store the call stack on the heap and other strangeness...
OTOH, game studios deliberately obfuscate stuff all the time, and this
stops approximately 0% of all cracking attempts.
Which would mean, for an int variable, unless b=0 you are now accessing
undefined memory locations. That's UB. At this point you have to *guess*
what appears next in memory (which is compiler-dependent).
Uh, how do you figure? The memory locations of the two variables might
be in no way related.
> Also if you then
> with.
That seems clear enough.
> output array.
I don't have it with me, but I did manage to come up with a recursive
algorithm for generating prime numbers. It's based on the fact that the
prime numbers repeat, until multiples of the next prime come into play.
The algorithm is tricky as hell to get right, but it's quite nice when
it works. Does require O(N!) RAM though...
What, you can't compute the square root of 5 in your head? ;-)
No, seriously - humans have shallow stacks.
