POV-Ray : Newsgroups : povray.off-topic : Wall of text Server Time
25 Feb 2026 00:05:10 EST (-0500)
  Wall of text (Message 1 to 10 of 10)
Subject: Wall of text
Date: 18 Jun 2015 15:27:27
Message: <55831b9f$1@news.povray.org>
Arguably one of the most famous Haskell functions is Map().
Map() takes two arguments --- a function and a list --- and it applies
the function to every element of the list, returning the results in a
new list. Simple.
In fact, Haskell has a version of the Map() function which is more
polymorphic than that. It can be applied to things that aren't lists.
For example, Haskell does not have null. But it does have something
called Maybe. An Int variable definitely holds an integer. However, a
Maybe<Int> variable does exactly what it sounds like --- it's a value
that *maybe* contains an Int.
This is actually quite a big deal. In a language such as Java or C#,
every non-primitive datatype is basically a pointer type --- and every
such type can potentially be null.
Here's the problem though: 99% of the code in your code is probably
expecting that all of its arguments will never, ever be null, and will
behave in some unspecified way if null is present. (Typically by
throwing an exception, but possibly several method calls *after* the
problematic one!) On the other hand, 1% of your code *does* expect null
as a legitimate value that actually signals something important. Sadly,
it's nearly impossible to figure out what 1% that is, unless by some
fluke it happens to be documented.
In Haskell, this stuff is in the type signature. If a function takes an
Customer argument, then it is 100% guaranteed at compile-time that the
input will *always* be an actual Customer value, and never null. Because
Haskell *doesn't have* null. But if the Customer argument is actually
optional, you can explicitly declare it as Maybe<Customer>. This
instantly signals to anybody trying to use this function that it's
expecting the possibility of there being no Customer. And it also means
the function itself won't compile unless it actually *does* handle the
Customer argument being empty. You cannot "forget" to do this; it won't
type-check.
Maybe does a similar thing for results. Rather than throw an exception
if something goes wrong, you can return a Maybe<something>. Again, this
signals to anybody using your code that it may fail in some way. And it
forces you to check for failure. (You cannot "forget" to do this.) And
you don't need any special exception-catching machinery; it's just data.
You just inspect it.
(In a way, it's kind-of like the C# Nullable<> type. But in C#, you only
use that for value-types [i.e., almost no real-world types except
built-in primitives]. But I digress...)
So Maybe is wonderful. But, as you can imagine, if you're not careful
you can end up spending a lot of code dealing with maybies, to the point
of obscuring your actual logic.
Fortunately, Map() works on Maybe values. Instead of a list of values,
you can have a Maybe<something>, and if it contains a value, Map() will
apply your function to that value, and put the result back into a
Maybe<something else>.
Anything that has a Map() implementation is called a "functor". (This
term apparently derives from category theory. Formally, Haskell's
Functor class represents the endomorphisms on the category of valid
Haskell types... Yeah.) So list and Maybe are both functors. You might
also expect that Set would be a functor. Well, it *should* be... but it
isn't, since it doesn't work for *all* possible types. (Only types that
have a total ordering.) There's a few other container types that are
functors though (e.g., Sequence).
Slightly bizarrely, *functions* are functors. Given a function from type
X to type Y, you can Map() a function from type Y to type Z over it,
yielding a new function from type X to type Z and a fairly obvious way.
The fact that you can do this routinely confuses the hell out of people. ;-)
If this was an object-oriented programming language, there would be an
IMappable interface, and all the standard container classes would
implement it. But you know what else is a functor? Parsers.
Now a parser is obviously no kind of container whatsoever. But given a
Parser that takes some input and returns a String, you can type a
function from String to Int and Map() it over the Parser, yielding a new
Parser that produces an Int.
Here we don't have a *container* of stuff, we have an "action" that
*produces* stuff. And we can Map() a function over the stuff that will
ultimately be produced.
Once you wrap your mind around this idea, it comes as little surprise
that other sorts of "actions" are also functors. For example, an atomic
shared-memory transaction is a functor. An I/O operation is a functor.
So here we take two things --- data containers and executable actions
--- which appear wildly different, and unify them under a single
abstraction (functor) based on their abstract similarity. That's what
happens when your library design is guided by advanced mathematics
rather than commercial interests.
Suppose we want to run two parsers and combine their output. Now the
Map() function allows us to apply a 1-argument function to the output of
1 parser. But how do we apply a 2-argument function to the output of 2
parsers?
Well, recall that Haskell has curried functions. If you call a
5-argument function with 1 argument, you end up with a 4-argument
function. That being the case, we actually *can* Map() a 2-argument
function over a parser. The result is a function that produces a
1-argument function.
At this point we're stuck. There's no obvious way to proceed. Indeed,
using only Map(), you can't go any further.
Anything that implements Map() is called a functor. But anything that
implements Apply() is called an *applicative functor*. (Yeah, it's so
easy to pronounce...)
Forget about parsers for a moment. Let's think about lists again. So
let's say we have two lists and a 2-argument function. If we Map() the
function over the first list, we now have a list of 1-argument
functions, and we're stuck.
The Map() function takes *a* function and a list of inputs. But the
Apply() function takes *a list* of functions and a list of inputs. And
it applies every function to every list, collecting all the results into
a single, flat list. That means that we can do something like
   Apply(Map(my_func, list1), list2)
Assuming my_func is a 2-argument function, Map(my_func, list1) applies
my_func to every datum in list1, producing a *list* of functions, which
Apply() then applies to every datum in list2.
Notice that we can now handle *any* number of arguments. If I take a
4-argument function and Map() it, I get a list of 3-argument functions.
If I Apply() that, now I have a list of 2-argument functions, which I
can Apply() again to get a list of 1-argument functions, and Apply()
again to get a list of results. Something like
   Apply(Apply(Apply(Map(my_func, list1), list2), list3), list4)
Recall that in Haskell, the syntax for function calls is not
   my_func(x, y)
but rather
   my_func x y
Well, in Haskell, we define the following aliases:
   <$> = Map()
   <*> = Apply()
That done, we can now write
   my_func <$> list1 <*> list2
This is much more readable! The syntax for a normal function call is
nearly identical to the syntax for calling a function multiple times
with arguments pulled out of lists. Indeed, we can also write
   my_func <$> list1 <*> list2 <*> list3 <*> list4
Now it is clear that we can handle any desired number of arguments. And
it's all thanks to curried functions!
This trick of course works with parsers too. If we have a function that
combines the output of our two parsers, we can just do
   combine_func <$> parser1 <*> parser2
(Or, indeed, any other number of parsers.) So now we have a systematic
way to glue an arbitrary number of simple parsers together to form more
complex parsers. We can hierarchicly build parsers as complex as we wish.
If you've read this monologue before, you might recall me rambling on
about "monads", and how you can build parsers using them. Where are
those guys now?
You actually can build sophisticated parsers using only applicative
functors. And, indeed, it is considered good practise to do so, for
reasons that I'll come to later. But it turns out that monadic parsers
can do things that applicative parsers cannot. There are grammars for
which you can write a monadic parser, but you cannot write an
applicative one.
Most particularly, you cannot decide which parser to run next based on
what input you've seen so far. Neither Map() nor Apply() allow you to
inspect the input and decode what parser to do next; the sequence of
parsers is decided long before we actually "run" the parsers.
This is very frequently no problem at all. But sometimes it *is* a
problem. Most particularly, an applicative functor is often all you need
for parsing, but for I/O it's nearly useless. You *want* your program to
perform different I/O based on what input you feed it!
So let's try to make a parser that changes its mind. Suppose we want to
parse two identical characters. Say we have a parse_any() function that
accepts any character (and returns it), and a parse_char() function that
only accepts the specified character. What we want to do is something like
   var c = parse_any();
   parse_char(c);
But of course, parse_any() doesn't return a *character*; it constructs a
*parser*! So what are we to do? Well, this *almost* works:
   Map(parse_char, parse_any)
This will run the parse_any parser, and then apply the parser_char
function to its output. [Notice how the parsers have ended up in
"backwards" order, with parser_char *last* and parse_any *first*.] The
output of parse_any is a character, so that's right. Trouble is... well,
look:
   Parser<char> parse_any() {...}
   Parser<char> parse_char(char c) {...}
   Parser<Y> Map(Func<X, Y>, Parser<X>)
   Map(Func<char, Parser<char>>, Parser<char>) ==> Parser<Parser<char>>
We've written a parser that returns another parser! Oops! That's not
right... We don't want to *return* the second parser, we want to *run* it!
Fortunately, we can sort this out with one extra function: Join(). The
Join function takes a functor of functors and returns a single functor.
For a list, it's quite easy to see what Join() does. It takes a list of
lists, and returns a flat list. So basically it takes the outer list,
and concatenates together all the lists inside it. Easy.
For a parser, it symbolically "looks like" the function just deletes one
copy of the word "Parser" from the type signature:
   Parser<X> Join(Parser<Parser<X>> nested);
But in fact, what this function is doing is constructing a new parser
that runs the outer parser and then carefully connects all the parse
state up to the inner parser before running it. So that (for example)
the new parser continues from the same point that the outer parser had
got up to. That kind of thing. So you can kind of imagine what the code
might look like.
Using Join(), we can implement our desired parser:
   Join(Map(parse_char, parse_any))
It turns out that anything which implements Apply() and Join() is
actually a monad. Well, not quite. I've missed out one function:
Inject(). Sometimes you need a parser in a certain place (e.g., a
function input), but you don't want to actually *parse* anything, you
just want to always return a specific result. That's what Inject() is for.
   Parser<X> Inject(X);
Perhaps it's easier to think in terms of lists. In that case, Inject()
takes an element and returns a 1-element list.
Let us survey the scene so far:
   Functor:
     List<Y> Map(Func<X, Y>, List<X>);
   Applicative functor:
     List<X> Inject(X);
     List<Y> Apply(List<Func<X, Y>>, List<X>);
   Monad:
     List<X> Return(X);
     List<Y> Bind(List<X>, Func<X, List<Y>>);
   or
     List<X> Return(X);
     List<X> Join(List<List<X>>);
It's absolutely obvious that Inject == Return. These two functions both
do exactly the same thing. It may not be immediately obvious that every
Applicative is also a Functor. Why? Because Map = Inject+Apply:
   Map(f, listX) = Apply(Inject(f), listX);
Apply() takes a *list* of functions, whereas Map() takes *one* function.
Well if you use Inject() to put your function into a 1-element list,
then you're done.
So, everything that implements Applicative basically implements Functor
as well. (In fact, Haskell *requires* you to implement Map() if you have
an implementation for Inject() and Apply().)
It's not totally obvious that Bind = Map+Join. But it is:
   Bind(listX, f) = Join(Map(f, listX));
Bind takes a list of values and a function that takes a value and
produces a list of results. If you just Map() the function, you get a
list of lists. Join() will flatten that down for you.
It might seem dumb to *require* that the result of the function passed
to Bind() has to return a *list* of results. But if you think about
parsing again, then Bind() takes a parser and a function that takes the
result of the parser and constructs the next parser to run. And now it
makes sense why Bind() looks like this. Again, Join() is running an
outer parser and connecting its workings up to the inner parser thus
returned.
It's also not obvious, but Join = Bind+identity:
   Join(list_list_X) = Bind(list_list_X, list_X => list_X);
Bind will execute a function for each element of the outer list. If that
function just *returns* whatever you give it, then we've flattened a
list of lists into one list --- exactly what Join() is specified to do!
So you can construct Bind() from Map()+Join(), and you can construct
Join() from Bind(). Incidentally, you can build Apply() from Bind() too:
   Apply(list_funcs, list_X) =
     Bind(list_funcs, func => Bind(list_X, x => Return(f(x)));
So every Monad really is an Applicative, and every Applicative really is
a Functor.
(Until recently, Haskell required everything declared as Applicative to
be declared as Functor as well, but you could declare something as Monad
without any other declarations. With the latest revision of the standard
libraries, every Monad is now *required* to be an Applicative [and hence
a Functor] --- a breaking change which will probably affect quite a lot
of older Haskell code...)
(Sadly, we still have Inject() *and* Return(), even though they clearly
do precisely the same thing. When Monad wasn't required to be
Applicative, that was necessary. Now that Monad automatically implies
Applicative, maybe someday we can get rid of the duplicate function.)
Although a monad can be defined by return+bind *or* return+apply+join,
Haskell chooses to define return+bind as the required elements, and join
is then implemented in terms of bind. One might argue that Join() is
perhaps easier to comprehend then Bind()... or maybe not. It depends on
your perspective.
Back to that statement I made earlier. Applicative parsers are less
powerful than monadic ones. So why are they considered better?
One aspect is notation. Compare:
   my_parser = do
     x <- parser1
     y <- parser2
     z <- parser3
     return $ my_func x y z
   my_parser = my_func <$> parser1 <*> parser2 <*> parser3
Some say that applicative *style* is less imperative and more readable.
In this example, it's certainly less verbose!
But there's more. The monadic parser above basically desugars into
   Bind(parser1, x =>
     Bind(parser2, y =>
       Bind(parser3, z => Return(my_func(x, y, z))
Now we don't know exactly how Bind() or Return() might be implemented
for a particular parser library. But what we *do* know is this: the
outer-most Bind() function is being given two arguments. One is parser1,
which is a parser object that we, the library authors, can probably
inspect in all sorts of interesting ways. The other is a function.
That's it. It's just an arbitrary blob of Turing-complete code. We can't
do anything with this code except execute it.
(I notice that in C#, you can actually *introspect* such code, so you
can notionally see what it does. But beware Rice's theorem: determining
almost any useful information about this function is formally equivalent
to the Halting Problem. So even in C#, you're not going to get very far!)
Consider, on the other hand, the applicative parser. Desugared, it looks
like this:
   Apply(Apply(Map(my_func, parser1), parser2), paser3)
We still can't do anything with my_func. But it's plainly possible for
Map() to return a parser that contains a marker saying "this was build
by Map()", and likewise for Apply(). And this opens up a fantastic
possibility: you can execute the above function calls to build your
complicated parser, and then you can write an "optimiser" function that
rearranges the internal structure of the parser to improve performance.
This is possible because the parsers are directly connected to each
other. Only at the final step do we Map() an arbitrary Turing-complete
computation over the *output* of a parser. The parsers themselves are
statically generated and cannot change based on the input being parsed.
And that means we can potentially do the kind of rearrangements that an
SQL engine might do to a complex query.
In short, an applicative parser supports run-time optimisation before we
run it. A monadic parser utterly thwarts any attempts at run-time
analysis. (Although perhaps the compiler can do something interesting at
compile-time.) Then again, you can write a monadic parser that parses a
BNF grammar followed by a document written in that grammar! There's not
much hope of optimising such a parser before it runs...
Subject: Grouting of comment.
Date: 18 Jun 2015 17:00:05
Message: <55833155$1@news.povray.org>
I do like reading your paragraphs, even when I can't follow them 100%.
They are educational.
So much so I understood the mention of Haskell in the BBC series of 15
minutes on "Codes that changed the World".
http://www.bbc.co.uk/programmes/b05qqhqp
(The last prog. 5/5)
Regards
Subject: Re: Grouting of comment.
Date: 18 Jun 2015 17:01:01
Message: <5583318d$1@news.povray.org>
Oops!
http://www.bbc.co.uk/programmes/b05qqhqp/episodes/player
Regards
Date: 21 Jun 2015 17:41:09
Message: <55872f75$1@news.povray.org>
That's always good to hear.
Hmm. Kinda interesting. And yet, at the same time, it's one of those
where everything has been dumbed down to the point where they might as
well be talking about invisible pixie fairies or something. A bit like...
http://blog.xkcd.com/2015/05/13/new-book-thing-explainer/
Date: 22 Jun 2015 05:49:57
Message: <5587da45@news.povray.org>
Yes, it is for a radio 4 audience. Grown ups who are interested but
never had the time to learn.
> A bit like...
That looks like fun. :-)
For a slightly different take on educating those who do not know.
Do you remember the secret life of machines?
http://www.secretlifeofmachines.com/index.shtml
https://en.wikipedia.org/wiki/The_Secret_Life_of_Machines
Regards
Date: 22 Jun 2015 08:23:13
Message: <5587fe31$1@news.povray.org>
>> A bit like...
It does, and it immediately shows were things go seriously wrong with
this concept: /fire/ does not come out of volcanoes; /land/ is not going
away.
Trying to translate concepts into a simpler language needs also
/understanding/ of those concepts. I fear that is not the case here.
This is a much better/accurate work than the book by Randall Munroe.
Date: 22 Jun 2015 14:14:25
Message: <55885081$1@news.povray.org>
Yeah, I guess.
I'm always disappointed when I watch Horizon or something, and they tell
you about something interesting, but simplified to the point where you
have no idea what they actually mean anymore.
>> A bit like...
No idea. What I *do* remember is this:
https://en.wikipedia.org/wiki/The_Way_Things_Work
This is how I learned how logic gates work. I was *so* upset when Emma
destroyed the book. Then again, she only did it to upset me, so...
Date: 22 Jun 2015 15:38:41
Message: <55886441$1@news.povray.org>
> Yeah, I guess.
It is sad when you know more than your teacher. :-(
When you go to her wedding. Forget to put on your trousers on the big
day. ;-)
Regards
Date: 22 Jun 2015 16:25:57
Message: <55886f55$1@news.povray.org>
>> Yeah, I guess.
Well, that was my experience for much of higher education. But I meant
more when you watch a program about string theory or something, and it
*sounds* like it's probably really interesting... but they didn't want
to do an hour of equations, so instead they just have arty shots of
expensive particle accelerators and some whizzy computer graphics. And
an analogy about ants.
> day. ;-)
Pff. Emma got married years ago.
Date: 22 Jun 2015 18:32:53
Message: <55888d15$1@news.povray.org>
Sometimes radio programmes are better. No graphics but light on the hard
sums. :-)
>> day. ;-)
Sorry, I thought you were talking about your sister.
Regards
