POV-Ray : Newsgroups : povray.off-topic : Fired fox Server Time
13 May 2026 08:40:17 EDT (-0400)
  Fired fox (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Fired fox
Date: 16 Mar 2015 19:55:35
Message: <55076d77$1@news.povray.org>
On Mon, 16 Mar 2015 19:44:31 -0400, Jim Henderson wrote:
>> This seems to be a worrying trend. GNOME 2.x had a sea of configuration
>> options. GNOME 3.x has almost *nothing*. In order to change anything,
>> you have to install user-supplied "extensions". (Oh, did I mention?
>> There's no documentation for how to write these extensions. You just
>> have to read the source code. Because that's trivial...) It seems
>> software producers have somehow got the idea that it's OK to produce a
>> product with no configurability, and let a dozen different 3rd parties
>> write a dozen mutually-incompatible "extensions" each of which solves a
>> different 30% of the problem.
> GNOME3 has plenty of configuration options, set using dconf-editor.
Oh, and for creating gnome-shell extensions?
https://wiki.gnome.org/Projects/GnomeShell/Extensions
Google with search terms "writing gnome 3 shell extensions".
First hit.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 17 Mar 2015 10:20:44
Message: <5508383c$1@news.povray.org>
On 3/16/2015 1:08 PM, Orchid Win7 v1 wrote:
> For over 10 years now I've been a satisfied Firefox user.
> Today I finally got fed up with its extreme slowness, and tried to
> install another browser.
Firefox's biggest problem seems to be how to threads things. It works
nicely, if you have NoScript, and leave everything you don't absolutely
need in the pages scripts "disabled". Its does vastly worse with a lot
of active scripts, animated gifs, or anything that has to simultaneously
load as the page does.
But, apparently... they know the problem, but fixing it... would require
a complete rewrite of the engine it uses... :(
Hotmail... is broken in everything, imho, since they changed things
there. lol
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Date: 17 Mar 2015 15:00:18
Message: <550879c2@news.povray.org>
GNOME 3 uses the gsettings system to hold its configuration settings.
It's something like the Windows Registry, but harder to use. (E.g., it
seems to be impossible to access when X11 isn't running. It's
nightmarishly hard to configure settings for a user who isn't you. It's
really hard to navigate without a GUI tool. And so on.)
Since OpenSUSE 13.1, gsettings likes to randomly revert certain settings
every 103 reboots, for no defined reason. This is extremely unhelpful.
But the *most* unhelpful thing is that half the things you want to
change DON'T HAVE SETTINGS! For example, there is no setting to bring
back the minimise and maximise buttons; you have to install an extension.
But I guess that's a symptom of another worryingly common problem: GNOME
3 is *clearly* designed to run on a tablet or a phone. Because nobody
uses desktop PCs anymore, right? Right?? >_<
> First hit.
Riiiight. Because I haven't already read that page 65,536 times. :-P
Basically, you write a shell extension by writing a JavaScript file that
contains [at least] three functions with specific names. These functions
work by MONKEY-PATCHING THE LIVE RUNNING CODE to make it do something
different. The extension itself is responsible for reverting these
changes when you disable the extension. (In particular, there are
extensions that cannot be disabled, or don't disable properly.) Leaving
this critical detail up to people who don't really know what they're
doing and have no documentation to go by is... not optimal.
This, then, is how you write a shell extension. And how do you work out
which part of THE ENTIRE SHELL CODEBASE you need to monkey-patch to make
the changes you want?
You read the source code.
For the entire shell.
Because there's no documentation. Indeed, one Stack Overflow commenter
helpfully commented that "there SHOULD be no documentation, because the
source code is the documentation". No, random Internet user, the source
code is not and will never be the documentation. Because the source code
gives you the *implementation* not the *interface*.
Then again, when your entire extensibility platform is fundamentally
based on purposely breaking encapsulation to start with...
Date: 17 Mar 2015 15:03:19
Message: <55087a77$1@news.povray.org>
That would seem to be the case. Load any moderately complex page, and
the CPU usage goes sky-high.
Does anybody else remember when everybody started switching to Firefox
because it was so much faster than IE? People used Firefox even though
dozens of high-profile web pages only worked with IE. (Like I said,
running a dated version of Firefox was *so much faster*!) Now, it seems,
the boot is on the other foot.
It's a shame, because Firefox seems to have some really lovely developer
tools, if you want to build crazy web-stuff...
Date: 17 Mar 2015 16:56:48
Message: <55089510@news.povray.org>
Well, I do not use gnome anymore on PC. xfce rules now.
I enjoyed gnome2 and its applets. They lost me with unity & gnome3.
>> First hit.
That's why I now prefer the xfce's run a shell widget (generic monitor):
the output for logo and text is not so fancy, but for periodical
scanning of a resource, it's easy enough to allow me to have want I
wanted (and easy testing), without problem. I could even have the shell
to launch a binary, if I dare to not be portable (and a bit slow for a
double fork)
Right. At best: the documentation is in the source code, for doxygen to
extract. But "Source is all you need" is just bad. Code never explains
the concepts.
Date: 17 Mar 2015 17:19:42
Message: <55089a6e$1@news.povray.org>
>> uses desktop PCs anymore, right? Right??>_<
> I enjoyed gnome2 and its applets. They lost me with unity&  gnome3.
Sadly, this seems to be the way of the world. At work I'm forced to use
Windows 8, which keeps insisting that my desktop is actually a tablet.
Complete with low-detail fonts, and an ugly, blocky colour scheme that a
tablet can handle. Because why would you pay £1,000 for a developer
workstation and then expect to use it like a developer workstation?
> the concepts.
Indeed.
All the source code for the Linux kernel is freely available. Yet no
sane person expects you to actually read the source code to figure out
how you open a file!
(Then again, the Linux kernel obeys POSIX and similar, so...)
Date: 18 Mar 2015 03:47:34
Message: <55092d96$1@news.povray.org>
Am 17.03.2015 um 20:00 schrieb Orchid Win7 v1:
Why does that sound strangely familiar?
Date: 18 Mar 2015 12:19:15
Message: <5509a583$1@news.povray.org>
Could be a bug.  Have you asked in the openSUSE forums for some help, and/
or reported a bug?
> extension.
No, you don't. gnome-tweak-tool -> Windows.
I use GNOME3 every day, and not on a tablet or touchscreen.  Works fine
here.
>> First hit.
You said it wasn't documented.  It is.
Got a better idea about how to do it?
No.  What you do is you identify what it is you want to do, and you find
that part of the code, if that's the way it's actually done (I don't for
a moment pretend to have written an extension, however given your track
record in overstating things, you don't really think I'm going to take
your word for it, do you? ;) )
Um, no, it's based on extending encapsulation in an OO way, as I
understand it.  It's somewhat like using DITA specializations, or
extending an object class in a directory service.
Jim
Date: 18 Mar 2015 13:41:36
Message: <5509b8cf@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> I think the thing that really drove it home was that the other day I
> happened to fire up an old VM that's running Firefox 5. It was *so much*
> faster! I could actually look at Google Maps in *realtime*! Not with a
> 30-second pause every time I scroll or zoom.
Do you honestly think that if that were common, people wouldn't have
noticed? (I just tested google maps with firefox, and they worked just
fine in real-time, with no lagginess of to speak of.)
Or is this another one of your exaggerations, where you express
estimations with two orders of magnitude of exaggeration?
Date: 19 Mar 2015 04:03:33
Message: <550a82d5$1@news.povray.org>
If it were just my home PC, I'd probably assume that something is wrong
with my PC. Given that the PC at work does the exact same thing... and
other people in the office have also mentioned it and switched
browsers... I suspect it's not just me.
(Plus the fact that an older version of Firefox runs drastically faster.
In a VM, which is typically slower...)
Maybe 30 seconds is an exaggeration. When you make a mouse gesture, and
nothing visible happens for multiple seconds afterwards, it sure *feels*
like several eternities.
