POV-Ray : Newsgroups : povray.off-topic : Fired fox Server Time
13 May 2026 08:40:16 EDT (-0400)
  Fired fox (Message 31 to 34 of 34)
Subject: Re: Fired fox
Date: 11 Apr 2015 13:38:59
Message: <55295c33@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> If it were just my home PC, I'd probably assume that something is wrong
> with my PC. Given that the PC at work does the exact same thing... and
> other people in the office have also mentioned it and switched
> browsers... I suspect it's not just me.
So please explain why it works just fine with my PC.
Date: 11 Apr 2015 15:08:38
Message: <55297136$1@news.povray.org>
Absolutely no idea. What version are you running?
(As I said, I ran a much older version in a VM, and it was trippy-fast.
It's only recent versions that seem slow...)
Date: 28 Apr 2015 14:17:44
Message: <553fcec8$1@news.povray.org>
On 16/03/2015 08:08 PM, Orchid Win7 v1 wrote:
> So I installed Opera, and I've just spent about an hour trying to force
> it to work the way *I* want it to work, not how it tells me I should
> work.
So today I learned a thing: Opera auto-updates itself. And it is
impossible to disable this behaviour.
I don't find that very amusing.
(Well OK, it's but *impossible*, just damned hard. There's a
command-line switch --- which won't work if you click a URL which
auto-opens the default web browser. Or you can rename the updater
executable. Which may accidentally get "repaired". Or you can try to
firewall your web browser... good luck with that!)
Not only can you not tell it to stop this, you also cannot tell that
it's doing this. There's no UI to tell you an update is happening, or
how far it's got, or anything. That's very annoying.
Date: 28 Apr 2015 14:19:25
Message: <553fcf2d$1@news.povray.org>
Could be worse, I suppose; FileZilla auto-updates itself too. It has an
option to turn off updates, WHICH IT BLATANTLY IGNORES!
As in, I've turned updates off, the settings dialog tells me it's off,
and still every time I start the program it prompts me to install the
update. And no matter how many times I delete the update file, it
redownloads it again.
Maybe it's time to switch to WinSCP...
