POV-Ray : Newsgroups : povray.off-topic : Fired fox Server Time
13 May 2026 05:43:03 EDT (-0400)
  Fired fox (Message 11 to 20 of 34)
Subject: Re: Fired fox
Date: 18 Mar 2015 03:47:34
Message: <55092d96$1@news.povray.org>
Am 17.03.2015 um 20:00 schrieb Orchid Win7 v1:
> But I guess that's a symptom of another worryingly common problem: GNOME
> 3 is *clearly* designed to run on a tablet or a phone. Because nobody
> uses desktop PCs anymore, right? Right?? >_<
Why does that sound strangely familiar?
Date: 18 Mar 2015 12:19:15
Message: <5509a583$1@news.povray.org>
On Tue, 17 Mar 2015 19:00:21 +0000, Orchid Win7 v1 wrote:
> On 16/03/2015 11:55 PM, Jim Henderson wrote:
>>> GNOME3 has plenty of configuration options, set using dconf-editor.
> GNOME 3 uses the gsettings system to hold its configuration settings.
> It's something like the Windows Registry, but harder to use. (E.g., it
> seems to be impossible to access when X11 isn't running. It's
> nightmarishly hard to configure settings for a user who isn't you. It's
> really hard to navigate without a GUI tool. And so on.)
> Since OpenSUSE 13.1, gsettings likes to randomly revert certain settings
> every 103 reboots, for no defined reason. This is extremely unhelpful.
Could be a bug.  Have you asked in the openSUSE forums for some help, and/
or reported a bug?
> But the *most* unhelpful thing is that half the things you want to
> change DON'T HAVE SETTINGS! For example, there is no setting to bring
> back the minimise and maximise buttons; you have to install an
> extension.
No, you don't. gnome-tweak-tool -> Windows.
I use GNOME3 every day, and not on a tablet or touchscreen.  Works fine
here.
>> Oh, and for creating gnome-shell extensions?
>> https://wiki.gnome.org/Projects/GnomeShell/Extensions
>> Google with search terms "writing gnome 3 shell extensions".
>> First hit.
> Riiiight. Because I haven't already read that page 65,536 times. :-P
You said it wasn't documented.  It is.
> Basically, you write a shell extension by writing a JavaScript file that
> contains [at least] three functions with specific names. These functions
> work by MONKEY-PATCHING THE LIVE RUNNING CODE to make it do something
> different. The extension itself is responsible for reverting these
> changes when you disable the extension. (In particular, there are
> extensions that cannot be disabled, or don't disable properly.) Leaving
> this critical detail up to people who don't really know what they're
> doing and have no documentation to go by is... not optimal.
Got a better idea about how to do it?
> This, then, is how you write a shell extension. And how do you work out
> which part of THE ENTIRE SHELL CODEBASE you need to monkey-patch to make
> the changes you want?
> You read the source code.
> For the entire shell.
No.  What you do is you identify what it is you want to do, and you find
that part of the code, if that's the way it's actually done (I don't for
a moment pretend to have written an extension, however given your track
record in overstating things, you don't really think I'm going to take
your word for it, do you? ;) )
> Because there's no documentation. Indeed, one Stack Overflow commenter
> helpfully commented that "there SHOULD be no documentation, because the
> source code is the documentation". No, random Internet user, the source
> code is not and will never be the documentation. Because the source code
> gives you the *implementation* not the *interface*.
> Then again, when your entire extensibility platform is fundamentally
> based on purposely breaking encapsulation to start with...
Um, no, it's based on extending encapsulation in an OO way, as I
understand it.  It's somewhat like using DITA specializations, or
extending an object class in a directory service.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 18 Mar 2015 13:41:36
Message: <5509b8cf@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> I think the thing that really drove it home was that the other day I
> happened to fire up an old VM that's running Firefox 5. It was *so much*
> faster! I could actually look at Google Maps in *realtime*! Not with a
> 30-second pause every time I scroll or zoom.
Do you honestly think that if that were common, people wouldn't have
noticed? (I just tested google maps with firefox, and they worked just
fine in real-time, with no lagginess of to speak of.)
Or is this another one of your exaggerations, where you express
estimations with two orders of magnitude of exaggeration?
Date: 19 Mar 2015 04:03:33
Message: <550a82d5$1@news.povray.org>
If it were just my home PC, I'd probably assume that something is wrong
with my PC. Given that the PC at work does the exact same thing... and
other people in the office have also mentioned it and switched
browsers... I suspect it's not just me.
(Plus the fact that an older version of Firefox runs drastically faster.
In a VM, which is typically slower...)
Maybe 30 seconds is an exaggeration. When you make a mouse gesture, and
nothing visible happens for multiple seconds afterwards, it sure *feels*
like several eternities.
Date: 19 Mar 2015 04:14:30
Message: <550a8566$1@news.povray.org>
> or reported a bug?
Given how excruciatingly hard it is to get access to the OpenSUSE bug
tracker... no, I haven't.
Besides, they'll just report it upstream and then go back to doing
nothing. That's what they did with the Zypper bug I spent ages
diagnosing and reporting.
>> extension.
Perhaps it was the "show task list" option then. I remember spending
weeks trying to configure the shell the way we want it, and in the end I
couldn't do it.
>> uses desktop PCs anymore, right? Right??>_<
> here.
I'm not saying it doesn't *work*. I'm saying it's clearly not optimal.
The way they try to stop you arranging multiple windows visible at once,
the way they try to steer you away from multitasking. Heck, the latest
revision even removed a scrollbar and replaced it with a sequence of
buttons, so it'll work better with a touchscreen.
How you write a minimal Hello World type thing is documented. The vast,
sprawling mass of code you need to interact with to do anything
nontrivial is utterly undocumented.
How do I respond to window open/close events? Not documented. How do I
determine what tray icons are defined? Not documented. How do I resize
an existing window? Not documented. Would you like me to continue?
How about, I don't know, the system generating a reverse diff as you
change stuff, and then applying that diff when you turn the extension
off? It's more work for the framework, but then less work for the
extension author. And I'd *hope* the framework is rather better tested
than your typical extension...
You realise I got *paid money* to write several shell extensions and
modify some existing ones, right?
Indeed, it seems the only "documentation" for how to do anything is to
read the source code for extensions that other people have already written.
(How THE HELL these other people wrote this stuff utterly baffles me...
I guess one or two people might have too much free time, but given the
vast number of extensions available [most of which add back
functionality that GNOME 2 had built-in], it screams that somebody
somewhere must have some real documentation...)
In an OO language, you don't generally modify a huge, complex framework
by deleting code from the running system and replacing it with your own.
Then again, JavaScript isn't completely OO, so...
Date: 19 Mar 2015 06:41:11
Message: <550aa7c7$1@news.povray.org>
I'm with you. When you find a better browser. Let us know.
Regards
Date: 19 Mar 2015 10:25:00
Message: <web.550adc362e481659f644696d0@news.povray.org>
Patrick Elliott <kag### [at] gmailcom> wrote:
> Firefox's biggest problem seems to be how to threads things. It works
> nicely, if you have NoScript, and leave everything you don't absolutely
> need in the pages scripts "disabled". Its does vastly worse with a lot
> of active scripts, animated gifs, or anything that has to simultaneously
> load as the page does.
> But, apparently... they know the problem, but fixing it... would require
> a complete rewrite of the engine it uses... :(
I'm running the latest Firefox on Windows XP, along with the Flash plug-in
there.
The sluggishness of Firefox seems to be a known problem, having to do with its
"plug-in-container.exe" process. And without a solution, AFAIK-- except to add
the NoScript add-on. (Haven't done that yet.)
Flash + plug-in-container = big problem! Like, 100% takeover of the CPU. It
happens on my system about 50% of the time while I'm online. My only solution at
present is to kill the plug-in-container process in Task Manager, when things go
screwy. (Or to keep the Flash plug-in from firing up at all, choosing "ask to
activate" there.) I'm obviously missing a lot of Flash content on the web--but I
don't need to see most of it anyway.
Date: 19 Mar 2015 12:27:16
Message: <550af8e4$1@news.povray.org>
>>> settings every 103 reboots, for no defined reason. This is extremely
>>> unhelpful.
>> and/
>> or reported a bug?
1. Create user ID
2. Validate your e-mail address
3. Go to bugzilla.opensuse.org and enter a bug
Not terribly difficult, really.
You don't know that unless you file a bug.  File a bug, or don't
complain.  Seriously, that is probably the most annoying thing you can do
is bitch about something that's fixable and not report a bug.
>>> extension.
> couldn't do it.
Not sure what you mean by "show task list option".  What was the specific
thing you were trying to do?
>>> GNOME 3 is *clearly* designed to run on a tablet or a phone. Because
>>> nobody uses desktop PCs anymore, right? Right??>_<
>> here.
It's optimal for me, and I don't use a tablet.  "Optimal" is clearly a
matter of personal taste, and I wish people would stop putting forth
their personal opinion as cold hard fact - it's not.
I don't see any of those issues.
Since I don't write extensions, it's kinda pointless for you to
continue.  However, again, given your track record, I'm not going to take
it on faith that your assertion that these things aren't documented is
true.  You'll have to forgive me my cynicism on that point.
>>> that contains [at least] three functions with specific names. These
>>> functions work by MONKEY-PATCHING THE LIVE RUNNING CODE to make it do
>>> something different. The extension itself is responsible for reverting
>>> these changes when you disable the extension. (In particular, there
>>> are extensions that cannot be disabled, or don't disable properly.)
>>> Leaving this critical detail up to people who don't really know what
>>> they're doing and have no documentation to go by is... not optimal.
>>> out which part of THE ENTIRE SHELL CODEBASE you need to monkey-patch
>>> to make the changes you want?
>> find that part of the code, if that's the way it's actually done (I
>> don't for a moment pretend to have written an extension, however given
>> your track record in overstating things, you don't really think I'm
>> going to take your word for it, do you? ;) )
You realise that that's no guarantee that anyone's an expert at a task,
right? I know lots of people who get paid to do things who don't take the
optimal route to doing them.
How many questions did you ask on, oh, I don't know, the GNOME mailing
lists?
> written.
Bingo!  Just because you didn't happen to look in the right place doesn't
mean that the documentation doesn't exist.
>>> the source code is the documentation". No, random Internet user, the
>>> source code is not and will never be the documentation. Because the
>>> source code gives you the *implementation* not the *interface*.
Of course not.
And "deleting code from the running system" isn't the same as extending
it.
Jim
Date: 19 Mar 2015 12:54:30
Message: <550aff46$1@news.povray.org>
> there.
Well there ya go ... not sure if it's totally the plug-in container
processes fault /entirely/ my gut feeling says it's Flash. IHMO the most
insecure process hog on the face of the planet ... JavaScript is a close
second. On my linux system I /have/ also observed the plug-in container
process consuming a lot of cpu cycles and have gone into the process
table and killed it off when I've noticed it still running when Firefox
isn't. I've also seen it delay my system going into stand-by as well, so
/perhaps/ it's not completely blameless. Since a couple of versions ago
I've not been running Firefox with Flash plug-in and have opted for
Flash to HTML5 extension because I do frequent YouTube. If I run across
something on other sites that I just /have/ to see I fire up Chrome
because it comes bundled with the browser. In short ... I just gave up
on Flash when I noticed an end of support notice for linux platforms.
Date: 19 Mar 2015 13:00:42
Message: <550b00ba$1@news.povray.org>
Yeah it's there you just got to dig a bit ... snipped most of what Jim
said because I agree and I just wanted to add that Andrew kind of
reminds me of Sheldon ;-)
