POV-Ray : Newsgroups : povray.off-topic : Enter the compiler Server Time
13 May 2026 06:58:35 EDT (-0400)
  Enter the compiler (Message 21 to 26 of 26)
Subject: Re: Enter the compiler
Date: 8 Mar 2015 08:07:07
Message: <54fc3b6b$1@news.povray.org>
On 8-3-2015 10:43, Stephen wrote:
> On 08/03/2015 08:28, Thomas de Groot wrote:
>>>> How true Dr Frankenstein. All those tales about vampires... :-)
>>> Not me. I was nowhere near the place, then. ;-)
>> What? Where were you on the 6th of July 1816? At midnight? ;-)
> I have an alibi.
> I was nursing Dr John back to health after the Battle of Seven Oaks. He
> stepped in front of a musket ball aimed at me. Governor Semple was a fool.
Of course, of course. I should have known... It explains quite a lot though.
Date: 8 Mar 2015 08:45:16
Message: <54fc445c$1@news.povray.org>
>> I have an alibi.
>> fool.
> though.
It does. Blew half his head off. All over my best uniform as well. Took
him a deuce of a time to recover. I used some native lichen to pack the
wound. The same stuff that fellow, John Wyndham, found. He made a full
recovery, better than ever. Especially in the head department. The
lichen was assimilated and gave him supper powers. ;-)
Regards
Date: 8 Mar 2015 11:11:24
Message: <54fc669c$1@news.povray.org>
>>> I have an alibi.
>>> fool.
>> though.
I should be careful with those 'supper'(sic) powers. Obesitas, you know. ;-)
Glad he recovered though. I remember Wyndham made quite mess of the
stuff but apparently it was good for something after all. Doesn't John
clap his hands too often? for no apparent reason?
Date: 17 Mar 2015 15:09:45
Message: <55087bf9$1@news.povray.org>
On 05/03/2015 06:37 PM, Orchid Win7 v1 wrote:
> On 03/03/2015 10:45 PM, Orchid Win7 v1 wrote:
>> It's a tad verbose (!!), but it works. The protocol is that every
>> top-level Haskell constant becomes a
>> public static Thunk<...> OB_XXX = ...
>> Any top-level constant that's a *function* also gets a
>> public static T0 FN_XXX(Thunk<T1> arg1, Thunk<T2> arg2, Thunk<T3> args)
>> ...compiled code...
> ...yeah, that doesn't actually work.
> Haskell allows you to declare a "constant" who's type is polymorphic. C#
> does not.
In other fun news, C# allows you to use Func<Foo, Bar> to denote a
first-class function from type Foo to type Bar. It does *not* allow you
to represent a generic function in this manner, however. For example,
   public List<TX> map<TX, TY>(Func<TX, TY>, List<TY>) {...}
is a valid generic method. But the *only* way to encode this as a Func<>
is to do
   Func<Func<object, object>, List<object>, List<object>>
and then some nifty run-time type-checking. You know, the exact thing
that generics exists to prevent? :-P
Ah well, I suppose it's silly to expect the entire Haskell type system
to fit *exactly* into a radically different programming language. (I
suspect C++ could probably handle it though...)
Date: 18 Mar 2015 04:27:46
Message: <55093702$1@news.povray.org>
Have you looked at F#? That limitation might be with C# rather than the CIL.
Date: 19 Mar 2015 04:17:09
Message: <550a8605$1@news.povray.org>
> CIL.
Yeah, I remember briefly looking at F#, and being unimpressed. Since
it's designed to directly interact with a huge, very imperative OO
library, it ends up being very imperative and OO.
I did think about generating CIL directly. It looks pretty complicated
though. And so far, I've only found a few little corners where C# won't
do what I want. Overall, it looks to be refreshingly easy for C# code to
talk to Haskell and vice versa. Although... come back when I've actually
*finished* the thing! ;-)
I can live with the lack of generics. It mostly affects internal
machine-generated code, so...
