POV-Ray : Newsgroups : povray.off-topic : Those who wait Server Time
13 May 2026 16:30:12 EDT (-0400)
  Those who wait (Message 7 to 16 of 66)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Those who wait
Date: 29 Jul 2014 03:18:38
Message: <53d74ace@news.povray.org>
Reminds me of this:
http://www.bbc.com/news/science-environment-28402709
Date: 29 Jul 2014 03:38:59
Message: <53d74f93$1@news.povray.org>
> Less than the electricity to illuminate the building, I would think...
Depends how big your building is :-) But I find it hard to believe you
would use *on average* 500W (or whatever your PC uses flat out) of lighting.
Date: 29 Jul 2014 03:46:46
Message: <53d75166@news.povray.org>
I suppose it depends on the size of the building, but given that
100W incandescent light bulbs are (still) popular, even a small building
is probably using those a lot.
Date: 29 Jul 2014 05:08:38
Message: <53d76496@news.povray.org>
I suppose you could have 20x 100W bulbs burning for 6 hours every day,
that would add up to an average of 500W.
Date: 29 Jul 2014 05:31:12
Message: <53d769e0$1@news.povray.org>
>>> lighting.
How did you came up with that 500W figure ?
Most ventirad of cpu are about 100 to 150W, and when rendering the
graphic card is nearly idle, so even with a disk and some memory chips,
the global power would be about 200W when rendering, even with a 80%
efficient PSU. (you do not have to keep the screen on during the render).
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 29 Jul 2014 06:58:18
Message: <53d77e4a$1@news.povray.org>
Well I needed to upgrade from a 500W to 750W+ PSU on my latest machine,
which I thought was mainly due to the graphics card, so 500W without
using the graphics card sounded about right. But then that probably is
worst case assuming powering all parts simultaneously.
The motherboard presumably uses a fair whack as well, as on mine at
least it's got two quite large heatsinks. The other interesting I just
found out is that my GPU uses about 3x the power as my CPU, yet the CPU
heatsink and fan is bigger? How does that work?
Anyway, I figured out my average lighting use was about 25W (a handful
of LED and energy saving bulbs on for 4-6 hours/day), so even just
leaving my computer idle is using more than that...
Date: 29 Jul 2014 07:12:14
Message: <53d7818e$1@news.povray.org>
On 29/07/2014 12:58, scott wrote:
> The other interesting I just found out is that my GPU uses about 3x the
> power as my CPU, yet the CPU heatsink and fan is bigger? How does that
> work?
CPU usually throttle down once in the 80°C range. GPU are able to go to
105+°C (and might throttle down too once there).
The air flow on the cpu heatsink is rather loose, whereas the air flow
on the gpu heatsing is a tunnel.
Once you put these two facts together, you have on one side a
dissipation of 120W, and and the other side one of 250W.
(From air at 30°C, delta Temperature is 40 vs 65, more than 50%
effective alone)
Date: 29 Jul 2014 08:20:02
Message: <53d79172$1@news.povray.org>
That then begs the question, why aren't CPUs using the same thermal
technology as GPUs?
Date: 29 Jul 2014 13:49:26
Message: <53d7dea6$1@news.povray.org>
> lighting.
My previous PC had a peak power usage of something like 200W when
running Crysis, and while not doing anything it sat at about 100W. You
don't have to turn on many lights 100W lights to easily exceed that...
Date: 29 Jul 2014 19:11:13
Message: <53d82a11$1@news.povray.org>
Am 29.07.2014 13:12, schrieb Le_Forgeron:
>> work?
> effective alone)
Plus, the CPU fan also needs to provide airflow for various mainboard
components, such as memory and voltage dividers.
