This must be one of strangest problems I've come across. Sometimes the
"r" key does not work - every other key works fine. However, as soon as
I enter a single "r" using Alt+114 the "r" key itself comes back to life
and works perfectly. I have no idea what could be causing this strange
behaviour, but it seems more like a software/driver issue rather than
hardware.
> hardware.
you have, of course, used a different keyboard on the machine and also
used the first keyboard on a different machine.
But, as you imply, weird.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
>> hardware.
Update: I think the problem only started since the keyboard was plugged
into the monitor's internal USB hub (I'd moved it here to tidy up some
wires under my desk). The r stopped working approximately 25% of the
time after the PC puts the monitor to sleep and then I wake it back up
again. However I moved it to the next USB socket on the monitor, then
back to the first and I can't recreate it anymore in either socket...
Maybe it's just Windows telling me I need to restart my machine after 17
days?
> days?
There you go.
"Have you tried switching it off then on again" :-D
John
Protect the Earth
>> days?
> There you go.
Tisk! Tisk! Power Off Reset, if you please. ;-)
Regards
Am 04.07.2014 19:37, schrieb Stephen:
>>> days?
>> There you go.
In German, we say: "Hilft es nicht im Guten, musst du einmal booten."
Loosely translated: "If it won't be good, you have to make it boot."
On 04/07/2014 7:12 PM, clipka wrote:
>>> There you go.
How very interesting.
That is similar to our:
"If in doubt, give it a clout."
(Affirmative action by TV repairmen. The world over. :-) )
Regards
I solemnly promise to kick the next angle, I see.
At my old place, I had a little KVM switch on my desk. That used to do
weird and wonderful things to the (PS/2) keyboard and mouse from time to
time...
> days?
My home PC doesn't get switched off for weeks on end.
(I just checked POV-Ray, and apparently it's only been running 13 days.
That's because 2 weeks ago my Internet stopped working, and I wanted to
see if rebooting the PC would fix it... It didn't.)
Am 04.07.2014 22:08, schrieb Stephen:
>>>> There you go.
Percussive maintenance - even space technology can't do without. (If the
solar panel won't unfold, find a way to give the satellite a good shake...)
>>>>> There you go.
As we say.
We're not being paid to hit it. We're being paid because we know where
to hit it.
Regards
