POV-Ray : Newsgroups : povray.off-topic : Wireless connection issue Server Time
10 Oct 2024 17:20:47 EDT (-0400)
  Wireless connection issue (Message 1 to 10 of 13)
Subject: Wireless connection issue
Date: 19 Jun 2014 08:08:43
Message: <53a2d2cb@news.povray.org>
For a few weeks now I have connection problems between my PC and
modem/router. I have had the modem/router checked by professionals and
it seems to work as expected, however I can make a wired connection
presently but /not/ a wireless one. As far as I understand it, this
seems to be a problem within my PC. I can illustrate this with a couple
of images.
Checking for the network connections, I get the screen in image Network
Connections_01.jpg attached. The used wired connection is at left. I am
concerned with the middle one which says 'not connected'.
Highlighting it and  clicking 'Connect To' I get the image: Network
Connections.jpg. The highlighted connection should be mine, surprisingly
it does /not/ say 'connect automatically' with a check box, which it did
in the past. See also image: Network properties.jpg. Anyway, clicking
'connect' does not establish the connection but results in an error
message. As additional info, checking for IP addresses shows the result
in image: ipconfig_on.jpg.
What to do? Something in the Network Connection Properties (image:
Network Connection Properties.jpg)? Or how to make a /new/ network
connection from scratch? Somehow I have not been able to achieve that
:-( Or is there a problem with the Wireless LAN?
I hope this connection will persist long enough to be able to get a
dialogue going. My experience has been that even the wired connection
has a tendency to break down...
Download 'network connection_01.jpg' (67 KB) Download 'network connections.jpg' (33 KB) Download 'network properties.jpg' (119 KB) Download 'network connection properties.jpg' (80 KB) Download 'ipconfig_on.jpg' (108 KB)
Preview of image 'network connection_01.jpg'
Preview of image 'network connections.jpg'
Preview of image 'network properties.jpg'
Preview of image 'network connection properties.jpg'
Preview of image 'ipconfig_on.jpg'
Subject: Re: Wireless connection issue
Date: 19 Jun 2014 09:27:48
Message: <53a2e554@news.povray.org>
Has this setup (modem, wireless card, PC, software) ever worked
correctly, or did it just suddenly stop working one day?
Some ideas to try:
- Reinstall your wireless hardware driver (find it in device manager,
right click on it and choose "uninstall" then restart the machine). That
should make it reinstall the drivers and then create a new connection
from scratch.
- Log on as a different user and disable any startup programs
- Try another wireless adaptor (borrow a USB one?)
- Boot from a Linux Live CD (assuming there are drivers for your
wireless card)
Date: 19 Jun 2014 10:05:32
Message: <53a2ee2c$1@news.povray.org>
Yes, it did work perfectly for several years but gives trouble since a
router's reset.
> Some ideas to try:
> from scratch.
> wireless card)
Thanks.
Date: 19 Jun 2014 10:41:06
Message: <53a2f682@news.povray.org>
> from scratch.
I assume you mean this (see image) in Win7?
Download 'wireless lan card properties_drivers.jpg' (73 KB)
Preview of image 'wireless lan card properties_drivers.jpg'
Date: 19 Jun 2014 10:51:10
Message: <53a2f8de$1@news.povray.org>
>> from scratch.
Yep - I'd just hit uninstall and then restart the machine, it should
then find the "new" hardware and install the driver for it when it
restarts. Make sure you have a copy of the driver handy just in case
Windows has lost it... (maybe a good opportunity to check you have the
latest one anyway).
Date: 19 Jun 2014 10:59:53
Message: <53a2fae9$1@news.povray.org>
> latest one anyway).
Right.
I checked the drivers and they are up to date.
I did something else then (had found that on the web): in the 'Device
Manager' I (1) /uninstalled/ the wireless LAN, then (2) from 'Action' I
did 'Scan for hardware changes'.
Worked but unfortunately, that did not solve the issue.
I am going further tomorrow...
Date: 20 Jun 2014 13:02:44
Message: <53a46934$1@news.povray.org>
> router's reset.
Maybe your neighbor put MAC address filters to make you stop from
stealing his bandwidth!  ;)
Seriously though, check your router's encryption settings (Did the WPA
key get reset, etc...)
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 Jun 2014 03:42:44
Message: <53a7da74$1@news.povray.org>
I assumed Thomas had other devices working ok with the modem via
wireless, but maybe that was an incorrect assumption (I'm used to having
half a dozen devices on wireless) - good call.
I once had a modem/router that would not persist settings after a power
cycle unless you specifically went to the "save changes" page and told
it to save them. Caught me out.
Date: 23 Jun 2014 03:57:32
Message: <53a7ddec$1@news.povray.org>
I addressed him sternly and he promised to make amends :-)
As far as I can tell, That went ok.
Date: 23 Jun 2014 04:01:31
Message: <53a7dedb$1@news.povray.org>
I only have one device indeed. So, strictly speaking, I not even do need
wifi, but I like things to work properly of course.
True. I certainly need to 'save' all changes before changing pages on
the modem/router.
