POV-Ray : Newsgroups : povray.off-topic : Publishing Server Time
13 May 2026 08:26:53 EDT (-0400)
  Publishing (Message 15 to 24 of 24)
Subject: Re: Publishing
Date: 18 Jun 2014 15:40:55
Message: <53A1EB3F.5000007@gmail.com>
According to a friend of mine that has used InDesign for some personal
projects, InDesign can export and import XML. That could mean that you
only have to create a template and then insert the documentation by
automatic search and replace. (I use the same technique to build simple
websites.)
Apparently InDesign even has scripting facilities, she has not used them
herself. She is not a programmer, but a child of the WYSIWYG point and
click generation. All in all it sounds to me as something that matches
your interests and abilities. Perhaps she can even help you a bit. She
has met people that use complex programs to do simple tasks before (i.e.
we have worked together for some time).
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 18 Jun 2014 16:57:04
Message: <53a1fd20$1@news.povray.org>
> websites.)
OK. Well that all sounds like something worth looking into.
(I overheard the guy who's working on the documentation the other day.
We was explaining - as if this is a really complex and novel idea - how
he's managed to configure InDesign in such a way that it *automatically*
updates the table of contents and the index when you change something.
As if this is a really sophisticated idea, rather than - you know -
something that EVERY half-decent document production system should be
able to do out-of-the-box...)
It sounds like with some suitable tinkering, we could probably get quite
a nice workflow with this thing.
I wonder if there's any official documentation for it online. I'll take
a look...
Date: 18 Jun 2014 17:24:04
Message: <53a20374$1@news.povray.org>
> a look...
https://helpx.adobe.com/ca/indesign.html
(You'll need to replace the "ca" bit of the URL...)
- Go to adobe.com
- Click on menu
- Click on the inDesign icon
- Click Learn & support
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 19 Jun 2014 01:45:01
Message: <web.53a27873a1cd9691de778ac40@news.povray.org>
> > websites.)
> a look...
Good idea. I have had to work with indesign files given by clients and I managed
to work with it. I wouldn't compare the learning curve to Blender at all,
InDesign is a lot easier.
Alternatively afaik SVG supports feathered dropshadows and rounded boxes. I
think SVG could be the future of design because it seems to support just about
everything needed for print and web.
-Nekar Xenos-
Date: 19 Jun 2014 02:27:27
Message: <53a282cf$1@news.povray.org>
svg has even draft about multipage... which, with the ability to use CSS
at top of svg file, might or might not be a good thing.
In formating of the page, there is already the World vs North-America
(A4 vs US letter). Either you designed your template to only use the
common area, dropping the margin (width 210 vs 216 mm, height 297 vs 279
mm, so 6 mm & 18 mm of white..), or you didn't and the change of paper
becomes "interesting" (truncated text, or repaginated with references
becoming wrong...)
A document is more than a collection of pages.
And remember: your documents will be migrated to the new company logo
and charts when the bigger corporation buy your company... or resell
it... or change its visual identity, or want to explore a new market.
Better keep a strict separation between formatting and content. (your
diagrams & pictures might show the company logo, but it should not be
copied inside every of them, it should be part of the formatting data
that can be referenced by them). The company name as well as the product
name are also not part of the content.
Just because nobody complains does not mean all parachutes are perfect.
Date: 19 Jun 2014 09:16:16
Message: <53a2e2a0$1@news.povray.org>
> becoming wrong...)
This.
I happen to work with commercial software packages that were bought,
renamed, and merged multiple times... It makes life interesting when
looking for upgrade logs.  I imagine documentation writers must be
having a field day.
Date: 19 Jun 2014 11:20:47
Message: <53A2FFCB.1050204@gmail.com>
> becoming wrong...)
Huh, I though current paper sizes were IPad, IPad mini, IPhone,
1600x1200,1280x1024,..., and whatever the android phones/tablets use.
Date: 19 Jun 2014 13:36:14
Message: <53a31f8e@news.povray.org>
> at all, InDesign is a lot easier.
The idea in the comparison (on my part) was not to say that they're
equally difficult, but that the UI seems to get in the way (at least with
FrameMaker, I've no direct experience with InDesign) until you understand
the workflow that it's designed for.  I've used a number of Adobe
products over the years, and have found that to be the case.
IOW, it's not about "this is more difficult than that" but that it is
important to learn the tool, and there is a learning curve before one
becomes familiar enough to be very productive.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 19 Jun 2014 15:18:15
Message: <53a33777$1@news.povray.org>
So cynical for one so young. ;-)
Regards
I solemnly promise to kick the next angle, I see.
Date: 19 Jun 2014 15:30:01
Message: <web.53a339d2a1cd969125a480c50@news.povray.org>
Jim Henderson <nos### [at] nospamcom> wrote:
> On Thu, 19
> Jim
True. It did take some time to figure things out.
The documentation and Google helped a lot
-Nekar Xenos-
