POV-Ray : Newsgroups : povray.off-topic : You work in computers don’t_you? Server Time
25 Feb 2026 05:22:50 EST (-0500)
  You work in computers don’t_you? (Message 1 to 10 of 34)
Subject: You work in computers don’t_you?
Date: 26 May 2014 16:39:23
Message: <5383a67b$1@news.povray.org>
And you know the next line is. Can you look at my laptop?
And what he brings round is a ruggedized laptop running XP. My neighbour
is a car mechanic and his laptop is for running car diagnostics. The DVD
reader will read data discs but not video DVDs. The device drivers for
the DVD player are up to date. When I put a Video disc in it did not
Windows 7 disc in. And although it said that it could not run the
programme it did read the file structure.
I did try an external DVD reader/writer but the system did not even see
that. To be fair takes a lot of power and has two USB inputs the laptop
properly.
Another thing it is a reconditioned machine, still with warranty.
Any suggestions?
Regards
Subject: Re: You work in computers don’t_you?
Date: 26 May 2014 17:35:46
Message: <5383b3b2$1@news.povray.org>
A video DVD is merely a data DVD using the UDF filesystem, containing
files with specific names. It's not like CDs where an audio-mode CD and
a data-mode CD have a totally different structure. I can believe that
the device won't *play* a video DVD (that requires access to an MPEG-2
codec, which usually requires actual *money), but I'm baffled as to how
it fails to see the disk at all...
...unless this is a region-coding "thing"...
Date: 26 May 2014 19:03:05
Message: <5383c829@news.povray.org>
On 26/05/2014 22:35, Orchid Win7 v1 wrote:
> ), but I'm baffled as to how it fails to see the disk at all...
Me too. I didn't have time to look at it for long and he was looking
over my shoulder all the time. As if it were one of his cars and I was
about to pull a flanker. {Golly Gosh! I can't find a correct meaning for
that word on Google. I mean pull a fast one. (braces for Dr John)}
I am reasonably sure the two Videos I tries were region free.
I am wondering if it might be the operating system. A cut down version
of XP. It is after all a tool. It might be a design feature allowing
only essential services.
Regards
Subject: Re: You work in computers don’t you?
Date: 26 May 2014 19:36:37
Message: <5383d005@news.povray.org>
On Mon, 26 May 2014 21:39:23 +0100, Stephen wrote:
> Any suggestions?
Use the warranty? ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 26 May 2014 19:38:00
Message: <5383d058$1@news.povray.org>
On Mon, 26 May 2014 22:35:48 +0100, Orchid Win7 v1 wrote:
>> When I put a Video disc in it did not recognise that there was a disc
>> mounted at all. “Insert a disc”. I put a Windows 7 disc in. And
>> although it said that it could not run the programme it did read the
>> file structure.
Not usually.  The disc usually shows up and the software says that it's
the wrong region and offers to burn one of the "change region" toggles in
the firmware, which is usually a limited number of times thing.
Unless you use Linux, in which case the software doesn't care, doesn't do
anything with the firmware, and just decodes the region the way it should
because region coding is a stupid idea. ;)
Jim
Date: 27 May 2014 02:12:48
Message: <53842ce0$1@news.povray.org>
>> Any suggestions?
My first thought too.
But other than not seeing video DVDs it is working fine.
And as it is second hand, quite a bit cheaper than a new one I imagine.
Really it is a nice to have.
I'll take another look at it and check the build. Also put a PS on my
external DVD player.
Regards
Date: 27 May 2014 03:37:33
Message: <538440bd$1@news.povray.org>
No, I work as pianist in a brothel.
Date: 27 May 2014 04:23:48
Message: <53844b94$1@news.povray.org>
From oxforddictionaries.com
Flanker
 noun
<snip>
pulled a flanker on the army
Note the 'dated' in the definition
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Subject: Re: You work in computers =3D?windows-1252?Q?don=3D92t_you=3D3F?=3D
Date: 27 May 2014 07:55:00
Message: <web.53847c24e2713e707f6b03a40@news.povray.org>
Note the "dated" in the OP. ;-)
Subject: Re: You work in computers =3D?UTF-8?B?ZG9u4oCZdCB5b3U/?=3D
Date: 27 May 2014 07:55:01
Message: <web.53847cf15a9948e87f6b03a40@news.povray.org>
Well I never. I did not know that. :-)
I thought that you bent hard things after pumping your bellows. ;-)
