POV-Ray : Newsgroups : povray.off-topic : A small challenge Server Time
25 Feb 2026 05:23:00 EST (-0500)
  A small challenge (Message 1 to 3 of 3)
Subject: A small challenge
Date: 1 May 2014 14:15:56
Message: <53628f5c$1@news.povray.org>
Does anybody here know how to read C?
Basically, my problem is this:
root# fdisk -l /dev/sdc
Disk /dev/sdc: 320.1 GB, 320072932864 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142447 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
    Device Boot      Start         End      Blocks   Id  System
/dev/sdc1              63      128519       64228+  af  HFS / HFS+
root# mount /dev/sdc1 /mnt
root# echo $?
0
root# umount /mnt
root# mount --ro -o offset=32256,sizelimit=6576994 /dev/sdc /mnt
mount: wrong fs type, bad option, bad superblock on /dev/loop20,
        missing codepage or helper program, or other error
        In some cases useful info is found in syslog - try
        dmesg | tail or so
root# dmesg | tail
[164258.208493] hfs: unable to find HFS+ superblock
[164398.983651] hfs: invalid secondary volume header
[164398.983654] hfs: unable to find HFS+ superblock
[164404.235785] hfs: invalid secondary volume header
[164404.235787] hfs: unable to find HFS+ superblock
[164407.461400] hfs: invalid secondary volume header
[164407.461404] hfs: unable to find HFS+ superblock
In order words, if I mount /dev/sdc1, it works perfectly. But if I mount
/dev/sdc, passing in the byte offsets to the start and end of the first
partition, it doesn't work at all.
By pointing my web browser at kernel.org and wandering aimlessly through
the Linux kernel source code, I was eventually able to discover that the
first message ("unable to find HFS+ superblock") appears on line 410 of
fs/hfsplus/super.c - which seems like a logical enough place for
superblock-reading code to live.
My question: Can anybody figure out why the code is actually failing?
What is it unhappy about? What has it expecting to find that wasn't
there? (I guess it's kinda hard to conclusively pin this down without a
copy of the disk...)
For me, just figuring out where the various functions are defined is
quite hard. (C has this wonderful arrangement where any part of the code
can refer to any other part of the code, with no algorithm for ever
discovered WHERE that code is actually defined - except for
whole-program analysis, obviously.) Also fun is that some of the
"functions" are actually macros. Just to mess with your head.
OTOH, considering this is an OS kernel... it's not as awful as I had
expected.
Subject: Re: A small challenge
Date: 1 May 2014 14:38:40
Message: <536294b0@news.povray.org>
Le 01/05/2014 20:16, Orchid Win7 v1 nous fit lire :
> root# echo $?
> 0
> root# umount /mnt
>        dmesg | tail or so
> root# dmesg | tail
And why do you want to use sdc instead of sdc1 ?
Offset seems an option for the loop device only (aka: the disk is
actually a file). Never heard of it for normal disk. Same for sizelimit.
Mount is tricky, but it's nothing when compared to fsck mega jumbo
trampoline.
the option for hfs are only (from man page): creator, uid, dir_umask,
file_umask, umask, session, part and quiet.
If you really want to access the content from /dev/sdc, you would need
first to copy it as a file (on another bigger disk) (with
"dd if=/dev/sdc of=whatever_file_not_on_sdc" ), and then
mount -t hfs -o ro,loop,offset=32256,sizelimit=6576994
/whatever_file_not_on_sdc /mnt
(absolute path of the file is needed by mount)
Date: 13 Jun 2014 14:09:15
Message: <539b3e4b@news.povray.org>
> root# echo $?
> 0
> root# umount /mnt
> dmesg | tail or so
It turns out that updating to the next release of OpenSUSE completely
fixes the issue. So that should be a five-minute job...
