POV-Ray : Newsgroups : povray.off-topic : CPU fan trouble Server Time
25 Feb 2026 14:17:39 EST (-0500)
  CPU fan trouble (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: CPU fan trouble
Date: 17 Feb 2014 03:16:16
Message: <5301c550@news.povray.org>
On 16-2-2014 18:34, Warp wrote:
Thanks Warp, I am going to investigate the possibilities you mention.
In the mean time, this morning, it started up ok, without problems, and
all temperatures are at normal levels. I really wonder what might have
happened.
Latest Windows update was on wednesday; the problem on sunday. I don't
think that would be related. Room temperatures are around 20 degrees and
even lower at day's start up, so that seems to be ruled out too.
It might have been a small piece of dust stuck on a vital part that sent
temperatures soaring up to 99 degrees (and that is now totally burned
up). Puzzling.
I'll keep my eyes open.
Date: 17 Feb 2014 03:20:24
Message: <5301c648$1@news.povray.org>
On 16-2-2014 16:53, Stephen wrote:
> On 16/02/2014 3:28 PM, Thomas de Groot wrote:
>> The four core temperatures however, are all around 31 degrees Celsius.
>> Any idea is welcome. Thanks in advance.
> About a year or so ago, I was having temperature problems with my
> laptop. (There was a broken fan blade which was jamming the fan.)
> TThrottle helped me, keep the temperatures reasonable,  until I found
> out the problem and get it fixed.
> http://efmer.eu/boinc/
Thanks Stephen. I shall look at TThrottle in any case. This morning the
machine behaved like it should so I am wondering what happened. It
probably needed its Sunday Rest. I am again thinking that maybe a piece
of dust was stuck at the wrong place and needed to be burned down. The
fan is whole and rotating correctly.
Date: 17 Feb 2014 03:45:01
Message: <web.5301cba95221760c7f6b03a40@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote:
> Thanks Stephen!
> This is just what I need. Here in Sunny South Africa I can't render when
> it's hot unless I set Pov-Ray to use only 2 or 3 cores.
rely on the duty cycle to throttle PovRay. When in hot countries.
> Hmm BOINC. How about someone doing a BOINC patch for Pov-Ray? =D
> That would be awesome!
Yeh!Show me a Pover that has spare CPU ticks to give to someone else. ;-)
> Getting a little off off-topic here :)
It used to be a "hanging offence" at one time. ;-)
Date: 17 Feb 2014 04:00:01
Message: <web.5301cedb5221760c7f6b03a40@news.povray.org>
It is worth having a look at. It will log your core temperatures and CPU usage
for  at least 12 hours. Then send you an email if they go over a limit, if you
want. I see that there is a newer version out, I should give it a look over.
> This morning the
It might have been a core stuck in a loop and it just needed a re-boot. You
never can tell.
> The
Good and PC fans are easier to change.
http://www.almico.com/speedfan.php
Date: 17 Feb 2014 04:09:34
Message: <5301d1ce$1@news.povray.org>
>> This morning the
> never can tell.
Indeed. They should do what they are told though ;-)
>> The
Not sure about controlling fan speed. It seems to happen automatically
in situations where external temp (for instance) is high. I shall have a
look at speedfan too. Thanks!
Date: 17 Feb 2014 04:38:52
Message: <5301d8ac$1@news.povray.org>
> never can tell.
You can get task manager to show the CPU usage for each core
(Performance -> View -> CPU History -> One Graph Per CPU), it should
then be obvious if any of the cores are stuck in a loop.
Date: 17 Feb 2014 06:45:01
Message: <web.5301f5335221760c7f6b03a40@news.povray.org>
> > never can tell.
I did not mean it literally. :-)
One of the irritations with my current, i7 laptop, is. Regularly the system'
process will use 13% ~ 25% of the recourses and the machine will be very
sluggish. But you never see a core maxed out.
You do with PovRay, though. :-)
Date: 17 Feb 2014 07:17:01
Message: <5301fdbd@news.povray.org>
>> re-boot. You
>> never can tell.
Of course. I forgot to check that yesterday. Stupid. ;-)
Date: 17 Feb 2014 07:20:56
Message: <5301fea8$1@news.povray.org>
>>> never can tell.
My i7 PC does that too sometimes. It seems to have to do with some
arcane Windows process... I checked with the task manager and one or
another process was active.
Date: 17 Feb 2014 08:00:00
Message: <web.5302067d5221760c7f6b03a40@news.povray.org>
> > never can tell.
Indeed but...
instructions, it looks like it would be suitable for slowing down noisy fans.
