POV-Ray : Newsgroups : povray.off-topic : CPU fan trouble Server Time
10 Sep 2025 03:04:16 EDT (-0400)
  CPU fan trouble (Message 21 to 25 of 25)
Subject: Re: CPU fan trouble
Date: 22 Feb 2014 12:22:12
Message: <5308dcc4@news.povray.org>
Le_Forgeron <lef### [at] freefr> wrote:
> IIRC, he said that the temperatures of cores were fine (and low) when
> the incident happened.
Of course they were because the fan was spinning so fast. It doesn't
mean the load wasn't at 100%.
Date: 22 Feb 2014 12:22:45
Message: <5308dce5@news.povray.org>
> Well, that I forgot to check indeed. But I am pretty sure it was not the
> case. The system was neither slowed down at all.
The CPU load being high doen't necessarily mean that the system becomes
sluggish.
Date: 23 Feb 2014 03:27:19
Message: <5309b0e7@news.povray.org>
> sluggish.
True indeed. However, what set off the fan seems to have been the
extreme high temperature (99C) somewhere on the motherboard. Related to
a core? I don't know. I do not pretend to understand the works ;-)
There is a huge lot of confusion on the web about what TEMPIN0, TEMPIN1
and TEMPIN2 are referring to. Nobody seems really to know. So, examples
given, some say:
TEMPIN0=System Temp
TEMPIN1=North Bridge
TEMPIN2=South Bridge
others guess:
TMPIN0 = SYS
TMPIN1 = CPU
TMPIN2 = MCH
and others, comparing HWMonitor with Everest Ultimate come to:
BIOS - HWMonitor - Everest
SYS = TMPIN0 = Motherboard
CPU = TMPIN1 = CPU
MCH = TMPIN2 = Northbridge
I cannot bake any bread from that :-(
Date: 24 Feb 2014 03:36:04
Message: <530b0474$1@news.povray.org>
> given, some say:
Most BIOS settings have a page that shows temperatures and fan speeds,
the manual of the motherboard should tell you what each one is. I assume
the confusion is because different motherboard manufacturers use
different "channels" for different purposes.
Date: 24 Feb 2014 07:15:12
Message: <530b37d0$1@news.povray.org>
>> given, some say:
Which leads of course to the expected question of 2.50 Martian Dollars:
/where/ is that manual? I have none; I cannot find anything on the web
resembling docs.
motherboard: Pegatron Corporation 2AB6
