POV-Ray : Newsgroups : povray.off-topic : CPU fan trouble Server Time
25 Feb 2026 12:31:52 EST (-0500)
  CPU fan trouble (Message 16 to 25 of 25)
Subject: Re: CPU fan trouble
Date: 17 Feb 2014 11:26:01
Message: <53023819@news.povray.org>
> In the mean time, this morning, it started up ok, without problems, and
> all temperatures are at normal levels. I really wonder what might have
> happened.
Btw, did you check that something wasn't consuming CPU time? Was the CPU
at 100% load?
Date: 17 Feb 2014 17:09:07
Message: <53028883$1@news.povray.org>
On 17/02/2014 12:20 PM, Thomas de Groot wrote:
> My i7 PC does that too sometimes. It seems to have to do with some
> arcane Windows process... I checked with the task manager and one or
> another process was active.
Arcane indeed.
I downloaded Process Explorer to see if I could find out what was
causing it. Cyber-man's magic. Whooo! :-)
Regards
Date: 18 Feb 2014 01:23:02
Message: <5302fc46$1@news.povray.org>
>> happened.
> at 100% load?
IIRC, he said that the temperatures of cores were fine (and low) when
the incident happened. Of course, if it was at start-up of the computer,
they hadn't had the time to heat yet. (I guess they have that big
inertia of a block of alu-copper attached to them, something the other
chip might not have)
Just because nobody complains does not mean all parachutes are perfect.
Date: 18 Feb 2014 03:29:37
Message: <530319f1$1@news.povray.org>
>> happened.
> at 100% load?
Well, that I forgot to check indeed. But I am pretty sure it was not the
case. The system was neither slowed down at all.
@ Le_Forgeron: the temperatures of the cores remained low the whole day.
Only the TMPIN1 of the motherboard showed an abnormal temperature of 99,
according to the CPUID Harware Monitor.
Date: 18 Feb 2014 10:30:41
Message: <53037ca1$1@news.povray.org>
> Arcane indeed.
svchost, SearchIndexer, taskmgr, are some of the arcanes (to me)
although normally they do not take up much cpu time.
Date: 22 Feb 2014 12:22:12
Message: <5308dcc4@news.povray.org>
Of course they were because the fan was spinning so fast. It doesn't
mean the load wasn't at 100%.
Date: 22 Feb 2014 12:22:45
Message: <5308dce5@news.povray.org>
The CPU load being high doen't necessarily mean that the system becomes
sluggish.
Date: 23 Feb 2014 03:27:19
Message: <5309b0e7@news.povray.org>
> sluggish.
True indeed. However, what set off the fan seems to have been the
extreme high temperature (99C) somewhere on the motherboard. Related to
a core? I don't know. I do not pretend to understand the works ;-)
There is a huge lot of confusion on the web about what TEMPIN0, TEMPIN1
and TEMPIN2 are referring to. Nobody seems really to know. So, examples
given, some say:
TEMPIN0=System Temp
TEMPIN1=North Bridge
TEMPIN2=South Bridge
others guess:
TMPIN0 = SYS
TMPIN1 = CPU
TMPIN2 = MCH
and others, comparing HWMonitor with Everest Ultimate come to:
BIOS - HWMonitor - Everest
SYS = TMPIN0 = Motherboard
CPU = TMPIN1 = CPU
MCH = TMPIN2 = Northbridge
I cannot bake any bread from that :-(
Date: 24 Feb 2014 03:36:04
Message: <530b0474$1@news.povray.org>
> given, some say:
Most BIOS settings have a page that shows temperatures and fan speeds,
the manual of the motherboard should tell you what each one is. I assume
the confusion is because different motherboard manufacturers use
different "channels" for different purposes.
Date: 24 Feb 2014 07:15:12
Message: <530b37d0$1@news.povray.org>
>> given, some say:
Which leads of course to the expected question of 2.50 Martian Dollars:
/where/ is that manual? I have none; I cannot find anything on the web
resembling docs.
motherboard: Pegatron Corporation 2AB6
