POV-Ray : Newsgroups : povray.off-topic : CPU fan trouble Server Time
13 May 2026 09:28:02 EDT (-0400)
  CPU fan trouble (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: CPU fan trouble
Date: 17 Feb 2014 04:38:52
Message: <5301d8ac$1@news.povray.org>
> It might have been a core stuck in a loop and it just needed a re-boot. You
> never can tell.
You can get task manager to show the CPU usage for each core
(Performance -> View -> CPU History -> One Graph Per CPU), it should
then be obvious if any of the cores are stuck in a loop.
Date: 17 Feb 2014 06:45:01
Message: <web.5301f5335221760c7f6b03a40@news.povray.org>
> > never can tell.
I did not mean it literally. :-)
One of the irritations with my current, i7 laptop, is. Regularly the system'
process will use 13% ~ 25% of the recourses and the machine will be very
sluggish. But you never see a core maxed out.
You do with PovRay, though. :-)
Date: 17 Feb 2014 07:17:01
Message: <5301fdbd@news.povray.org>
>> re-boot. You
>> never can tell.
Of course. I forgot to check that yesterday. Stupid. ;-)
Date: 17 Feb 2014 07:20:56
Message: <5301fea8$1@news.povray.org>
>>> never can tell.
My i7 PC does that too sometimes. It seems to have to do with some
arcane Windows process... I checked with the task manager and one or
another process was active.
Date: 17 Feb 2014 08:00:00
Message: <web.5302067d5221760c7f6b03a40@news.povray.org>
> > never can tell.
> Indeed. They should do what they are told though ;-)
Indeed but...
> Not sure about controlling fan speed. It seems to happen automatically
> in situations where external temp (for instance) is high. I shall have a
> look at speedfan too. Thanks!
instructions, it looks like it would be suitable for slowing down noisy fans.
Date: 17 Feb 2014 11:26:01
Message: <53023819@news.povray.org>
> In the mean time, this morning, it started up ok, without problems, and
> all temperatures are at normal levels. I really wonder what might have
> happened.
Btw, did you check that something wasn't consuming CPU time? Was the CPU
at 100% load?
Date: 17 Feb 2014 17:09:07
Message: <53028883$1@news.povray.org>
Arcane indeed.
I downloaded Process Explorer to see if I could find out what was
causing it. Cyber-man's magic. Whooo! :-)
Regards
Date: 18 Feb 2014 01:23:02
Message: <5302fc46$1@news.povray.org>
>> happened.
> at 100% load?
IIRC, he said that the temperatures of cores were fine (and low) when
the incident happened. Of course, if it was at start-up of the computer,
they hadn't had the time to heat yet. (I guess they have that big
inertia of a block of alu-copper attached to them, something the other
chip might not have)
Just because nobody complains does not mean all parachutes are perfect.
Date: 18 Feb 2014 03:29:37
Message: <530319f1$1@news.povray.org>
>> happened.
> at 100% load?
Well, that I forgot to check indeed. But I am pretty sure it was not the
case. The system was neither slowed down at all.
@ Le_Forgeron: the temperatures of the cores remained low the whole day.
Only the TMPIN1 of the motherboard showed an abnormal temperature of 99,
according to the CPUID Harware Monitor.
Date: 18 Feb 2014 10:30:41
Message: <53037ca1$1@news.povray.org>
> Arcane indeed.
svchost, SearchIndexer, taskmgr, are some of the arcanes (to me)
although normally they do not take up much cpu time.
