POV-Ray : Newsgroups : povray.off-topic : Hardware Server Time
13 May 2026 10:47:41 EDT (-0400)
  Hardware (Message 11 to 20 of 42)
Subject: Re: Hardware
Date: 24 Dec 2013 04:28:16
Message: <52b953b0$1@news.povray.org>
On 24/12/2013 08:18 AM, scott wrote:
> Do you want GFLOPS or FPS? You can use those performance charts like
> GPUmark and also look at framerates in common games if that's what
> you're going to be using the GPU for.
I would presume that render frame-rate and compute power are strongly
correlated. Then again, I guess I don't know that much about the render
pipeline, so...
> FWIW when I built my machine earlier this year I chose the GTX 650 (I
> ok, but I'm not one for playing lots of cutting-edge games, FarCry3 is
> probably the latest one I have that is heavy on graphics - that runs
> fine at max detail. I'm waiting for GTA5 to come out for the PC in
> March, hopefully that will handle it ok.
My GTX 260 was able to handle Crysis, Crysis 2, FarCry 3 and just about
every other game I tried on very high detail settings. (Although I think
FarCry 3 became noticeably laggy when I turned everything up to maximum
- it was only slight though.)
If a GTX 260 can handle it, presumably a newer generation card with
multiple times the compute power will eat it up.
Ultimately, I'm probably going to wait for my next bank statement before
I decide. It's only a few days away, after all...
Date: 24 Dec 2013 04:41:26
Message: <52b956c6$1@news.povray.org>
Oooh, is that 1995 I hear calling again :-)
Date: 24 Dec 2013 05:03:55
Message: <52b95c0b$1@news.povray.org>
As well as that, I'm going to try to get CUDA to work again. I've got a
few bits of software which *claim* to use your GPU to do compute-heavy
work much faster. If only any of them actually *worked*...
Date: 24 Dec 2013 05:05:15
Message: <52b95c5b$1@news.povray.org>
What, you think I should be using Internet banking? I prefer it if bad
people *can't* steal all my money merely by guessing a password...
Date: 24 Dec 2013 05:27:36
Message: <52b96198$1@news.povray.org>
Oh it's 2005 calling now...
Date: 24 Dec 2013 10:26:55
Message: <52b9a7bf@news.povray.org>
What bank uses fixed passwords (rather than a sheet of single-use codes)
and thinks that it's safe?
Date: 24 Dec 2013 11:17:44
Message: <52b9b3a8$1@news.povray.org>
>> yet, it produces 2,200 GFLOPS (and has twice the RAM).
> It's not the size that matters. It's how you use it.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 25 Dec 2013 00:48:41
Message: <52ba71b9$1@news.povray.org>
Am 24.12.2013 16:26, schrieb Warp:
What bank uses a sheet of single-use codes and thinks that it's safe?
Over here in Germany we're past that age. Codes dynamically generated
from transaction details it is for us.
Date: 25 Dec 2013 07:39:35
Message: <52bad206@news.povray.org>
Well, much safer than a fixed password.
You can't do anything with the sheet alone if you don't have the user's ID.
Granted, it's not impossible to acquire both, but if you don't store your
ID anywhere and instead have it memorized, it becomes difficult. (Basically
they would need to install some spyware in the computer you are using in
order to get the ID, and then physically steal the passcode sheet. Not
impossible, but not likely to happen.)
How does that even work?
Date: 25 Dec 2013 14:02:29
Message: <52bb2bc5$1@news.povray.org>
Am 25.12.2013 13:39, schrieb Warp:
Just two words:
(1) Phising.
(2) Man-in-the-middle attack.
There are two variants in use:
(A) Each time you submit a transaction via browser, you get a
transaction-specific authorization code via SMS to your mobile phone,
including some essentials of the transaction (like the amount of money
transferred, and the target bank account) to make sure that you and the
bank are talking about the same deal.
(B) You get a code generator from your bank. Typically this would be a
combination of a bank card with a built-in chip, plus a card reader with
a built-in display to make sure that the code is generated from the
transaction details you desire.
(As certified card readers are expensive, have never really taken off,
and would probably be difficult to integrate into web-based online
banking, the common solution is an inexpensive battery-powered
stand-alone device using optical transmission from web interface to card
reader.)
