One of my laptops is finally dying. At least, the screen is; it has a
beautiful magenta tint.
I'm running openSUSE 13.1 on it (I upgraded two days ago) and I'm pretty
sure it will run a second monitor through the VGA socket on the side. My
question is, therefore, has anyone here tried to remove a laptop screen
and then boot the machine?
I have a feeling it will fail POST, but does anyone know different?
BTW It's a Toshiba A110-274
John (growing a moustache for Movember)
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
I haven't tried removing the screen and booting it, but replacing a
laptop screen isn't difficult - I think I found a spare for an old Dell
laptop I have around here on eBay for pretty cheap. I know I found
motherboards there as well.
Jim
> Jim
Good point. However, firstly the only screens I can find are in the £60
range and the machine ain't worth that (data's all backed up, so no loss
if scrap it). Second, I was thinking of letting The Feegle have it to
watch Peppa Pig on. If I put a box round it, it would look like Pappi's
machine and he'd feel very grown up. :-)
John
Protect the Earth
If the whole screen looks fine apart from the lack of a green component
in every pixel, then I'd say the issue is before any of the electronics
actually inside the screen. It might be worth re-seating the flat
cable(s) between the screen and the main board in their connectors first
to see if that fixes it. Or if you're unlucky there might be a break in
the tracks on the actual cable - but that should be easy to test for (if
you have a meter that can measure resistance) and you might be able to
pick up a spare.
I don't see any reason why it shouldn't work, but can't you just disable
the internal screen in the OS?
> pick up a spare.
It's an uneven magenta tint with a bright green spot in the top left
corner when I mouse-over it.
The problem is POST. I can set the OS to ignore the internal screen.
I'll try some experiments this weekend providing that The Feegle gives
me some space.
John
Protect the Earth
Am 26.11.2013 12:07, schrieb Doctor John:
I'm not sure about laptops, but IIRC the classic POST just checks for
the precence of a graphics card (or the onboard equivalent), and gives a
damn whether there's actually a display connected to it.
That is very encouraging. I'm still not going to try until the weekend -
a laptop in pieces would be too tempting a target for The Feegle.
John
Protect the Earth
You mean the colour tint changes depending on where you move the mouse?
If you want, post a photo of the screen whilst displaying a plain white
and then plain green background, and I'll see if I can figure out what
has happened.
