POV-Ray : Newsgroups : povray.off-topic : Adventures with WCF Server Time
13 May 2026 10:48:32 EDT (-0400)
  Adventures with WCF (Message 21 to 30 of 30)
Subject: Re: Adventures with WCF
Date: 12 Nov 2013 09:03:44
Message: <52823540@news.povray.org>
> Am 11.11.2013 21:17, schrieb Warp:
> > Orchid Win7 v1 <voi### [at] devnull> wrote:
> >> Oh, and if you try to return a
> >> local variable as the result of a function, your code may segfault.
> > Strange, given that probably at least 80% of functions do that.
> No, not at all. Those 80% return the /value/ of a local variable. Big
> difference.
Well, if you define it like that, then it's impossible to return a local
variable. It's local.
Date: 12 Nov 2013 09:06:21
Message: <528235dd@news.povray.org>
> If you think the fact that your code can segfault if called with a
> specific set of inputs is "minor", then... enjoy C++! :-D
But then, some tasks take seconds in C++ to run, while they may take
hours with Haskell, so there's that.
Date: 12 Nov 2013 14:00:48
Message: <52827ae0$1@news.povray.org>
Haskell isn't the only programming language which is "safe" enough that
a typical beginner won't usually cause an OS-level crash just by
accident. There are plenty of other safe languages...
It's true that a finely-crafted C++ program will probably be faster than
anything you could write in a safe language. It's also true that most
code isn't very "finely-crafted"...
Date: 12 Nov 2013 14:07:52
Message: <52827c88$1@news.povray.org>
On 12/11/2013 02:01 PM, Francois Labreque wrote:
>>> XML is a document formatting language. Not a transfer protocol. XML does
>>> not do error handling, retransmits, keepalives, etc... If you use raw
>>> TCP sockets, you need to reinvent all those wheels.
>> You send an XML document explaining what method you want to call. The
>> server sends back an XML document either saying it went OK, or
>> describing why it didn't. Provided you standardise the XML, you don't
>> particularly need anything from the transport protocol.
> How would you implement splitting the payload across multiple packets,
> with a direct socket connection? How would your server know the
> difference between a malformed XML document with missing closing tags
> and a missing packet?
> How do you tell your server (or client) that there should be more data
> coming?
> How do you handle errors?
> The answer is to reinvent XML wheels that already exist in HTTP.
TCP already handles splitting a message into packets and reassembling it
on the other side. Of the things you've mentioned, error reporting is
the *only* thing TCP doesn't already do - and that's quite easy to deal
with using XML. (HTTP lets you report a 3-digit error code. XML lets you
report an entire stack trace if you wish.)
>>> In an entreprise setting. you need to do application layer parsing of
>>> your traffic to ensure that, amongst other things, PII does not excape,
>>> so using HTTP means that a third party firewall will be able to do deep
>>> packet inspection out of the box.
>> How does HTTP have any baring on this?
> Everyone knows how HTTP is defined, so it's easier to find the relevant
> data in an HTTP stream, than in a proprietary protocol.
I don't see how parsing XML over HTTP is any easier than parsing XML
over raw TCP.
>>> Also, HTTP is very easy to proxify, so your application will work in
>>> most entreprise settings, without having to resort to Socks, or other
>>> forms of tunnels.
>> If you're trying to send commands and replies, the *last* thing you want
>> is some proxy caching it for you...
> I'm not talking about caching, I'm talking about relaying. Most proxies
> are indeed caching proxies, but their priamry function is to relay
> traffic from one network to another network and keeping both networks
> isolated.
I have no idea why you'd want to do that.
>> This is the fundamental problem with HTTP. It's designed to transfer
>> static documents, not ephemeral commands and replies.
> You are correct, that there are more specialized messagin protocols out
> there (most of them proprietary), such as IBM MQ-Series or TIBCO
> Rendezvous, just to name them, that are more suited to handling
> ephemeral commands, than HTTP, but most of the civlized world has no
> problems whatsoever using HTTP (or more often HTTPS) to exchange data
> between systems and even companies.
> Since the makers of WCF do not know ahead of time what you will be doing
> with their framework, they decided to pick the most widely used tranfer
> protocol to make most of their users' life less miserable.
I still don't really see why you need any additional services beyond
what TCP provides. What do these proprietary protocols get you?
>> I don't see why you would ever need more than one TCP connection -
>> unless you're actually trying to issue multiple commands simultaneously
>> or something...
> In your particular case, maybe, but you are using a general purpose
> framework that is built for general use.
> Let's say a travel agent is discussing various possible plane/hotel
> combinations with a client. She shouldn't "hog" a tcp socket open for
> minutes while the client makes up his mind, nor should she have to
> re-enter her credentials everytime she checks the availablity at another
> hotel, or makes the final reservation.
> In the background, the application would open one session and issue a
> session ID, after having verified the user's credentials. Then after
> that, whenever the travel agent makes a query through her reservation
> system, the client-side application would open a new TCP sessions,
> include the application ID inside the payload and send one (or more)
> commands to the server. The server would send the reply and the TCP
> connection would then close to leave resources available for the next
> agent.
You speak as if having a TCP connection open is some terrible overhead.
If you're allocating a session ID, I would suggest that storing the
details of this session somewhere is already using *far* more resources
than a simple TCP connection...
Date: 12 Nov 2013 22:47:57
Message: <5282f66d$1@news.povray.org>
>> coming?
> on the other side.
TCP only ensures that data that is split in multpiple packets will be
rassembled in the right order at the other end.  It does not tell you
ahead of time how much data to expect, so you can't know in advance if
you should still be waiting for the end of that XML document, or if it
was malformed and is missing closing tags, and you should simply reject it.
Well, duh.  XML is a document markup language.  You can return a 249
page court document if you'd like, however parsing that response might
prove to be more cumbersome than necessary.  There's nothing that
prevents you from sending that stack dump via HTTP either.  In fact,
many applications do.  Having a 200 or 503 at the start makes it easier
for the application to know if it succeeded or failed, though.
The short error codes used by SMTP, FTP, HTTP, et al. are for efficiency.
> over raw TCP.
Parsing XML is parsing XML.  However, getting the appliance to recognize
that the data in that tcp flow on a weird port is actually XML is
harder.  It can be done in most boxes made by the big players in the
field, but it's more work.
>>>> forms of tunnels.
>> isolated.
To prevent unauthorized traffic from leaving or entering your network
(or parts of it).  To mask the details of how the back-end of your
server farm is laid out.  There are many valid uses for proxies, apart
from caching the Google Doodle of the day to speed up the users'
connection and cut down on bandwidth usage.
Just like SMTP is a well defined and understood way of exchanging user
messages between machines, and FTP a well defined way of exchanging
files between machines.  Some people decided to create new protocols
that allowed them to send messages between applications, route them to
specific queues, define priority levels, etc... in a well defined manner
that would allow them to exchange information using a common "language".
Of course, these protocols would be overkill for a project of the size
of your testbed, but in an entreprise where the shop floor work load
management application needs to talk to the inventory system and the
employee scheduler; the inventory system needs to talk to the purchasing
application and the shipping/receiving management system; the employee
scheduler needs to talk with the payroll system; who also needs to talk
to the accounting system; who needs to interface with the external bank
system; and the inventory management can automatically place orders with
suppliers, you need something can efficiently route these messages
between all these systems.
>>> or something...
>> agent.
Nope.  Denials of service target the number of simultaneous connections
for a reason.  Most servers will fork a thread for each open TCP
connection, whereas a session ID is a few bytes in a table (more,
obviously if you have other data associated with that seesion to track,
such as items in your shopping cart, for example).  Managing all these
threads on a busy server can become a problem real fast.
Of course, your test bed does not need to worry about that, since you
dont expect to have more than one client and you don't expect to have
the server go back to listening mode for new clients while processing
the request of the first client.
[CSB]
About 10 years ago, we were in a "critsit" because of problems with a
customer's online banking web site.  Each server in the server farm
would grind to a halt every 6 hours or so for 5-10 minutes and then pick
up where it left off.  Of course, users weren't happy, and neither were
the mainframe guys in the back because of the number of unfinished
transactions that had to be rolled-back.
It turned out that Sun's HTTP server's (formlery Netscape Entreprise
Server) method of hanlding the high number of tcp connections was not to
have one thread per connection, but to put each connection state in a
table and have a pool of worker threads work the connections in turn.
Every once in a while, a "janitor" thread would spawn and freeze the
connection table while it went down the list to send an ACK to each
client, wait a few seconds and then close the connections that didn't
respond.*  While it was doing this, no new connections could be
established, nor taken down gracefully.  The support team keept upping
the number of allowable connections, and the number of worker threads
hoping to get rid of the problem, but only made it wors when the janitor
did start.  In the end, they figured that having a very small connection
table, and having the janiotr thread constantly stopping it for a few
seconds was a much better solution than having the server come to a
complete stop for minutes at a time every few hours.
*We were on the phone with some pretty interesting "core" programmers by
the time we reached that conclusion.
[/CSB]
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 13 Nov 2013 19:03:24
Message: <5284134b@news.povray.org>
I'm wondering why I should care if a beginner can make the program crash.
It's a bit like saying "power tools are dangerous, and therefore children
shouldn't be using them." Yeah, true, but why should I care? I know how
to use it.
Date: 14 Nov 2013 03:31:55
Message: <52848a7b$1@news.povray.org>
> to use it.
OK, but given the choice between a knife that's just a sheet of metal
with sharp edges, and a knife that has a smooth handle that you can
hold, which would you prefer?
Date: 14 Nov 2013 14:38:27
Message: <528526b3$1@news.povray.org>
>> on the other side.
If the XML is machine-generated, it shouldn't ever be malformed. If it
is, that's a bug. (Which I suppose is something real applications have
to deal with, but it doesn't concern me overly much.)
> Well, duh. XML is a document markup language. You can return a 249 page
> court document if you'd like, however parsing that response might prove
> to be more cumbersome than necessary. There's nothing that prevents you
Sure. It's just that HTTP isn't adding any real benefit here.
>> over raw TCP.
How "hard" can it be to look for traffic on a particular port number?
Sheesh...
>>> isolated.
> (or parts of it). To mask the details of how the back-end of your server
> farm is laid out. There are many valid uses for proxies, apart from
> caching the Google Doodle of the day to speed up the users' connection
Isn't that what a firewall does?
> files between machines. Some people decided to create new protocols that
OK, well if you need to relay messages between multiple machines or you
need to actually *queue* them (and presumably receive responses
asynchronously) and you start needing prioritisation and so forth...
yes, that becomes a little bit more complex.
Literally *all* I am trying to do here is have one piece of code invoke
methods in other piece of code, which happens to be on a different
machine. That's all I actually want. And everybody insists that WCF is
the only way to achieve that, so...
> of your testbed
Perhaps that's what it comes down to.
The long and short of it is, I managed to configure WCF to *not* use
HTTP, and it works exactly the same as if it *did* use HTTP. Which, to
me, rather suggests that using HTTP is a total waste of time.
Isn't that why *real* servers use thread pools or green threads or some
similar mechanism which avoids allocating an entire OS thread for every
single individual TCP connection?
It seems to me that what you're *actually* saying is that having lots of
OS threads is a lot of overhead. Well, yeah, nothing new there...
Ah yes, the joys of garbage collection...
Date: 15 Nov 2013 08:30:50
Message: <5286220a$1@news.povray.org>
I've been to several offices where the IT was configured with a proxy
server as the only access to the outside world. Seems to be quite a
common method in large organisations to control the traffic.
Date: 15 Nov 2013 09:11:07
Message: <52862b7b$1@news.povray.org>
>> reject it.
> is, that's a bug.
A bug that has been exploited by many a malware.  ;-)  Trust no one!
True, but it is a good idea to develop good programming habits and do
some error-checking nonetheless.
To reuse the powertool analogy that you and Warp are discussing, even if
you develop the habit of wearing gloves and protective eyewear everytime
you use your circular saw, even for small jobs, you have a much smaller
risk of injuring yourself, the day you're tearing down the old kitchen
counters and the saw hits a nail and jumps back at you.
Firewall only inspect and block unauthorised traffic from leaving or
entering a network, but for them to work, you need an actual route to
the outside world to exist and point to the firewall.  With a proxy, you
can actually NOT have any route to the internet on your inside lan.
Your Proxy has two interfaces, one on the inside lan (and everyone uses
that in their broswer config), and another one on an internet-accessible
network.  This kills most bots and other malware dead.
In a corporate environment, you'd typically have such a setup to isolate
the developpers (or "guest" wifi access, for example) from the rest of
the production network, so that they can play as much as they want with
their toys while still having access to needed intranet and internet
resources, without impacting the rest of the business.
A 30 second google tells me that you can do something called
"NetTcpBinding" instead of "BasicHttpBinding".  I have no idea if that
is what you are looking for because I don't know how the framework works
and this was just a blog entry explaining how to tell a server to say
"Hello World!" and it didn't delve into the various intricacies of not
using BasicHttpBinding.
