POV-Ray : Newsgroups : povray.off-topic : Where is the world going? Server Time
14 May 2026 01:07:24 EDT (-0400)
  Where is the world going? (Message 100 to 109 of 199)
Subject: Re: Where is the world going?
Date: 12 Sep 2013 19:22:43
Message: <52324cc3$1@news.povray.org>
On 9/11/2013 10:17 PM, Jim Henderson wrote:
> On Wed, 11 Sep 2013 10:14:24 -0700, Patrick Elliott wrote:
>> True enough.. and, this is a perfect example imo of why, after the Apple
>> II line, the whole thing went to shit - you no longer had to know how
>> any of it worked, or, even on a hardware level, could find out (where
>> Apple gave you a built in language, which you could boot to even without
>> an OS, and a complete circuit diagram). The whole, "It will work if I
>> reboot." thing is just.. gah! But, yeah, most people won't even try to
>> comprehend the basics, and treat a PC likes is a big cell phone (and
>> have done so since before cell phones).
> Well, for most people, PCs are tools.  It's like driving a car - most
> people don't know how to fix them, but most people also know how to drive
> them (allegedly).
> There are always those of us who want to see what's "under the hood", but
> most people don't really give a shit - they just want to do their job,
> and the tool they use helps them do it.
> That's a lot of why Windows works the way it does.
> Jim
True, some people, like a certain niece of mine, can't even figure out
that, "You need to change the oil once in a while."
But, cars you at least "can" do maintenance on, or have other people do
so, and you don't generally, on having them do that, find that 90% of
the "experts" you might want to take them to are going to either a) be
unable to fix a broken taillight wire, or b) do so without stealing
every single things you had in the trunk, and throwing it in a dumpster,
because it was "unfixable" with all your shit still in the vehicle. PCs,
especially, tend to exhibit both traits....
Date: 13 Sep 2013 00:43:05
Message: <523297d9$1@news.povray.org>
No, those who want to learn how stuff works can, even with PCs.
But a microchip is just a tad more complex than a combustion engine,
too.  The same holds true for magnetic recording media, storage devices,
etc.
Jim
Date: 13 Sep 2013 01:20:50
Message: <5232a0b2@news.povray.org>
> too.
Not any more it's not. ;-)
I used to service my own cars and bikes. Other than check the fluids all
I can do with the engine nowadays is check that it is still there. :-)
Regards
Date: 13 Sep 2013 12:44:25
Message: <523340e9$1@news.povray.org>
>> too.
Well, some cars have computers in them now, that's true.  But the
mechanical parts are still basically the same.  Patrick's analogy is
flawed because he's comparing physical items in the boot to data on a
hard drive.  The two are so /not/ comparable it's not even funny.
Jim
Date: 13 Sep 2013 19:17:49
Message: <52339d1d$1@news.povray.org>
>>> too.
> Jim
Give me a break. It was supposed to be a bit of a joke. But, it is never
the less true anyway. "Reinstall" is practically a #1 solution in
Windows, when things break bad enough, and, even if you don't throw out
everything in the trunk when you do that (instead of the equivalent of
taking it out, then putting it all back in again), the process of
"fixing" a problem by doing such a thing goes a bit beyond replacing the
air freshener. Its more like stripping the car down to the body shell,
then having to "reinstall" every single part, from the ground up, just
to fix a loose wire, at least.. under Windows anyway. Linux is a bit
less stupid about it. But, if you want a better example, how about a
motor home, instead of a car? Those things are, from what I brother
says, built with no clear plan, beyond the chassis, everything tacked on
where ever it fits, and damn near no intention/design-considerations,
with respect to, "How the fuck is someone supposed to get at this part
of the vehicle, to fix it, when it break, without literally removing
half of the entire vehicle, and everything installed in it?"
So, yeah, there can be some valid comparisons you can make.
Date: 13 Sep 2013 19:39:15
Message: <5233a223@news.povray.org>
On Fri, 13 Sep 2013 16:17:48 -0700, Patrick Elliott wrote:
> Give me a break.
OK, done. :)
Jim
Date: 14 Sep 2013 02:50:19
Message: <5234072b$1@news.povray.org>
>>> too.
Would you not consider a car's fuel control system a computer?
> But the mechanical parts are still basically the same.
Yes the bits that go roundy round are basically similar as is the
structural nits. But how do you set up the spark plug timing on your car?
All analogies break down at some point, eh?
The real problem is that computers are domestic appliances now. They are
not just for geeks.
Here is another analogy or parable, whatever.
Rule number one when working with electrical equipment is disconnect it
from the mains before opening it up. Yes?
So you can understand in a way why my boss's boss gave me a bollocking
for working on exposed live equipment. (H&S to the forefront)
He had no answer to my question "How do I trouble shoot if it is dead?"
He went away, I powered it up, found the fault and all was well.
Mixing techie and non-techie is a very hard thing to do.
I've run out of steam, now.
Regards
Date: 14 Sep 2013 13:32:41
Message: <52349db9$1@news.povray.org>
>>>> too.
>>> all I can do with the engine nowadays is check that it is still there.
Depends on the car.  Not if it's just a throttle cable.
> car?
I have no idea - but I could ask my father-in-law or brother-in-law.
IIRC, there's a timing belt/chain in older cars that don't use electronic
fuel injection.
>> Patrick's analogy is flawed because he's comparing physical items in
>> the boot to data on a hard drive.  The two are so /not/ comparable it's
>> not even funny.
> not just for geeks.
Not necessarily.  First, unplugging it isn't going to protect you from a
charged capacitor - any first year electronics student knows that.
Well, sure.
Date: 14 Sep 2013 15:52:35
Message: <5234be83@news.povray.org>
Maybe it is just me but I've not had a car that had a direct throttle
drive for 20 years or so and I don't buy new cars. Current one is almost
10 years old and the one before that was 13 years old when it died on me.
>> car?
> fuel injection.
It is the distributor that you adjust. Using a timing light connected to
the #1 spark plug. The strobe effect makes a timing mark on the fan belt
drive wheel appear stationary. The distributor is adjusted to that the
dynamic timing mark is at TDC. IIRC
>>> not even funny.
>> not just for geeks.
That why I missed that out so not to take up more bandwidth and to
respect you savy-ness.
> Well, sure.
So that is where the problem lies. Manufacturers don't make a lot of
money if they can't sell a product to lots of non technical people.
And if you try to make a computer idiot proof, techies rail at the
restrictions imposed.
I want to buy a new laptop but I don't want Win 8 with "even your 5 year
old can operate it" OS. Nor do I want Linux where I'll have to learn a
new OS or not be able to run M$ office, for work compatibility.
I might as well ask here. Does anyone have any recommendations for a
light weight laptop that has a reasonable spec to run PovRay and Blender
and weighs a lot less the the 3kg (6.6 lb) DTR I have to lug around?
Regards
Date: 14 Sep 2013 16:33:07
Message: <5234c803@news.povray.org>
> me.
Well, yeah, like I said, if it's not an EFI system, but those have been
around for a while.
>>> car?
>> electronic fuel injection.
See how much I know about cars?  I changed the battery once and was shown
how to change the brake pads once, but I'm no expert.  Amy knows a lot
more about that sort of stuff - which makes sense, since she grew up in a
family that works on cars (her brother teaches auto body repair at the
local vocational/technical school where she grew up).
>> a charged capacitor - any first year electronics student knows that.
>>> dead?" He went away, I powered it up, found the fault and all was
>>> well.
>> Well, sure.
Yep.  And that's the problem Patrick has.  The system is idiot-proof, but
he's no idiot, and wants to do what he wants to do.  You can't mass-
market something like that, though, because the non-technical people who
make up the "masses" are going to be idiots when it comes to technology,
because they just want to drive to work, they don't want to fine-tune the
fuel injection system.
So you have to compromise and get the mass-market option.
I've been happy with my Dell laptop, but I'm not sure how much it
weighs.  It's a couple years old - the 17R (N7110 is another number I see
associated with it), but is pretty speedy (i7 processor) and has plenty
of memory (8GB, max for this model).
Jim
