POV-Ray : Newsgroups : povray.off-topic : Where is the world going? Server Time
13 May 2026 12:06:03 EDT (-0400)
  Where is the world going? (Message 11 to 20 of 199)
Subject: Re: Where is the world going?
Date: 27 Aug 2013 12:56:48
Message: <521cda50@news.povray.org>
On 27/08/2013 2:45 PM, clipka wrote:
> At least some editions of Windows also provide a shortcut in the start
> menu, in the "accessories" submenu, called "command prompt" (IIRC).
My version has an "Open command window here" as an entry in the context
menu (right click) in explorer.
Regards
Date: 27 Aug 2013 13:11:38
Message: <521cddca$1@news.povray.org>
On 27/08/2013 4:11 PM, Warp wrote:
> Stephen <mcavoys_AT_aolDOT.com> wrote:
>>> I remember win95, a good user interface with DOS - where is DOS now?
>> Hidden in the command prompt box: cmd.exe
> cmd.exe is a program, not DOS...
True it is a command-line interpreter.
Regards
Date: 27 Aug 2013 13:17:24
Message: <521cdf24$1@news.povray.org>
On 27/08/2013 08:26 AM, scott wrote:
>> Don't get me wrong, I have no problem with a simplified UI existing. If
>> there's a product specifically for people who just want to surf the
>> Internet and send a few emails, then that's great! What I object to is
>> *me* being forced to use that same product.
> You do realise if you get the "desktop" version of Win8 you get the
> standard Win7-like desktop too? It's only the "RT" version for low
> powered mobile devices that consists solely of the new GUI.
If that's only the cut-down version, then why is all the marketing
material based on it?
Also, the laptop we purchased to test Windows 8 with came with that
awful UI too, so...
Date: 27 Aug 2013 13:19:41
Message: <521cdfad$1@news.povray.org>
>> But hey, MS makes a metric tonne of money per hour, why would they even
>> care what I think?
> I remember win95, a good user interface with DOS - where is DOS now? I have Win7
> and I hate it because I can't use my own old programs. But (or install Linux)
> there is no way to avoid MS empire. And as you say, MS take all the power of the
> PC and consider the user like a child - no big responsabilities for the user, it
> is dangerous to modified all that stuff.
> Where is (except Linux) the possibility to make your machine, like you want. MS
> format the users. It's a fact.
The vast majority of end-users couldn't give a fig how much "control"
they have over the PC. They just want to be able to *use* the thing. I
have no problem with MS making computer technology easier for them to
use. (I would debate the degree to which they achieve that, mind you...)
What I *do* have an issue with is MS deciding that *I* can't get stuff
done with my own PC because "most" end-users don't need that feature.
I should probably go buy the competitor's OS instead. Oh, wait...
Date: 27 Aug 2013 14:06:42
Message: <521ceab2$1@news.povray.org>
Am 27.08.2013 18:56, schrieb Stephen:
Actually that's by far the most useful one. Unfortunately it's not
available in all editions/versions - Windows 7 Pro doesn't have it, for
instance.
Date: 27 Aug 2013 14:25:01
Message: <web.521cee67cafa64a7e9f5ed2c0@news.povray.org>
Yes, I know, but this DOS is not a real DOS, try to launh a program like
Fractint, it can't run.
Date: 27 Aug 2013 14:30:18
Message: <521cf03a$1@news.povray.org>
> instance.
It should be available by pressing Shift + Right Click. Or made
permanent by editing the registry.
http://blog.deepakazad.com/2012/04/permanently-enable-open-command-window.html
Regards
Date: 27 Aug 2013 15:02:35
Message: <521cf7cb$1@news.povray.org>
That's because DOS is a monotasking real-mode OS; applications run under
it have complete access to the physical hardware. The command prompt in
Windows is merely a DOS-compatible command interpreter. Windows itself
is a multitasking protected-mode OS. So a program like FractInt which
performs direct hardware access can never work under Windows.
You can, however, run it in a virtual machine if you so desire...
Date: 27 Aug 2013 15:05:16
Message: <521cf86c@news.povray.org>
If you want to emulate an old obsolete system, use DOSBox.
Date: 27 Aug 2013 15:30:01
Message: <web.521cfd23cafa64a7e9f5ed2c0@news.povray.org>
Yes, but I remember that MS has developed a multi-task version of DOS. Why MS
has not implemented this version?
