POV-Ray : Newsgroups : povray.off-topic : Unexpected Server Time
25 Feb 2026 10:44:36 EST (-0500)
  Unexpected (Message 1 to 10 of 30)
Subject: Unexpected
Date: 17 Aug 2013 05:20:50
Message: <520f4072$1@news.povray.org>
OK, well I never expected to end up on the *other* side of an interview
table. o_O
Basically one of the guys had to leave the office suddenly, meaning that
I was the most senior developer left. (Hey, there's only 4 of us to
start with!) So, on about twenty minutes' notice, I had to go into an
interview. Looking like crap, because it's Friday afternoon. :-.
I forget how long the interview was, but my boss apparently made his
mind up within about five minutes. (Not that he said that at the time,
of course.)
As part of the interview process, my boss likes to get people to
implement the absolute function in C#. That is, he got out some paper,
scribbled
   int abs(int input)
and handed it to the guy. (He usually ends up having to explain what an
"absolute function" is, but that's fair enough.) The objective is not so
much to have perfect syntax, but to write something that is logically sound.
On this day, the applicant came up with this:
   int abs(int input)
     int value = 0;
     for (int n = input; n != 0; n++)
       value++;
     return value;
The guy explained how it works, and my boss just stared at him in
disbelief, and then explained "that's the most bizarre answer I've ever
seen!"
Perhaps slightly frighteningly, this function *actually works* - for
negative inputs, at least. If you feed it -7, then the loop counter
counts upwards from -7 all the way to zero, and "value" at the same time
counts from 0 up to +7, which is the value returned.
There's a final twist. Because the loop condition is "!= 0" rather than
"< 0" or similar, if the input is positive to start with, the function
goes into an infinite loop...
...except that it doesn't. It locks up for a few minutes, AND THEN
RETURNS -7! O_O
We stared at each other in disbelief, and then realised that the loop
goes around roughly 2^31 times and then the counter overflows, becoming
negative. The other counter similarly overflows, eventually resulting in
the -7 we saw output.
In short, this isn't abs(), this is negate()! And it actually works! (If
by "works" you accept solutions which are absurdly slow.) Note that if
you did, say, "n <= 0" then you would have an off-by-one bug resulting
in the wrong answer. Yet this guy managed (by skill or luck) to avoid
that pitfall. Without a PC to check it with!
The guy spent so long desperately trying to wrap his brain around how to
negate a number, that he completely forgot the possibility of the number
being positive to start with. When we pointed this out, he then spent
another several minutes trying to figure out how you could perhaps tell
if a number was positive. He spent ages trying to think up what the name
of the standard function for that is...
That's pretty special. But my boss told me afterwards it's the most
bizarre code he's ever seen. *Clearly* he hasn't seen the more
obfuscated possibilities of logic programming or functional
programming... I may have to dig up some examples.
(My boss has a standard set of ways to implement abs(). They include:
* if (x < 0) return 0-x; else return x;
* return sqrt(x*x); // Evil.
* return str.Remove('-'); // String munging. Very evil!
* if (x < 0) return x ^ 0x8000; else return x; // DOESN'T ACTUALLY WORK!
I'm sure there must be more evil ways of doing this...)
Subject: Re: Unexpected
Date: 17 Aug 2013 12:56:58
Message: <520fab5a@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
>    int abs(int input)
>      int value = 0;
>        value++;
>      return value;
Having been a teaching assistant at the computing science lab, I got to
see some pretty weird programs made by students.
For example, you wouldn't believe how complicated calculating the length
of a 2D vector can become in the hands of an inexperienced programmer.
(This should be a literal one-liner, yet even 100 lines of code were
regularly broken just to do this simple thing.)
Many C and C++ compilers will actually optimize that to abs(x). I wouldn't
be surprised if a C# compiler wouldn't do the same...
Date: 17 Aug 2013 13:56:37
Message: <520fb955$1@news.povray.org>
Hmm, yes. I'm just trying to visualise that now... What would I do if I
had no idea what I'm doing? (I guess the question is, how many of these
programs ever *worked*?)
Perhaps. That doesn't mean this is a good way to achieve that goal though.
Date: 17 Aug 2013 13:58:36
Message: <520fb9cc$1@news.povray.org>
Am 17.08.2013 11:20, schrieb Orchid Win7 v1:
>    int abs(int input)
He should also be prepared for
     return Math.Abs(input);
possibly with an added comment to the effect that the abs(int) function
should be refactored away at the earliest possible opportunity ;-)
Date: 17 Aug 2013 15:20:00
Message: <web.520fcbbc825e3e9f8cb76ff30@news.povray.org>
Here's one (probably not the best) way to do it:
return x*(1-2*(x<0));
Not sure how C# handles types, but in C that would return an int.
Thanks for the laughs, btw :) When Haskell isn't the main subject, you're
actually pretty funny ;)
Sam
Date: 17 Aug 2013 15:30:01
Message: <web.520fce4c825e3e9fde4684940@news.povray.org>
Oops, that should be
return x*(1-2*int(x<0));
I just woke up :\
It blows me away that many of the job applicants must be told what an absolute
function is o_O
Date: 18 Aug 2013 03:50:14
Message: <52107cb6@news.povray.org>
Mind you, these people generally knew the pythagorean formula to do the
job (after all, they were university students.) They still managed to
break the 100-line mark.
Date: 18 Aug 2013 04:45:33
Message: <521089ad@news.povray.org>
Heh, yeah. I think when an interviewer asks how to implement a standard
library function, and you call the standard library function, you're
probably not going to get mad props for that. ;-)
Date: 18 Aug 2013 04:47:13
Message: <52108a11$1@news.povray.org>
Well, I mean, the "obvious" way is
   if (x<0) return -x; else return x;
But you can phrase that as
   return x ? x : -x;
if you prefer.
If you wanted to find crazy ways to do this in Haskell, you would have
some pretty scary options available... ;-)
Date: 18 Aug 2013 04:50:49
Message: <52108ae9$1@news.povray.org>
OK, ouch. Pythagoras and you're *still* getting this wrong??
Mind you, I recall an incident at university where our lecturer wrote
the Shannon channel theorem on the board, and everyone was like "woah,
what the heck does 'log' mean?" And the guy was like "oh, I'm sorry, I
just expected that 3rd year computer science students would know what a
logarithm is."
It turns out that only two people in the room knew what that actually
is. One of them was obviously me. Weirdly, the other one was the crazy
Mancunian rugby lout. It's the first (and last) time I ever saw him say
something sensible. And it wasn't like he had a vague idea... he seemed
to actually know what he was talking about. I guess there really *is*
more to that guy than I first imagined.
