POV-Ray : Newsgroups : povray.off-topic : A solution in search of a problem Server Time
11 Oct 2024 01:23:23 EDT (-0400)
  A solution in search of a problem (Message 1 to 10 of 12)
Subject: A solution in search of a problem
Date: 22 Jun 2013 10:39:27
Message: <51c5b71f$1@news.povray.org>
Some of you* may remember a while back I was having a discussion with
Darren about COM.
[* Particularly those of you who happen to be Darren.]
Anyway, I think I've hit upon a problem which COM might actually be able
to solve... Can I use COM to transfer some numbers into Excel and get
them graphed? And if so, how might I go about doing that?
(The alternative is to use GNUplot. But it does draw particularly ugly
graphs, and it's awkward and unintuitive to use...)
Subject: Re: A solution in search of a problem
Date: 22 Jun 2013 11:11:12
Message: <51C5BE8D.30905@gmail.com>
> Darren about COM.
why not simply Metapost?
or POV?
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 23 Jun 2013 10:13:17
Message: <51c7027d@news.povray.org>
> or POV?
Well, yeah, I could go reinvent the wheel... or I could quickly utilise
something that already exists.
There are plenty of other possibilities too - Google Charts, for
example. What none of these let you easily do is go back into the
spreadsheet and tweak the data.
Currently my program spits out a CSV file, which I then open in Excel,
manually select the range of cells I want, manually step through the
chart wizard, and now I've got a graph. It seems like there ought to be
some way to automate that...
Date: 23 Jun 2013 10:29:31
Message: <51c7064b$1@news.povray.org>
Le 23/06/2013 16:13, Orchid Win7 v1 nous fit lire :
Ploticus, split your code from your data and the data is a separate (or
more) files, in space separated columns. Never touch the code again.
But mastering ploticus is not easy. (yet, that's what I use for my bank
accounts overview/balancing)
Excel... isn't there some macro language in that flipper ? (or is it a
flight simulator ? or doom-like ?)
Date: 23 Jun 2013 11:04:43
Message: <51c70e8b$1@news.povray.org>
Yes there is. Andrew can record a macro then either edit it to be able
to change the name of the file of keep the name of the input file the same.
Sample code:
Sub Macro6()
' Macro6 Macro
     Columns("A:B").Select
     With ActiveSheet.QueryTables.Add(Connection:= _
         "TEXT;C:\Users\Stephen\Documents\Book2.csv",
Destination:=Range("$A$1"))
         .Name = "Book2_1"
         .FieldNames = True
         .RowNumbers = False
         .FillAdjacentFormulas = False
         .PreserveFormatting = True
         .RefreshOnFileOpen = False
         .RefreshStyle = xlInsertDeleteCells
         .SavePassword = False
         .SaveData = True
         .AdjustColumnWidth = True
         .RefreshPeriod = 0
         .TextFilePromptOnRefresh = False
         .TextFilePlatform = 850
         .TextFileStartRow = 1
         .TextFileParseType = xlDelimited
         .TextFileTextQualifier = xlTextQualifierDoubleQuote
         .TextFileConsecutiveDelimiter = False
         .TextFileTabDelimiter = True
         .TextFileSemicolonDelimiter = False
         .TextFileCommaDelimiter = True
         .TextFileSpaceDelimiter = False
         .TextFileColumnDataTypes = Array(1, 1)
         .TextFileTrailingMinusNumbers = True
         .Refresh BackgroundQuery:=False
     End With
     ActiveSheet.Shapes.AddChart.Select
     ActiveChart.ChartType = xlXYScatterLinesNoMarkers
     ActiveChart.SetSourceData Source:=Range("Sheet4!$A:$B")
End Sub
Regards
Date: 24 Jun 2013 03:11:40
Message: <51c7f12c$1@news.povray.org>
Haven't noticed him around for a while now.
Is this in C#? If so you need to look at Microsoft.Office.Interop.Excel
- the VS help and google will get you started using it, it's very easy
to do.
Mind you Excel's graphs are pretty yucky by default (although the newer
Office versions seem to have improved this).
If you /are/ on C# and using Windows forms then don't forget you've got
built in DataVisualization.Charting which can be used to quickly add a
charting capabilities to your program.
Date: 26 Jun 2013 13:21:16
Message: <51cb230c$1@news.povray.org>
> Sample code:
How would you execute that from outside Excel though?
Date: 26 Jun 2013 13:23:12
Message: <51cb2380$1@news.povray.org>
It seems awful quiet in this newgroup allround, really.
Then again, I now spend all day every day constantly writing code. I
hardly seem to have time to do anything else with my life now...
> to do.
Actually this is Haskell. But if it isn't too difficult, I could write
some C# to actually graph the data once it's in a CSV file...
Date: 26 Jun 2013 13:33:17
Message: <51cb25dd@news.povray.org>
>> same.
>> Sample code:
Whoa! now you are changing the question and we all know change requests
cost money.
So why would you want to execute it from outside excel when you will
need to open excel to see the graph?
But because it is you I will hazard an answer. Make the macro a startup
macro.
Regards
Date: 26 Jun 2013 15:36:34
Message: <51cb42c2$1@news.povray.org>
> cost money.
Like I said, I've got a program that generates some data. I want to
graph that data. Without having to manually press half a dozen buttons.
It's easy enough to open Excel programmatically; what isn't obvious is
how to make it run code once it opens up. (Indeed, these days that tends
to be exactly the sort of thing Excel blocks to prevent macro viruses...)
