POV-Ray : Newsgroups : povray.off-topic : Adventures with C++ Server Time
13 May 2026 16:30:12 EDT (-0400)
  Adventures with C++ (Message 36 to 45 of 65)
Subject: Re: An actual C++ question
Date: 23 May 2013 03:22:34
Message: <519dc3ba$1@news.povray.org>
>> boost::shared_ptr<std::vector<Foo>> _foo(new std::vector<Foo>());
> Oh, and it's probably best to write it like this:
> boost::shared_ptr<std::vector<Foo> > _foo(new std::vector<Foo>());
> Since some compilers will complain about using >> in a type definition
> (due to the ambiguity with the >> operator).
VisualStudio compiles this perfectly. GCC point-blank fails to compile
it. *sigh* Gotta love the number of inconsistencies between two
compilers for supposedly "the same" language...
(VC emits endless warnings about "printf may be unsafe; please use
printf_s instead". Apparently the latter function doesn't exist in GCC...)
Date: 23 May 2013 09:26:48
Message: <519e1918@news.povray.org>
You are surprised that a Microsoft product allows something that is
frowned upon by a more anal-retentive competitor?!?
They are MS-specific versions of the functions.
http://msdn.microsoft.com/en-us/library/8ef0s5kh%28v=vs.80%29.aspx
http://msdn.microsoft.com/en-us/library/239ffwa0%28v=vs.80%29.aspx
I'm sure the purists would frown that Microsoft decides to mess with
<sdtio.h> instead of putting them in a "msstdio.h" or similar.  Way back
when the dinosaurs still roamed the Earth, I used to hang in comp.lang.c
and I vividly remember certain members being quite angry at Borland for
pretending that conio.h was part of the standard headers and its
functions part of the standard libraries.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 May 2013 10:11:01
Message: <519e2375$1@news.povray.org>
Actually, I'm a little surprised that GCC didn't accept it, as that sort
of things should be allowed under the C++11 standard
(http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2005/n1757.html) and
GCC 4.7 is listed as supporting that feature
(http://gcc.gnu.org/gcc-4.7/cxx0x_status.html).  In general GCC seems to
have much better C++11 support that MSVC, so it's strange to see an
example of the opposite -- perhaps Andrew's using an old version of GCC
or something.
Date: 23 May 2013 10:14:06
Message: <519e242e$1@news.povray.org>
I don't see how the >> is ambiguous at all in this statement. Seems to
me like lazy/bad parser design if this trips it up.
Date: 23 May 2013 10:44:39
Message: <519e2b57$1@news.povray.org>
It's not quite so cut and dry as you might guess.  For example:
#include <iostream>
using std::cout;
using std::endl;
int _foo(int i) {
	return i;
namespace std {
	static const int vector = 7;
namespace boost {
	static const int shared_ptr = 5;
int main(int argc, char** argv) {
	int Foo = 3;
	cout << (boost::shared_ptr<std::vector<Foo>> _foo(NULL)) << endl;
	return 0;
If you run this program it should print "1" (at least in MSVC), which is
the result of treating < and >> and the less-than and bit-shift
operators.  Of course you couldn't write "new std::vector<Foo>()" in
this scheme, but it does show that it's hard to tell what's a template
and what's not at a purely syntatic level.
In any case, the C++11 standard does allow
"boost::shared_ptr<std::vector<Foo>> _foo(new std::vector<Foo>()); " and
the most recent version of GCC supposedly supports this.  You can read a
bit more about it here:
Date: 23 May 2013 11:38:28
Message: <519e37f3@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> > What do you mean by "field"? Your question is not clear enough.
> I mean something like
>    class Foobar
>      private:
>        boost::shared_ptr<std::vector<Foo>> foo;
>      public:
>        Foobar()
Why didn't you say so in the first place?
If you want to initialize that member function in the constructor, use
the constructor's initializer list or just assign to it in the contructor's
body. In the first case:
    Foobar::Foobar(): foo(new std::vector<Foo>)
Or if you prefer,
    Foobar::Foobar()
        foo = new std::vector<Foo>;
Btw, C++98 does not support >> for closing a double template. You have
to add a space in between.
I'm wondering why you are using a std::vector, though. I thought that what
you wanted was something like this:
class Foobar
    struct Impl;
    boost::shared_ptr<Impl> impl;
 public:
    Foobar();
In which case the implementation would be like:
struct Foobar::Impl
    std::vector<Foo> array;
Foobar::Foobar(): impl(new Impl)
Much simpler and cleaner that way.
> > (And btw, don't start names with an underscore. Those are reserved for
> > the compiler.)
> Hoooookay... In that case, there's about 200 lines in the existing
> codebase that need to be changed. o_O
I have never quite understood why so many programmers seem to be obsessed
with putting underscores at the beginning of names.
Date: 23 May 2013 11:41:32
Message: <519e38ac@news.povray.org>
Kevin Wampler <nob### [at] nowherenet> wrote:
> On 5/21/2013 10:25 AM, Orchid Win7 v1 wrote:
> > However, I can't seem to figure out what to write in the constructor.
> > I've got a field that looks like
> >    boost::shared_ptr<std::vector<Foo>> _foo;
> > What do I need to do to initialise this correctly?
*Where* are you doing that?
If you mean it like this:
class Foobar
then it works, but only in C++11. I think Andrew needed to do it in C++98.
Date: 23 May 2013 11:58:47
Message: <519e3cb7$1@news.povray.org>
Is that ambiguous?
Date: 23 May 2013 12:29:11
Message: <519e43d7@news.povray.org>
> Is that ambiguous?
Obviously not since it compiles.  It is, however, ambiguous unless you
know the types of boost::shared_ptr and std::vector (and you need to
know them during lexical analysis).  I wasn't saying that it's
impossible to correctly parse this sort of thing, just that correctly
parsing it is a more non-trivial task than it might at first appear.
Date: 23 May 2013 12:31:15
Message: <519e4453@news.povray.org>
I was just giving him an example to point out that you pass a raw
pointer to the constructor of shared_ptr and assuming that he'd figure
the rest out from there.  But you're right that I perhaps should have
been more explicit.
