POV-Ray : Newsgroups : povray.off-topic : Adventures with C++ Server Time
25 Feb 2026 21:23:33 EST (-0500)
  Adventures with C++ (Message 31 to 40 of 65)
Subject: Re: An actual C++ question
Date: 21 May 2013 13:32:36
Message: <519bafb4$1@news.povray.org>
On 5/21/2013 10:25 AM, Orchid Win7 v1 wrote:
> However, I can't seem to figure out what to write in the constructor.
> I've got a field that looks like
>    boost::shared_ptr<std::vector<Foo>> _foo;
> What do I need to do to initialise this correctly?
boost::shared_ptr<std::vector<Foo>> _foo(new std::vector<Foo>());
Take a look over the constructors of shared_ptr for more detail.  I
should note that it's relatively uncommon that I want a shared_ptr to a
std::vector.  Unless you actually need to store _foo somewhere else in
the code it's might be better to just forgo the shared_ptr and pass _foo
by reference to whichever functions need it.
Date: 21 May 2013 13:38:00
Message: <519bb0f8@news.povray.org>
Oh, and it's probably best to write it like this:
boost::shared_ptr<std::vector<Foo> > _foo(new std::vector<Foo>());
Since some compilers will complain about using >> in a type definition
(due to the ambiguity with the >> operator).
Date: 21 May 2013 17:07:09
Message: <519be1fd$1@news.povray.org>
The only reason I'm doing this is to avoid putting the real definition
of Foo in the header file.
Date: 22 May 2013 15:45:58
Message: <519d2076@news.povray.org>
What do you mean by "field"? Your question is not clear enough.
(And btw, don't start names with an underscore. Those are reserved for
the compiler.)
Date: 23 May 2013 03:21:03
Message: <519dc35f$1@news.povray.org>
I mean something like
   class Foobar
     private:
       boost::shared_ptr<std::vector<Foo>> foo;
     public:
       Foobar()
> the compiler.)
Hoooookay... In that case, there's about 200 lines in the existing
codebase that need to be changed. o_O
Date: 23 May 2013 03:22:34
Message: <519dc3ba$1@news.povray.org>
VisualStudio compiles this perfectly. GCC point-blank fails to compile
it. *sigh* Gotta love the number of inconsistencies between two
compilers for supposedly "the same" language...
(VC emits endless warnings about "printf may be unsafe; please use
printf_s instead". Apparently the latter function doesn't exist in GCC...)
Date: 23 May 2013 09:26:48
Message: <519e1918@news.povray.org>
You are surprised that a Microsoft product allows something that is
frowned upon by a more anal-retentive competitor?!?
They are MS-specific versions of the functions.
http://msdn.microsoft.com/en-us/library/8ef0s5kh%28v=vs.80%29.aspx
http://msdn.microsoft.com/en-us/library/239ffwa0%28v=vs.80%29.aspx
I'm sure the purists would frown that Microsoft decides to mess with
<sdtio.h> instead of putting them in a "msstdio.h" or similar.  Way back
when the dinosaurs still roamed the Earth, I used to hang in comp.lang.c
and I vividly remember certain members being quite angry at Borland for
pretending that conio.h was part of the standard headers and its
functions part of the standard libraries.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 May 2013 10:11:01
Message: <519e2375$1@news.povray.org>
Actually, I'm a little surprised that GCC didn't accept it, as that sort
of things should be allowed under the C++11 standard
(http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2005/n1757.html) and
GCC 4.7 is listed as supporting that feature
(http://gcc.gnu.org/gcc-4.7/cxx0x_status.html).  In general GCC seems to
have much better C++11 support that MSVC, so it's strange to see an
example of the opposite -- perhaps Andrew's using an old version of GCC
or something.
Date: 23 May 2013 10:14:06
Message: <519e242e$1@news.povray.org>
I don't see how the >> is ambiguous at all in this statement. Seems to
me like lazy/bad parser design if this trips it up.
Date: 23 May 2013 10:44:39
Message: <519e2b57$1@news.povray.org>
It's not quite so cut and dry as you might guess.  For example:
#include <iostream>
using std::cout;
using std::endl;
int _foo(int i) {
	return i;
namespace std {
	static const int vector = 7;
namespace boost {
	static const int shared_ptr = 5;
int main(int argc, char** argv) {
	int Foo = 3;
	cout << (boost::shared_ptr<std::vector<Foo>> _foo(NULL)) << endl;
	return 0;
If you run this program it should print "1" (at least in MSVC), which is
the result of treating < and >> and the less-than and bit-shift
operators.  Of course you couldn't write "new std::vector<Foo>()" in
this scheme, but it does show that it's hard to tell what's a template
and what's not at a purely syntatic level.
In any case, the C++11 standard does allow
"boost::shared_ptr<std::vector<Foo>> _foo(new std::vector<Foo>()); " and
the most recent version of GCC supposedly supports this.  You can read a
bit more about it here:
