POV-Ray : Newsgroups : povray.off-topic : Adventures with C++ Server Time
26 Feb 2026 00:52:42 EST (-0500)
  Adventures with C++ (Message 16 to 25 of 65)
Subject: Re: An actual C++ question
Date: 15 May 2013 17:53:17
Message: <519403cd@news.povray.org>
>     class PrivateClass;
>     class MyClass
>         std::shared_ptr<PrivateClass> privateObject;
Oh, and take into account that if instances of MyClass are copied around,
the copies will share the one and same PrivateClass object. That will not
get deep-copied. (That's what the "shared ptr" means, actually.)
If you want to avoid MyClass being copied around, that can be disabled.
(Of course this restricts the ways in which the class can be used, so
it's always a compromise.)
Another possibility is to write a copy constructor and a copy assignment
operator that deep-copies the private object... It all depends on how
exactly you need MyClass to behave.
Date: 16 May 2013 03:39:25
Message: <51948d2d$1@news.povray.org>
>>      class PrivateClass;
>>      class MyClass
OK. That seems easy enough.
There "should" only ever be one instance of this class; I'd just like to
avoid the program exploding if somebody *does* copy that instance for
some reason. A shallow copy is acceptable.
Date: 16 May 2013 10:55:52
Message: <5194f378$1@news.povray.org>
Is there a C++ equivalent to the C# static class? That would ensure at
compile-time that nobody tried to create an(other) instance.
Date: 16 May 2013 11:27:04
Message: <5194fac8@news.povray.org>
You could use a namespace instead of a class. Private implementation can
then all go to the source file, away from the header file.
On the other hand, this limits where you can use this "pseudoclass" and
it could be difficult to maintain backwards compatibility if you ever
wanted to change it so that more than one instance could be created.
Of course you could have a class that only has static member functions...
Date: 16 May 2013 13:19:26
Message: <5195151e$1@news.povray.org>
Le 16/05/2013 17:27, Warp nous fit lire :
You can either have all methods of a class static, or use a singleton
pattern.
Subject: Re: Adventures with C++
Date: 16 May 2013 13:46:20
Message: <51951b6c@news.povray.org>
On 14/05/2013 06:29 PM, Orchid Win7 v1 wrote:
> But that's nothing compared to how long it took to get VS to produce a
> DLL, and then get C# to successfully call this DLL without access
> violations... >_<
But THAT is nothing compared to the trouble we had trying to build a
Linux "shared object" and getting Mono to load that...
I can still hardly believe that this whole improbable contraption
actually ended up WORKING in the end! o_O
Date: 16 May 2013 14:57:33
Message: <51952c1d@news.povray.org>
> pattern.
If you are using an enforced singleton, and you don't want to expose
*any* implementation detail to the outside, one possibility would be
to do this:
// In the header file:
class TheClass
 public:
    virtual void someFunction() = 0;
    virtual int anotherFunction(int parameter) = 0;
    virtual void aThirdFunction(double, double) = 0;
TheClass& theClassInstance();
// In the implementation file:
#include "TheClass.hh"
namespace
    class TheActualClass: public TheClass
        struct InnerType { int a, b; }
        int privateMember;
        double anotherPrivateMember;
        InnerType aThirdPrivateMember;
        void privateFunction();
     public:
        TheActualClass() { /* constructor */ }
            // implement it here
    static TheActualClass actualClassInstance;
    return actualClassInstance;
Date: 17 May 2013 13:20:28
Message: <519666dc$1@news.povray.org>
On 16/05/2013 08:39 AM, Orchid Win7 v1 wrote:
>>> class PrivateClass;
>>> class MyClass
I entered this into VisualStudio, and it worked great.
However, when I tried to compile it under Linux, GCC refused to accept it.
First, VS seems to somehow allow you to compile things even without
actually importing the necessary include files. (E.g., it will happily
accept std::shared_ptr even though I didn't #include <memory>.) GCC
demands that you actually specify the include files [like you'd expect].
Weird, but true.
Second, it seems this "feature" only exists in C++11. I don't know what
GCC is defaulting to, but apparently you have to add a switch to tell it
to accept C++11. And when I do that, my code compiles perfectly, but the
rest of the codebase breaks spectacularly.
So, in summary, I had to revert everything back to how it was. *sigh*
Date: 17 May 2013 13:22:33
Message: <51966759$1@news.povray.org>
The daft thing is, it turns out to actually be pretty easy to write some
C++, make a DLL out of it, and call that from C#. The actual code that
ended up in source control is both small and simple.
This belies the vast amount of man-hours it took to *arrive* at this
final arrangement. It took an absurd amount of Google searches and
trail-and-error to get the myriad of pieces to fit together just right.
In summary, it's easy when you know how. So easy, presumably, that
nobody bothers to write down how it's actually done - so the next person
who tries to do this will have the exact same problem. :-/
Date: 17 May 2013 14:16:01
Message: <519673e1@news.povray.org>
You could use std::auto_ptr instead of std::shared_ptr, but then you'd
better disable copying for your class.
