POV-Ray : Newsgroups : povray.off-topic : Adventures with C++ Server Time
13 May 2026 13:34:20 EDT (-0400)
  Adventures with C++ (Message 11 to 20 of 65)
Subject: Re: Adventures with C++
Date: 14 May 2013 19:35:01
Message: <web.5192ca03676156f1ebb90cbd0@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> spend 3 months writing Bash scripts, two weeks writing
> VBScript and then a day writing C++ code... :-P
you truly suck at bash ;)
Subject: An actual C++ question
Date: 15 May 2013 15:58:52
Message: <5193e8fc$1@news.povray.org>
OK, so I have a class that looks like this:
   class Foobar
     private:
       Secrets secrets;
     public:
       int Foo1();
       int Foo2();
       int Foo3();
Now I want to put that in a header file. What I *actually* want to write is
   class Foobar
     public:
       int Foo1();
       int Foo2();
       int Foo3();
However, this doesn't work at all, because now the "real" Foobar class
is a different size to what all the clients of Foobar are expecting.
General mayhem ensues.
So I have to put the entire class definition into the header file. But
that means I have to put Secrets into the header file too - a data
structure that clients have absolutely no reason to know anything about.
(And I have to include everything that Secrets mentions, and everything
that those things mention, and...)
I thought perhaps I could just write an empty forward declaration, but
unsurprisingly that doesn't work; the compiler needs size information.
After Googling it, the only solution I could find was to make the
private field a *pointer* to the secret data. Now I can put a dummy
forward declaration in the header file, and define the real data
structure in the implementation, where it belongs.
And now I'm doing manual memory management. >_<
The example I got from Google shows a class with a constructor and a
destructor - so, following Warp's teachings, my immediate reaction is
"what the hell happens if somebody copies the object?" I fear the
secrets will be double-freed at some point.
My question is... Is there some simple change I might make to the code
to avoid all the gotchas of manual memory management?
I mean, there will only ever be one object, created in one place, so it
"should" be fine... but it still makes me nervous. If some day somebody
tries to use the code in a new way, I don't want it to suddenly fail in
a spectacular way so some poor sod has to spend 3 weeks trying to figure
out why...
Date: 15 May 2013 15:59:55
Message: <5193e93b@news.povray.org>
Oh, and I suppose *you* know exactly how to parse the output of sfdisk
to generate a valid mtab entry? :-P
Date: 15 May 2013 17:25:00
Message: <web.5193fcc1676156f1ebb90cbd0@news.povray.org>
just a joke about the duration of your bash programming versus C++ :)
Subject: Re: An actual C++ question
Date: 15 May 2013 17:44:06
Message: <519401a6@news.povray.org>
If having the internal-implementation-detail as a member variable of
the class is something you just must avoid, and especially if this is
a class that doesn't get instantiated a lot, then the solution is to
use the Pimpl idiom, which regardless of the funny name, is exactly what
you described. In other words, make a forward declaration of that private
class and just have a pointer to it as member.
Yes: Use std::shared_ptr instead of a raw pointer. In other words, you do
it like this:
    class PrivateClass;
    class MyClass
        std::shared_ptr<PrivateClass> privateObject;
Then in the implementation of MyClass just do a:
    privateObject = new PrivateClass;
and then you can forget about managing it yourself.
Date: 15 May 2013 17:53:17
Message: <519403cd@news.povray.org>
>     class PrivateClass;
>     class MyClass
Oh, and take into account that if instances of MyClass are copied around,
the copies will share the one and same PrivateClass object. That will not
get deep-copied. (That's what the "shared ptr" means, actually.)
If you want to avoid MyClass being copied around, that can be disabled.
(Of course this restricts the ways in which the class can be used, so
it's always a compromise.)
Another possibility is to write a copy constructor and a copy assignment
operator that deep-copies the private object... It all depends on how
exactly you need MyClass to behave.
Date: 16 May 2013 03:39:25
Message: <51948d2d$1@news.povray.org>
>>      class PrivateClass;
>>      class MyClass
OK. That seems easy enough.
There "should" only ever be one instance of this class; I'd just like to
avoid the program exploding if somebody *does* copy that instance for
some reason. A shallow copy is acceptable.
Date: 16 May 2013 10:55:52
Message: <5194f378$1@news.povray.org>
Is there a C++ equivalent to the C# static class? That would ensure at
compile-time that nobody tried to create an(other) instance.
Date: 16 May 2013 11:27:04
Message: <5194fac8@news.povray.org>
You could use a namespace instead of a class. Private implementation can
then all go to the source file, away from the header file.
On the other hand, this limits where you can use this "pseudoclass" and
it could be difficult to maintain backwards compatibility if you ever
wanted to change it so that more than one instance could be created.
Of course you could have a class that only has static member functions...
Date: 16 May 2013 13:19:26
Message: <5195151e$1@news.povray.org>
Le 16/05/2013 17:27, Warp nous fit lire :
You can either have all methods of a class static, or use a singleton
pattern.
